26-in-1_Learning_Kit_for_Arduino_UNO_R4_with_26_lessons_Support_WiFi_and_BLE
1. Product Overview
This kit is an Arduino learning kit designed specifically for beginners with no prior experience. Based on the Arduino UNO R4 WiFi development board, it integrates 26 sensors/modules + 26 lesson experiments to help users gradually master the fundamentals of electronics and programming.
  • Supports WiFi + BLE (Bluetooth Low Energy)
  • Step-by-step learning progression: from basic LEDs → sensors → displays → motor control → IoT applications
  • Suitable for: students / makers / teachers / beginners
SEA00904D
all-in-one_starter_kit_for_arduino_uno_r4
2. Introduction to the Arduino UNO R4 WiFi
The Arduino UNO R4 WiFi is a next-generation Arduino development board. Its key features include:
- 32-bit ARM Cortex-M4
- Clock speed: 48 MHz
- Built-in ESP32-S3 (supports Wi-Fi + BLE)
- USB-C port
- Supports DAC / CAN bus
In a nutshell: More powerful than traditional Arduinos + Internet-enabled
Arduino_UNO_R4
3. List of Sensors
Sensor / Module Classification Table
No. Product Name Module Type
1 Red Button Input
2 Green Button Input
3 Yellow Button Input
4 Switch Input
5 Light Sensor I2C
6 Sound Sensor Input
7 PIR Motion Sensor Input
8 Water Sensor Input
9 Soil Moisture Sensor Input
10 MQ2 Gas Sensor Input
11 Flame Sensor Input
12 3-Axis Accelerometer I2C
13 Temperature & Humidity Sensor I2C
14 Ultrasonic Ranging Sensor Input
15 IR Receiver Input
16 Linear Potentiometer Input
17 Red LED Output
18 Green LED Output
19 Yellow LED Output
20 Buzzer Output
21 Relay Module Output
22 4-Digit Display I2C
23 I2C LCD Display I2C
24 Servo Motor Output
25 Stepper Motor Output
4. Quick Start Guide
Step 1: Install the Main Board
Installing the Main Board
First, insert the Arduino Uno R4 main board into the development board from the back. Before inserting it, make sure all pins are properly aligned. The development board clearly labels the pin locations corresponding to the Arduino Uno R4, making it easy to connect all components correctly.
Arduino_UNO_R4-1
Step 2:Download_Arduino_IDE
Please click the card below to learn how to install Arduino IDE.
Installing the Uno R4 Development Board
① Click the development board icon on the left
② Type "uno r4" in the search bar
③ Select version 1.5.1. You can try other versions, but if uploading the code fails, switch back to 1.5.1. This tutorial's code was developed using version 1.5.1.
④ Click "INSTALL" to install
Arduino_UNO_R4-2
During the installation, a window will pop up-just click"Yes".
Step 3:Add library
Please click to download download the library files we have provided.
SLS-UI-36
Upload Steps (Important) In all following lessons, the upload steps are the same. Please read carefully, and if you forget, you can return here and follow the steps: 1. Connect the Type-C upload port to your computer
Arduino_UNO_R4-3
After writing the code, select the board you want to upload to: "Tools"->"Board"->"Arduino UNO R4 Boards"->"Arduino Uno R4 WiFi"
Arduino_UNO_R4-4
For more information on how to use this product and for further guidance, please refer to the user manual:
User_Manual_for_21-in-1_Learning_Kit_for_Arduino_UNO_R4.pdf
Resources
Github link:
(This GitHub link usually may contain single module example,lesson_code,libraries. Please click to view.)
How to buy
Please visit this page to purchase 26-in-1-learning-kit-for-arduino-uno-r4.
Support
