Best Buying Guide & Reviews for Displays Paired with Raspberry Pi
October 21, 2021
Raspberry Pi, now in its fourth generation, opens up new worlds for makers through card-sized kits. The Raspberry Pi's display is indispensable, it turns the Raspberry Pi into a computer that is easy to use anywhere. Here are some pertinent guides and views for choosing a Raspberry Pi display screen.
Consider a few factors when choosing a Raspberry Pi screen:
  • Screen size refers to the diagonal length of a screen, usually in inches. In general, project requirements and budgets determine the screen size required.
  • Screen brightness refers to the luminous intensity of the surface of the screen, usually with a 200cd/sq.m display, which is sufficient for normal use.
  • Screen resolution refers to the total number of pixels that can be displayed on the screen. The resolution is closely related to the details of the picture. If the selected resolution is not compatible, the display will stretch and shrink to fit the specified resolution, causing a huge loss of signal and quality.
  • Also consider whether the screen is compatible with the Raspberry Pi model. The Raspberry Pi display screen uses connectors for effective communication between peripheral devices. The most common connectors are HDMI, VGA and AV input. In addition, whether it is a back-mounted bracket, a stand-alone type or an integrated shell screen design that accommodates the Raspberry Pi, everything has to be designed to match the Pi perfectly.
Below is a list of all the best Raspberry Pi compatible screens available online. We provide many types of Raspberry Pi screens at very low prices to help you find a screen that suits your needs and projects:
Raspberry Pi  Display  Selection View
Size
   Product
   Name
Resolution
Display Tec
DISPLAY PORT
TOUCH Panel TYPE
Audio Output
Camera
Backlight Buttom
Stand
3.5
inch
3.5inch 480x320 MCU SPI Serial TFT LCD Module Display   480x320     TFT SPI     × ×      ×   ×  ×
HDMI 3.5 inch 480 x 320 Resolution Touch Screen Monitor for Raspberry Pi   480x320     TFT
HDMI
&USB
 Resistive
Earphone      ×  √  ×
Elecrow RR035 3.5 Inch 480x320 TFT Display with Touch Screen for Raspberry Pi   480x320     TFT SPI  Resistive ×      ×  ×  ×
 4
inch
RR040I 4 inch HD 800x480 Resolution IPS TFT Touch Screen Display for Raspberry Pi   800x480     TFT HDMI  Resistive ×      ×  ×  ×
RC040 4 Inch HD 480x320 TFT Display with Touch Screen for Rapberry Pi   480x320     TFT SPI  Resistive ×      ×  ×  ×
 5
inch
RC050S HDMI 5 Inch 800x480 Capacitive Touch Monitor Built-in Speaker with Backlight Control   800x480     IPS
HDMI
&USB
Capacitive Speaker      ×  √  √
Elecrow HDMI 5 Inch 800x480 TFT Display with Backlight Control   800x480     TFT
HDMI
&USB
 Resistive ×      ×  √  ×
Elecrow RC050 5 inch HDMI 800 x 480 Capacitive Touch LCD Display for Raspberry Pi/ PC/ SONY PS4   800x480     IPS
HDMI
&USB
Capacitive Earphone      ×  √  ×
Elecrow RR050 HDMI 5 Inch 800x480 Resistive Touch Screen TFT Display for Raspberry Pi B+/2B/3B/4B   800x480     TFT
HDMI
&USB
 Resistive ×      ×  ×  ×
7
inch
RC070S 7 inch 1024*600 IPS HDMI Capacitive Touch Monitor  1024x600     IPS
HDMI
&USB
Capacitive Earphone & Speaker      ×   ×
RC070P 7 Inch 1024x600 Raspberry Pi Monitor Touchscreen Capacitive IPS Display with Built-in Speaker & Stand  1024x600     IPS
HDMI
&USB
Capacitive Earphone & Speaker      ×  √
