2.8-inch IPS SPI LCD Capacitive Touch Display Module With ILI9341 Driver - 240x320 Resolution, Arduino Compatible
This 2.8-inch I**PS SPI module** uses the ILI9341 driver chip, has a 240x320 resolution and 65K color display, and has rich and delicate colors. It uses an IPS full-viewing angle panel to provide excellent viewing angles, and can maintain clear visual effects no matter which direction you look at it. Capacitive touch, sensitive response, and more convenient interaction. Onboard level conversion circuit, compatible with 5V and 3.3V MCU, easily adaptable to various microcontrollers. Adopting a 4-wire SPI serial bus effectively saves I/O pin resources and simplifies hardware design. The input interface supports 2.54 pin headers and FPC extension interfaces, which are flexible and diverse. It comes with a micro TF card slot for easy expansion of storage space and storage of large amounts of data.
We provide underlying driver technology support to ensure a smooth development process. Whether it is smart hardware development or industrial automation applications, this module is your ideal choice.
Customized requests can be discussed(based on MOQ), you can contact us at service@elecrow.com
Model DLS29028B
2.8inch_spi_capacitive_touch_module
  • 2.8-inch color screen, 240x320 resolution, 65K colors, rich display colors
  • IPS full-view panel, good viewing angle
  • Capacitive touch, sensitive response
  • Onboard level conversion circuit, compatible with 5V and 3.3V MCU
  • 4-wire SPI serial bus, saving I/O pins
  • Module input supports 2.54 pin header interface and FPC extension interface
  • On board micro TF card slot, can expand more storage space
  • Provide underlying driver technology support, easy to get started
Hardware Overview
the_backside_of_2.8inch_SPI_Capacitive_touch_module
Pin Function Description
Number Pin Label Description
1 VCC Power positive
2 GND Power ground
3 LCD_CS LCD selection control signal, Low level active
4 LCD_RST LCD reset control signal, Low level reset
5 LCD_RS LCD command / data selection control signalHigh level: data, low level: command
6 SDI(MOSI) SPI bus write data signal(SD card and LCD screen used together)
7 SCK SPI bus clock signal(SD card and LCD screen used together)
8 LED LCD backlight control signal (If you need control, please connect the pins. If you don't need control, you can skip it)
9 SDO(MISO) SPI bus read data signal (SD card and LCD screen used together)
10 CTP_SCL Capacitive touch screen IIC bus clock signal (modules without touch screens do not need to be connected)
11 CTP_RST Capacitor touch screen reset control signal, low-level reset (modules without touch screens do not need to be connected)
12 CTP_SDA Capacitive touch screen IIC bus data signal (modules without touch screens do not need to be connected)
13 CTP_INT Capacitor touch screen IIC bus touch interrupt signal, when generating touch, input low level to the main control (modules without touch screens do not need to be connected)
14 SD_CS SD card selection control signal, low level active (without SD card function, can be disconnected)
LCD Screen
Size 2.8 inch
Screen Type IPS
Resolution 240xRGBx320 (pixels)
Number of Colors(Max) 262K
Driver IC ILI9341V
Interface 4-wire SPI interface
Brightness(TYP) 280(cd/m2)
Backlight Type White LED*4
Operating Temperature -30℃~80℃
Storage Temperature -30℃~80℃
Touch Screen
Touch Screen Type Capacitive Touch Screen
Driver IC FT6336G
Communication Interface IIC
Operation Temperature -20~70(℃)
Storage Temperature -30~80(℃)
Other
Working Voltage 5V
Backlight Current 80mA
Power 0.4w
Interface 14P 2.54mm spacing Header and 0.5mm spacing FPC seat
Active Area 43.2x57.6(mm)
Module Size 50x86(mm)
Resources
How to buy
Please visit this page to purchase 2.8 ips spi lcd capacitive touch module.
Support
