Lesson 12: Playing a Test Tone Through an I2S Speaker
1. Objectives
In this lesson, the ESP32-S3’s I2S peripheral generates a 440 Hz sine wave and plays it through the onboard amplifier and speaker. The program does not rely on audio files; instead, it generates PCM data in real time within the code.
2. Prerequisites
  • Complete the ESP32-S3 environment setup in Lesson01.
  • This lesson uses the built-in ESP_I2S library from Arduino-ESP32. No additional third-party libraries are required.
How to add the library:
  • No additional third-party libraries are required. This lesson uses the ESP_I2S library included with the ESP32 3.3.3 board package.
3. Arduino IDE Instructions
  1. Open Lesson12_Speaker_Playback.ino in Arduino IDE. lesson_1
  2. Confirm that the board settings match those used in Lesson01. lesson_2
  3. Click Verify to compile the program. lesson_3
  4. Click Upload to flash the program, then open Serial Monitor and set the baud rate to 115200. lesson_4
4. Hardware Instructions
  1. Connect the development board to the computer using a USB data cable and ensure that the device remains properly powered.
lesson_5
  1. After flashing the program, listen near the speaker to determine whether the 440 Hz test tone plays periodically.
  2. Observe the PLAY_START and PLAY_END messages in the serial output to confirm the playback cycle.
  3. If you cannot hear any sound, verify that the amplifier enable pin, peripheral power supply, and speaker connections are functioning properly.
5. Key Code Explanation
speaker.setPins(kI2sBclkPin, kI2sLrclkPin, kI2sDataPin);
speaker.begin(I2S_MODE_STD, kSampleRate, I2S_DATA_BIT_WIDTH_16BIT,
              I2S_SLOT_MODE_MONO);
I2S requires at least three signal lines: BCLK, LRCLK, and DATA. setPins() assigns the GPIO pins in the order BCLK, LRCLK, and DOUT. begin() configures standard I2S mode, a 16 kHz sample rate, 16-bit samples, and mono output.
const float phaseStep = 2.0f * PI * kToneFrequency / kSampleRate;
for (size_t index = 0; index < kSamplesPerBuffer; ++index) {
  sampleBuffer[index] = static_cast<int16_t>(sinf(phase) * 9000.0f);
  phase += phaseStep;
Sound is essentially a sequence of PCM samples. Here, the phase increment for each sample is calculated from the frequency and sample rate, and sinf() is then used to generate a sine wave. Multiplying by 9000.0f controls the volume and prevents distortion caused by approaching the maximum value of 16-bit PCM.
digitalWrite(kAudioEnablePin, LOW);
speaker.write(reinterpret_cast<uint8_t*>(sampleBuffer), sizeof(sampleBuffer));
digitalWrite(kAudioEnablePin, HIGH);
The amplifier enable signal on this board is active-low. Therefore, GPIO48 is pulled low before playback and pulled high after playback to disable the amplifier. speaker.write() accepts a byte pointer, so the int16_t PCM array must be converted to uint8_t* before being passed to it.
Download the Lesson 12 code