Elecrow RC070C 7inch Touch Screen Display 1024x600 Resolution with 2MP Camera for Raspberry Pi 2/3B/3B+/4B  1024x600     IPS
HDMI
&USB
Capacitive  ×      √  ×  ×
RC070M 7 inch 1024 X 600 Touch Screen Display with 720P Camera for Raspberry Pi/ MacBook Pro./ Windows 10  1024x600     IPS
HDMI
&USB
Capacitive     ×      √  ×  ×
Elecrow RC070 7 inch 1024*600 HDMI LCD Display with Touch Screen  1024x601     TFT
HDMI
&USB
Capacitive     ×      ×  √  ×
7 Inch TFT Display for Raspberry Pi B+ Banana Pi BB BLACK   800x480     TFT
HDMI
&USB
Capacitive     ×      ×  √  ×
RR070 7 Inch 1024x600 HDMI/VGA/AV Display for Raspberry Pi B/B+/2B/3B/4B  1024x600     TFT
HDMI
&VGA
&AV
7 Inch 800x480 TFT Display for Raspberry Pi B+ Pcduino Banana Pi   800x480     TFT
HDMI
&USB
Capacitive     ×      ×  ×  ×
8
inch
SH080 8 Inch Mini HDMI Portable LCD Display 1280x800 Resolution Monitor Built in Speakers  1024x600     IPS
HDMI
&USB
     × Earphone & Speaker      ×  ×  ×
10.1
inch
SF101T 10.1 Inch Touchscreen 1920x1080 IPS Monitor for Raspberry Pi  1920x1080  IPS
HDMI
&VGA
 Capacitive Earphone & Speaker   ×  ×   √
ELECROW SQ101 10.1 Inch 2K IPS 2560x1600 Monitor with Built-in Speaker for Raspberry Pi PS4 XBOX Windows  2560x1600  IPS
HDMI
&USB
 × Earphone & Speaker   ×   ×  √
Elecrow SF101 10.1 Inch 1920x1080 Display HDMI VGA IPS PS3 PS4 Gaming Screen with Build-In Speakers for Raspberry Pi/ XBOX/ Windows 7/8/10  1920x1080  IPS
HDMI
&VGA
 × Speaker   ×  ×   √
Elecrow RR101 10.1 Inch 1280x800 Portable Monitor Metal Shell IPS Screen with Touch Function for Raspberry Pi All-In-One PC  1280x800  IPS
HDMI
&VGA
&USB
&AV
&BNC
SF101R 10.1 Inch Portable HD Display for Raspberry Pi 3  1024x600  IPS
HDMI
&USB
&VGA
&TV
&AV
11.6
inch
SF116 11.6 Inch 1920x1080 HDMI 1080P LED Display for Raspberry Pi  1920x1080  TFT
HDMI
&VGA
 × Speaker   ×   ×  √
13.3
inch
Elecrow MQ133 13.3 Inch 2K IPS 2560x1440 HD Display Dual Mini HDMI Port for Laptop PC PS4 WiiU Xbox Raspberry Pi 4B/3B+/3B  2560x1440  IPS
Dual HDMI
&USB
ELECROW SF133 13.3 Inch IPS 1920X1080 Monitor Dual HDMI PortablePS3 PS4 Gaming Screen with Build-In Speakers for Raspberry Pi/ XBOX/ Windows 7/8/10  1920x1080  IPS
Dual HDMI
&USB
SF133M 13.3 inch 1920 x 1080 HDMI Portable Display for Raspberry Pi/ PS4/ XBOX/ NS  1920x1080  IPS
Dual HDMI
&Type-C
15.6
inch
15.6" Touchscreen Portable Monitor 1920x1080 HDMI with Laptop Stand  1920x1080  IPS
HDMI
&USB
 Capacitive Speaker  ×   ×  √
13.3
inch
CrowVi VF133 HD 1920x1080 13.3 Inch IPS Portable Monitor (non touchscreen)  1920x1080  IPS
HDMI
&Type-C
CrowVi VF133T 13.3 Inch Display 1920x1080 HD IPS Portable Monitor with Touchscreen  1920x1080  IPS
HDMI
&Type-C
15.6
inch
CrowVi VF156 15.6 Inch Display 1920x1080 HD IPS Portable Monitor (non touchscreen)  1920x1080  IPS
HDMI
&Type-C
CrowVi VF156T 15.6 Inch 1920x1080 HD Display IPS Portable Monitor with Touchscreen  1920x1080  IPS
HDMI
&Type-C
MF156C 15.6 Inch 1080P IPS 1920 x 1080 Portable Monitor Full HD USB Type C HDMI Display with Smart Cover  1920x1080  IPS
HDMI/Type-C
If you have any questions about Raspberry Pi Touchscreen, please visit our official forum:https://forum.elecrow.com/
For more information, please visit: www.elecrow.com
Media Contact:
Tammy
Elecrow
Elecrow, West of F-building 8th Floor,
Fusen Industry Park ,Gushu Hangcheng Road, Bao'an Ave
Shenzhen, 518126, China
Email: pr.manager@elecrow.com
← Previous Next →
