Kota Morishita
E-paper Weather station - Weather Crow
Weather Crow is an ESP32-S3 based weather station featuring an E-paper display that shows current weather conditions and forecasts. This initial release provides a complete solution for monitoring local weather with minimal power consumption through efficient deep sleep cycles. the project is under the MIT license, so you can modify or chage as you want!!
This weather station displays real-time weather data, forecasts, and temperature trends on a 5.79-inch e-paper display. It features adaptive highlighting of key weather metrics, power-efficient deep sleep mode, and user-configurable parameters. The project requires an OpenWeatherMap API key, WiFi credentials, and location coordinates.
Key Features
  • Real-time Weather Data: Displays current temperature, humidity, pressure, and weather conditions
  • Weather Forecast: Shows upcoming weather forecast with icons and temperatures
  • Temperature Graph: Visual representation of temperature trends over the next 24 hours
  • Adaptive Display: Automatically highlights significant weather metrics (UVI when high, precipitation when present, wind speed when significant)
  • Pixel perfection: Carefully rendering a font creates a beautiful appearance.
  • Power Efficient: Utilizes deep sleep functionality to maximize battery life
  • Configurable Refresh: Weather data updates at user-defined intervals
  • Error Recovery: Automatic retry mechanism if API calls or connectivity fail
Requirements
How to install
  1. Connect your ESP32-S3 device via USB
  2. Click the Install Weather Crow button above
  3. Select the serial port for your device(e.g. USB Serial)
  4. Wait for the installation to complete (about 2 minutes)
  5. Your device will restart and start the WiFi setup
  • GitHub
    https://github.com/kotamorishi/weather-crow5.7
12.3k
35
5
  • Comments( 5 )
  • Like( 35 )
  • Cool project, can you share the link to the case you printed?
    Jul 24,2025 2 comments
    • Daniel Pettus 2026-01-06 21:20:15
      Seconded! I prefer this one over the one on thingiverse.
      Reply
    • Kota Morishita 2026-02-07 12:00:25
      Sorry for late reply, you can download STL file from here STL https://makerworld.com/en/models/1739544-5-79inch-e-paper-weather-station-stand
      Reply
    Reply
  • that's amazing
    Sep 08,2025 0 comments
    Reply
  • Cool project.
    Sep 12,2025 0 comments
    Reply
