Ankur Majumdar
Mentor Mitra AI: Interactive Toy with Voice and Emotions
Mentor Mitra AI is a smart educational toy with a custom ATmega328P PCB that integrates the AI Thinker VC02 chip,temperature sensing, interactive voice features, and a web dashboard for personalized learning insights.
  • TP4056 TypeC Battery Charging Module
    X 1 fenxiang
  • Buck Converter Module
  • Battery, 3.7 V
  • 40mm Mini Speaker 2w 8ohm
  • VC-02 Module
    AI-Thinker
    X 1 fenxiang
  • Blender
  • Kicad
  • Autodesk Fusion 360
  • VC 02 - SDK Generator
    AI Thinker
Mentor Mitra AI is an interactive educational toy designed to assist and engage children through voice-based interaction, emotional response, and adaptive learning. Built on a custom-designed PCB using ATmega328P, and integrated with the AI Thinker VC02 module, this toy can detect environmental inputs, interact with children using speech, and share progress data to a custom React + Node.js web dashboard for parents or teachers to monitor learning milestones.
This project blends embedded system design, AI communication, and educational psychology to offer a meaningful learning companion for kids — while promoting STEM concepts to students and hobbyists.
⚙️ How does it work?🔧 1. Hardware System
  • Microcontroller: ATmega328P (on a custom PCB)
  • Modules Used:
    • AI Thinker VC02 for voice-to-AI processing
    • 1.3” OLED Display for feedback display
    • Touch & Sound Sensors for user input
    • RGB LED and Servo Motor for expressive response
    • Temperature Sensor (e.g., DHT11 or LM35)
  • Power Regulation: 5V regulated using MP3608 step-down or USB
🧠 2. AI Communication
  • VC02 sends user voice input to a hosted AI model (e.g., via Gemini API)
  • AI generates intelligent text output based on context
  • ESP32 parses the AI output and sends commands to ATmega328P for action (e.g., move servo, show emotion on LED, say something)
🌐 3. Web Dashboard
  • Built using React.js (Frontend) and Node.js (Backend)
  • Displays:
    • Child interaction history
    • Emotions detected
    • Learning progress
  • Data sent from ESP32 to server via Wi-Fi and displayed live
🔨 Step-by-Step Tutorials to Build Mentor Mitra AI
Step 1: PCB Design (EasyEDA)
  • Design schematic using ATmega328P, headers for VC02, OLED, sensors, and power regulation
  • Generate and order PCB & assemble components
  • Step 2: Module Wiring
    • Connect VC02 via UART
    • I2C for OLED + sensors
    • PWM for servo + digital pins for touch/sound
  • Step 3: Integrate AI Thinker VC02
  • Using The SDK Builder made the custom SDK and Firmware file for the Voice thinker , used the link given in the software part to make your's .
  • Step 4: Web Dashboard Setup
    • Build React frontend with charts and logs
    • Setup Node.js backend with REST API
    • Connect ESP32 via POST requests to the backend
      Step 5: Final Assembly
      • 3D-print or build casing
      • Combine electronics and mount inside
      • Step 6: Testing and Calibration
        • Test all inputs, refine voice output timing, LED reaction, and data accuracy
        • Testing and Calibration Refer this Video https://drive.google.com/file/d/1AEFEz5XWi5ajWzWyZAeG_wYVmIOZi15E/view?usp=drive_link
        • Step 7: Also made a Custom Chat bot on Poe -
          • Refer here - https://poe.com/mentor_mitra_ai
            Step 8: Programming ATmega328P
            • Write firmware using Arduino IDE or PlatformIO
            • Control servo, display text, LEDs, and process input
              #include <DS18B20_INT.h>
              #include <Servo.h>
              Servo servo1;
              Servo servo2;
              const int redPin = 6;
              const int greenPin = 7;
              const int bluePin = 8;
              const int soundPin = 12;
                servo1.attach(9);
                servo2.attach(10);
                randomSeed(analogRead(A0));
                pinMode(redPin, OUTPUT);
                pinMode(greenPin, OUTPUT);
                pinMode(bluePin, OUTPUT);
                pinMode(soundPin, INPUT);
                // Read sound sensor
                int soundDetected = digitalRead(soundPin);
                if (soundDetected == LOW) {
                  Serial.println("Sound Detected");
                  unsigned long startTime = millis();
                  while (millis() - startTime < 2000) {
                    // Generate random angles for the servos
                    int angle1 = random(0, 181);
                    int angle2 = random(0, 181);
                    // Move each servo to a random angle
                    servo1.write(angle1);
                    servo2.write(angle2);
                    int color = random(0, 3);
                    switch (color) {
                      case 0:  // Red
                        digitalWrite(redPin, HIGH);
                        digitalWrite(greenPin, LOW);
                        digitalWrite(bluePin, LOW);
                        break;
