CrowPanel ESP32 E-Paper 5.79-inch Arduino Tutorial
Overall
This tutorial will demonstrate how to use ESP32 E-Paper Display as a price tags and update price images through WiFi and Bluetooth. And how to obtain weather information and display it on ESP32 E-paper display. In addition, there are simple examples to illustrate how to use the various interfaces on the board.
Get Started with Arduino IDE
Demo 1 Update Pictures Wireless
This demo will introduce how to wireless update a single price tag through WiFi and Bluetooth.
Update via WiFi
wifi-flow
Convert the image format
First, let's take a look at the price tag we design in this example, which is divided into three parts(all are images). The top bar is a fixed and unchanging background. On the left is the description, and on the right is the price. The parts we need to update are the description and price.
price-tag
For the fixed top bar, we can convert it to C array and put them in the code.
For the variable description and price, we need to convert them to bin file and upload them to the board through WiFi.
  1. downloadthe price tag pictures.
    pictures
  2. download the image modulo tool Image2Lcd and open it.
    imagelcd
  3. Click open and select top-bar.bmp, convert it to array format.
    • Open file
    • Output date type: C language array by default
    • The biggest width and height: Consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
    • Save and output
    top-bar-array
    You can put this array in a suitable header file, and I have placed it in Ap_29demo. h here.
    bg-top-array
  4. Convert the description pictures and price tag pictures to bin files. These bin files will be used to update prices over WiFi.
    • Open the file
    • The output type select .bin file
    • The width and height should consistent with the width and height of the image. Note that it must be a multiple of 8, otherwise it cannot be displayed properly
    • Save the file
    price-bin
    description-bin
Code Explanation
Please click download to download the code file 5.79_WIFI_refresh.zip for this demo.
Add necessary libraries
#include <Arduino.h>     // Includes Arduino core library files
#include "EPD.h"         // Includes library files for electronic paper screens
#include "Ap_29demo.h"   // Includes custom function libraries
#include "FS.h"          // File system library for file operations
#include "SPIFFS.h"      // SPIFFS file system library for file reading and writing
#include <WiFi.h>        // WiFi library for creating and managing WiFi connections
#include <Ticker.h>      // Ticker library for timing operations
#include <WebServer.h>   // WebServer library for creating HTTP servers
Define the file variable fsUploadFile Used for accessing files, txt_size and pre_size correspond to the size of the BIN file(Exported in the above steps) for the text label and price label to be transmitted. The image resolution requirement is smaller than the screen resolution and both width and height are multiples of 8.
//Object for storing uploaded files
File fsUploadFile; //Used to manipulate files in the SPIFFS file system
#define txt_size 6768 // Define the size of the description picture file
#define pre_size 5888 // Define the size of the price tag picture file
Note: The size here can be defined based on the size of the images to be transmitted later, otherwise it will cause image transfer failure
Receive the bin file sent and determine if it matches the pre-set file size. If it matches, store it in the file system and update the display icon
// Handling requests to upload files
void okPage()
  server.send(200, "text/html", HTML_OK); // Successfully sent page
  HTTPUpload &upload = server.upload();    // Retrieve the uploaded file object
  // Note: The initialization size of upload.buf is only 1436 bytes and needs to be adjusted to support uploading large files
  // Modify the HTTP-UPLOAD_SUFLEN definition in the WebServer. h file to increase the initial size to 14360 bytes
  if (upload.status == UPLOAD_FILE_END) // File upload completed
    Serial.println("draw file");
    Serial.println(upload.filename);  // Print and upload file name
    Serial.println(upload.totalSize); // Total size of printed files
    // Determine the size of the uploaded file and determine the file type
    if (upload.totalSize == 6768) // If the file size is 6768 bytes, it is a txt file
      filename = "txt.bin";
    else
      filename = "pre.bin"; // Otherwise, it is a preview file
    // Save the received file
    if (!filename.startsWith("/")) filename = "/" + filename;
    fsUploadFile = SPIFFS.open(filename, FILE_WRITE); // Open file for write mode
    fsUploadFile.write(upload.buf, upload.totalSize); // Write file data
    fsUploadFile.close(); // close file
    Serial.println("保存成功");
    Serial.printf("保存:");
    Serial.println(filename);
    // Store data into the corresponding array based on file size
    if (upload.totalSize == txt_size)
      for (int i = 0; i < 6768; i++) {
        txt_formerly[i] = upload.buf[i];
      Serial.println("txt_formerly OK");
      flag_txt = 1; // Set a flag to indicate that the txt file has been uploaded
    else
      for (int i = 0; i < pre_size; i++) {
        price_formerly[i] = upload.buf[i];
      Serial.println("price_formerly OK");
      flag_pre = 1; // Set a flag to indicate that the preview file has been uploaded
    EPD_GPIOInit();            // Initialize GPIO pin configuration for EPD e-ink screen
    EPD_FastMode1Init();       // Initialize EPD screen in Quick Mode 1
    EPD_ShowPicture(0, 0, 792, 40, background_top, WHITE); // Display a background image on the screen with a white background color
    // Display corresponding images based on the type of uploaded file
    if (upload.totalSize != 6768)
        EPD_ShowPicture(500, 80, 256, 184, price_formerly, WHITE); // Display preview image
    else
        EPD_ShowPicture(30, 80, 376, 144, txt_formerly, WHITE); // Display text image
    EPD_Display(ImageBW);      // Display images stored in the ImageBW array
    EPD_FastUpdate();          // Perform quick updates to refresh the screen
    EPD_DeepSleep();          // Set the screen to deep sleep mode to save power
Image Refresh Process
  1. Initialization
    // Initialize EPD (Electronic Paper Display) screen
      EPD_GPIOInit();  // Initialize the GPIO pins of EPD
      Paint_NewImage(ImageBW, EPD_W, EPD_H, Rotation, WHITE);  // Create a new canvas with dimensions of EPD_W x EPD_H and a white background color
      Paint_Clear(WHITE);  // Clear the canvas, with a white background color
      EPD_FastMode1Init();  // Quick Mode 1 for Initialize EPD
      EPD_Display_Clear();  // Clear EPD display content
      EPD_Update();  // update display
      UI_price();  // Display price information
  2. Initialize to fast mode display screen
      EPD_GPIOInit();  // Initialize the GPIO pin configuration of the EPD e-ink screen again
      EPD_FastMode1Init();  // Re initialize the EPD screen in Quick Mode 1
  3. Select the data to refresh
  4. Update the image to the screen
Upload the Code
  1. Open the 5.79_WIFI_refresh.ino
    open-wifi-refresh
  2. Click "Tools"->"Board"->"esp32"->"ESP32S3 Dev Module", and the "Partition Scheme" select "Huge APP (3MB No OTA/1MB SPIFFS)", "PSRAM" select "OPI PSRAM".
