3.5-inch IPS SPI LCD Capacitive Touch Display Module With ST7796 Driver - 320x480 Resolution, Arduino Compatible
This 3.5-inch IPS SPI module, equipped with ST7796 driver chip, presents you with 320x480 resolution and 16.7M color delicate display, whether it is images or text, it can be presented in rich and delicate colors. The IPS panel ensures that you can enjoy a clear and color-free visual experience from any angle. Capacitive touch technology makes interactive operation easy. Onboard level conversion circuit, compatible with 5V and 3.3V MCU. 4-wire SPI serial bus design effectively saves I/O pin resources and simplifies hardware design. The input interface provides two options of 2.54 pin header and FPC extension interface to meet the connection requirements in different scenarios. It comes with a micro TF card slot, and it can provide great convenience for your data storage needs.
Whether you are engaged in intelligent hardware development or industrial automation applications, this module can provide you with a stable, efficient and convenient display solution, and is an ideal choice for your project development.
Customized requests can be discussed(based on MOQ), you can contact us at service@elecrow.com
Model DLS30035B
3.5inch_spi_capacitive_touch_module
  • 3.5-inch color screen, 320x480 resolution, 65K colors, rich display colors
  • Capacitive touch, sensitive response
  • IPS full-view panel, good viewing angle
  • Onboard level conversion circuit, compatible with 5V and 3.3V MCU
  • 4-wire SPI serial bus, saving I/O pins
  • Module input supports 2.54 pin header interface and FPC extension interface
  • On board micro TF card slot, can expand more storage space
  • Provide underlying driver technology support, easy to get started
Hardware Overview
the_backside_of_3.5inch_spi_capacitive_touch_module
Pin Function Description
Number Pin Label Description
1 VCC Power positive
2 GND Power ground
3 LCD_CS LCD selection control signal, Low level active
4 LCD_RST LCD reset control signal, Low level reset
5 LCD_RS LCD command / data selection control signalHigh level: data, low level: command
6 SDI(MOSI) SPI bus write data signal(SD card and LCD screen used together)
7 SCK SPI bus clock signal(SD card and LCD screen used together)
8 LED LCD backlight control signal (If you need control, please connect the pins. If you don't need control, you can skip it)
9 SDO(MISO) SPI bus read data signal (SD card and LCD screen used together)
10 CTP_SCL Capacitive touch screen IIC bus clock signal (modules without touch screens do not need to be connected)
11 CTP_RST Capacitor touch screen reset control signal, low-level reset (modules without touch screens do not need to be connected)
12 CTP_SDA Capacitive touch screen IIC bus data signal (modules without touch screens do not need to be connected)
13 CTP_INT Capacitor touch screen IIC bus touch interrupt signal, when generating touch, input low level to the main control (modules without touch screens do not need to be connected)
14 SD_CS SD card selection control signal, low level active (without SD card function, can be disconnected)
LCD Screen
Size 3.5 inch
Screen Type IPS
Resolution 320xRGBx480 (pixels)
Number of Colors(Max) 16.7M
Driver IC ST7796U
Interface 4-wire SPI interface
Brightness(TYP) 300(cd/m2)
Backlight Type White LED*6
Operating Temperature -30℃~80℃
Storage Temperature -30℃~80℃
Touch Screen
Touch Screen Type Capacitive Touch Screen
Driver IC FT6336U
Communication Interface IIC
Operation Temperature -20~70(℃)
Storage Temperature -30~80(℃)
Other
Working Voltage 5V
Backlight Current 95mA
Power 0.5w
Interface 14P 2.54mm spacing Header and 0.5mm spacing FPC seat
Active Area 48.96x73.44(mm)
Module Size 55.5x98x14.28(mm)
Resources
How to buy
Please visit this page to purchase 3.5 ips spi lcd capacitive touch module.
Support