                      case 1:  // Green
                        digitalWrite(redPin, LOW);
                        digitalWrite(greenPin, HIGH);
                        break;
                      case 2:  // Blue
                        digitalWrite(bluePin, HIGH);
                        break;
                    delay(500);
                } else {
              #include <OneWire.h>
              #include <DallasTemperature.h>
              #include <DHT.h>
              #include <SPI.h>
              #include <Wire.h>
              #include <Adafruit_GFX.h>
              #include <Adafruit_SH110X.h>
              #define i2c_Address 0x3c
              unsigned int receivedValue = 0;
              #define SCREEN_WIDTH 128 // OLED display width, in pixels
              #define SCREEN_HEIGHT 64 // OLED dispay height, in pixels
              #define OLED_RESET -1
              Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
              #include <FluxGarage_RoboEyes.h>
              roboEyes roboEyes; // create RoboEyes instance
              void setup()   {
                delay(250); // wait for the OLED to power up
                display.begin(i2c_Address, true); // Address 0x3C default
                // Startup robo eyes
                roboEyes.begin(SCREEN_WIDTH, SCREEN_HEIGHT, 100); // screen-width, screen-height, max framerate
                // Define some automated eyes behaviour
                roboEyes.setAutoblinker(ON, 3, 2);
                pinMode(9, INPUT);
                pinMode(10, INPUT);
                pinMode(11, INPUT);
                pinMode(12, INPUT);
                pinMode(8, INPUT);//sound sensor
              } // end of setup
               roboEyes.update();
               roboEyes.setMood(DEFAULT);
               roboEyes.setCuriosity(OFF);
               roboEyes.setAutoblinker(ON);
               roboEyes.setWidth(36, 36);
               roboEyes.setHeight(36, 36);
               roboEyes.setBorderradius(8, 8);
               roboEyes.setSpacebetween(10);
                if (digitalRead(8) == LOW) {
                  int starTime = 0;
                  while (starTime < 50) {
                  roboEyes.setWidth(20, 20);
                  roboEyes.setSpacebetween(20);
                  starTime++;
                  roboEyes.update();
                  Serial.println("Sound Detected!");
                if (digitalRead(9) == HIGH) {
                  Serial.println("Sensor on pin 8 touched");
                  roboEyes.setMood(TIRED);
                if (digitalRead(10) == HIGH) {
                  Serial.println("Sensor on pin 9 touched");
                  roboEyes.setMood(HAPPY);
                if (digitalRead(11) == HIGH) {
                  Serial.println("Sensor on pin 10 touched");
                  roboEyes.setMood(ANGRY);
                if (digitalRead(12) == HIGH) {
                  Serial.println("Sensor on pin 11 touched");
                  roboEyes.anim_laugh();
          🎯 Why this project matters
          This project makes AI approachable, embedded design exciting, and education fun. With open documentation, low-cost components, and step-by-step guidance, it encourages:
          • Kids to learn with joy
          • Students to build real-world systems
          • Educators to adopt AI-driven feedback
          It’s not just a toy—it’s a platform to introduce AI, electronics, and empathy into learning.
          🙌 What others can learn from your experience
          • How to prototype complex systems step by step
          • Building and flashing a custom PCB with microcontrollers
          • Integrating cloud AI in embedded systems (ESP32 + VC02)
          • Designing dashboards with real-time data updates
          • Creating impactful educational technology from scratch
  • Codes
    codes_20001374846851f2704d6a6.zip
    Download(3)
  • Custom Firmware for VC02
    cdactwo_-_Copy_6139265256852bef8f00c8.zip
    Download(3)
  • Eye Code
    Download(4)
  • Arm Code
    Download(3)
  • Gerber Files For PCB
    Gerber_final-interactive_PCB_final-interactive_2025-01-30_14237638866851f1dc09a51.zip
    Download(9)
  • Gerber Files
    Gerber_Final-PCB_PCB_Final-PCB_2025-01-29_12849232616851f202a1ae3.zip
    Download(3)
6.3k
16
8
  • Comments( 8 )
  • Like( 16 )
  • Incredible work! Loved how you brought emotions into an educational toy.
    Jul 05,2025 1 comments
    Reply
  • Loved the attention to both technical depth and emotional intelligence.
    Jul 05,2025 0 comments
    Reply
  • Guys Checkout the tutorial as well - https://drive.google.com/file/d/1AEFEz5XWi5ajWzWyZAeG_wYVmIOZi15E/view?usp=drive_link
    Jul 08,2025 0 comments
    Reply
  • "Absolutely amazing work! Your dedication and creativity truly shine through — keep it up!"
    Jul 08,2025 1 comments
    Reply
  • I’m blown away by how seamlessly you integrated voice and emotions into a toy! It’s not just tech. It’s storytelling through engineering.
    Jul 09,2025 1 comments
    Reply
