Vladimir Todorov
  • 6 Projects
  • 3 Followers
  • Dec 05,2025
PCB Reverse enginnering : 4 layers
PCB Reverse enginnering - 4 layers
After successfully reverse engineering a two-layer board, I wondered: can I do the same with a four-layer board?
I chose a four-layer board with larger components: SMD resistors and SMD capacitors no smaller than 0805.
The board is automotive-grade: for AdBlue pump control.
For this project, I used Sprint Layout 6.0 — I didn't use Inkscape for the design.
Unfortunately, so far I haven't been able to locate the files I created with Sprint Layout 6.0.
I'm attaching photos. The board is 4-layer and quite thick: it took quite a bit of sanding to reach the inner layers.
Layer 1 - TOP , with components.
Layer 1 - TOP , with components and  with the component designations.
Layer 1 - TOP , without components.
Layer 1 - TOP ,  with the component designations.
Layer 2 - Inner layer.
Layer 3 - Inner layer.
Layer 4 - BOT , with components.
Layer 4 - BOT , with components and  with the component designations.
Layer 4 - BOT , without components.
Layer 4 - BOT ,  with the component designations.
Components : TOP and BOT .
Components : TOP and BOT + component designations.
Components : TOP and BOT , wthout picture : component designations.
Next project will be 4 layers pcb with 0402 compоnents and drawn layers on SVG format.
  • PICTURES TOP , PICTURES BOT + component designations
    TOP_BOT_component_designations_9389751016935a63002ce4.zip
    Download(1)
599
5
  • Like( 5 )
