4.3-inch ESP32 Dispaly PlatformIO Tutorial¶
Overview¶
This example tutorial is a project for controlling the on and off of an LED. It demonstrates how to create a UI and how to control the on and off of an LED through buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to build a project on PlatformIO.
Hardware Preparation¶
CrowPanel ESP32 4.3'' HMI | Crowtail-DHT20 | Crowtail-LED |
Note:
Set the name of the project, set the screen resolution to 480*272, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
to download the custom images used in this tutorial.
Note:
Images only support webp format. The pixels of the image need to be smaller than the pixel size of the screen used in your project. The size of each image should not exceed 100k, preferably within 30k, to provide a smooth display effect.
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Modify the button event code.
First, define a 'extern int led;' in the ui.h file to store the status of the LED. The value of this variable is judged to control the on and off of the LED.
The UI file export is completed, and the button event function is also modified. Next we're going to learn about how to create a PlatformIO project.
Create PlatformIO Project¶
Please click to download complete PlatformIO project that can be compiled and run directly.
Now let's explore how to build this project step by step!
Get Started with PlatformIO¶
Please click the card below to enter the page to get started with PlatformIO.
Create a new project¶
Place the esp32-s3-devkitc-1-myboard.json to the directory in the following picture:
Please click
to download the esp32-s3-devkitc-1-myboard.json.
Open Visual Studio Code, click the PlatformIO icon, click QUIK ACCESS 'Open', then click '+New Project'.
Add a project name "CrowPanel_ESP32_4.3". Select "Espressif ESP32-S3-DevKitC-1-N8 -ELECROW" for the board and Arduino for the framework.
Add the following code to the platformio.ini file
Write the main program in main.cpp.
Add Libraries¶
Click the PlatformIO icon, click QUIK ACCESS 'Open', then click 'Libraries'.
Search for LVGL, and add it to the project.
After adding, right click on lvgl and select "Open in Integrated Terminal"
Copy the "demos" and "examples" folders to "src" folder
Place the lv_conf.h we provide to the path: .pio\libdeps\esp32-s3-devkitc-1-myboard in the project folder.
Add XPT2046
Add GFX Library for Arduino
We can see that the library has been added successfully!
Add the UI file into PlatformIO Project¶
We need to add the UI file (generated from SquareLine Studio) to the PlatformIO project.
The .c file in the UI file should be placed in the /scr folder of the project file, and the .h files should be placed in the /include folder.
Upload the Code¶
Compile the program.
Select the serial port and upload the code.
Here we select Auto. The software will automatically select the corresponding serial port for program download. If the automatically selected serial port is incorrect, you can manually select the correct serial port.
Click the upload button to up the program to the board.
The program will run on the board!
