2 Introduce the screen user interface and external speakers for playing songs
Welcome to the second lesson of learning. I believe that after completing the first lesson, everyone has gained a deeper understanding of our product. Next, I will lead you to the first application case of the Advance series products - connecting to WiFi to play songs.
1 Product Interface Introduction
The following interface was generated by introducing the official firmware of LVGL, and the specific operation will not be explained in this lesson for now. In the next class, we will mainly explain the LVGL graphics library. You can follow our updates to facilitate your learning.
3
4
2 Select a match code for the screen
The code D: CrowPanel Advance HMI Course code under this path is the functional code we provide for all sizes in this lesson. Everyone can choose the appropriate code according to the size you are using.
5
6
Here, I will introduce a product with a size of 7.0 as an example
(2.4-inch, 2.8-inch, 3.5-inch using OnlineAudio (small))
(3.5-inch, 5.0-inch, 7.0-inch using OnlineAudio (Largel))
7
2.1 Using Arduino IDE to Open Code
8
2.2 Code Introduction
You can understand the overall code based on the comments after each line of code.
(If you want to have a deeper understanding of code construction, you can go watch a video explanation.)
9
3 Configure library file
3.1 Select the appropriate library file based on the product screen size
10
3.2 I will use the Advance 7.0-inch product as an example for operation
11
12
13
14
4 How to play the song we want to play
Principle:
After the CrowPanel ESP32 Advance HMI is connected to WIFI, it will search for this song through the URL link provided in our code and achieve network playback (this is an external link for a song)
15
Note: The audio stream encoding formats supported by the parameters of the audio.connecttohost function, such as MP3, AAC, FLAC, etc
The reason why people do not use familiar music websites such as Spotify, Apple Music, and YouTube Music to play songs is because most legitimate music streaming services only provide song page links or embedded player code to play music. To protect copyright, not providing direct download links in MP3 format, distributing or obtaining MP3 download links directly may violate the terms of service and copyright laws of these platforms. So we didn't use it. We use Chinese music websites to play music here. If you want to use a music website that you are familiar with, just find a URL link in MP3 format similar to the one in the code and replace it.
First, connect our speakers
16
In NetEase Cloud Music or other music platforms, the ID of a song is usually a unique identifier for each song. So the main thing is to replace the ID number in the URL link in the code
17
Next, I will use NetEase Cloud Music as an example to introduce, searching for an ID number
Use a browser to search for NetEase Cloud Music and open it
18
Play the song you want to listen to
19
Retrieve the ID number from the link and replace it with the ID number in the code
20
This way, you can change the music you want to play. (Remember to re burn the program after changing the ID)
Tips:
1. If the program runs without errors but the song doesn't play, you should check the URL to ensure that the provided link is correct.
2. If the song you want to play is a VIP song, it cannot be played.
3. Before burning the code, remember to configure the environment in which the code will run.
Be careful:
For large-sized products, 4.3 inches, 5.0 inches, 7.0 inches.
Before burning the code, be sure to set the switch on the back of the product to MIC&SPK mode.
20-1
5 How to adjust the size of the sound output from the speaker
When an external speaker is connected, this is the power consumption that our built-in amplifier chip can provide
21
5.1 The volume can be adjusted by adjusting the knob
22
5.2 Adjustment principle
Open the schematic diagram we provide
23
By changing the resistance of the R51 adjustable resistor, the volume can be adjusted.
24
6 Code presentation
6.1 OnlineAudio_large
#include <Wire.h>
#include "Arduino.h"
#include "WiFiMulti.h"
#include "Audio.h"
#include "TCA9534.h"
#define I2S_DOUT 4
#define I2S_BCLK 5
#define I2S_LRC 6
Audio audio;
WiFiMulti wifiMulti;
TCA9534 ioex;
String ssid = "yanfa1";
String password = "1223334444yanfa";
  Serial.begin(115200);
  Wire.begin(15, 16);
  delay(50);
  ioex.attach(Wire);
  ioex.setDeviceAddress(0x18);
  ioex.config(3, TCA9534::Config::OUT);
  ioex.config(4, TCA9534::Config::OUT);
  ioex.output(3, TCA9534::Level::L);
  ioex.output(4, TCA9534::Level::H);
  Serial.printf("[LINE--%d]\n", __LINE__);
  WiFi.mode(WIFI_STA);
  wifiMulti.addAP(ssid.c_str(), password.c_str());
  wifiMulti.run();
  if (WiFi.status() != WL_CONNECTED) {
    WiFi.disconnect(true);
    wifiMulti.run();
  Serial.println("--- WIFI_CONNECTED ---");
  audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
  audio.setVolume(20);  // 0...21
  ioex.output(4, TCA9534::Level::L);
  //  audio.connecttoFS(SD, "/320k_test.mp3");
  //  audio.connecttoFS(SD, "test.wav");
  // Choose the URL of the music you want to play
  // This is Taylor Swift singing 'Last Christmas'
  audio.connecttohost("http://music.163.com/song/media/outer/url?id=1405259103.mp3"); // Last Christmas.mp3
  // audio.connecttohost("http://music.163.com/song/media/outer/url?id=5103312.mp3"); // Empire state of mine.mp3
  Serial.printf("[LINE--%d]\t ready to play!!\n", __LINE__);
  audio.loop();
  if (Serial.available()) {  // put streamURL in serial monitor
    audio.stopSong();
    String r = Serial.readString();
    r.trim();
    if (r.length() > 5) audio.connecttohost(r.c_str());
    log_i("free heap=%i", ESP.getFreeHeap());
new-1
new-2
new-3
new-4
new-5
new-6