    setting
  3. Connect CorwPanel to the computer, click on "Tool" and select the corresponding "port".
  4. Click "Upload" to upload the code to the board. There will be an image show on the screen.
    upload
Update the price tag with WiFi
  1. Connect a laptop to the hotspot of the ESP32 E-PAPER display.
  2. Enter the IP address 192.168.4.1 in the browser.
    connect-wifi
  3. Select the bin file of the picture you need to show, then click submit.
    Note: The size of the images you transfer must be consistent with the size defined in the code, otherwise it will cause image transfer failure
    bin-size
  4. After successful transmission, the price and text will be replaced, and the data will be saved in flash.
    image-refresh
Update via Bluetooth
bt-flow
The same as the method in the "Update via WiFi".
Code Explanation
Please click download to download the code file 5.79_ble_refresh.zip for this demo.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include "EPD.h"
#include "FS.h"           // File System Library
#include "SPIFFS.h"       // SPIFFS File system library, used for file reading and writing
ble_pic function
Process the bin file sent and determine if it matches the pre-set file size. If it does, store it in the file system and update the display icon.
void ble_pic()
  // Check if data has been received
  if (dataReceived) {
    // Ensure that the data buffer is not empty
    if (!dataBuffer.empty()) {
      size_t bufferSize = dataBuffer.size();
      Serial.println(bufferSize);
      if (dataBuffer.size() == txt_size)//txt size
      else
      fsUploadFile.write(dataBuffer.data(), dataBuffer.size());
      Serial.println("保存成功"); //Successfully saved
      Serial.printf("保存:"); //Save:
      if (bufferSize == txt_size )
        for (int i = 0; i < txt_size; i++) {
          txt_formerly[i] = dataBuffer[i];
        //      memcpy(txt_formerly, upload.buf, sizeof(upload.totalSize));
      } else
          price_formerly[i] = dataBuffer[i];
        //      memcpy(price_formerly, upload.buf, sizeof(upload.totalSize));
        Serial.println(" price_formerlyOK");
      EPD_ShowPicture(0, 0, 792, 40, background_top, WHITE); // Display the gImage_stcenario_home image on the screen with a white background color
      if (bufferSize != txt_size)
        EPD_ShowPicture(500, 80, 256, 184, price_formerly, WHITE); // Display the gImage_stcenario_home image on the screen with a white background color
        //         EPD_ShowPicture(400, 60, 256, 184, price_formerly, WHITE); // Display the gImage_stcenario_home image on the screen with a white background color
      } else
        EPD_ShowPicture(30, 80, 376, 144, txt_formerly, WHITE); // Display the gImage_stcenario_home image on the screen with a white background color
      // Clear the buffer after writing
      dataBuffer.clear();
      totalReceivedBytes = 0;
      // Clear data buffer
      dataBuffer.clear(); // Clear the buffer after writing
    // Reset the data reception flag after processing the data
    dataReceived = false;
// Clear the display screen content
void clear_all()
  // Initialize the quick mode of the e-ink screen
  // Clear the e-ink screen
  // Update display screen
  EPD_Update();
class MyCallbacks : public BLECharacteristicCallbacks
Receive the data sent and integrate it together. Receiving the "OK" character indicates that the transmission is complete.
// BLE Feature callback class
class MyCallbacks : public BLECharacteristicCallbacks {
    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string value = pCharacteristic->getValue();
      if (value.length() > 0) {
        Serial.printf(".");
        // Assuming that the client sends a specific end marker at the end of data transmission
        if (value == "OK") {
          dataReceived = true;
          return ;
        size_t len = value.length();
        if (len > 0) {
          // Append the received data to the buffer
          dataBuffer.insert(dataBuffer.end(), value.begin(), value.end());
          totalReceivedBytes += len; // Update the total number of bytes received
UI_price
Check if the file system has saved UI images, and if so, display them.
// User interface function: Display price information
void UI_price()
  if (SPIFFS.exists("/txt.bin")) {
    // File exists, read file content
    File file = SPIFFS.open("/txt.bin", FILE_READ);
    if (!file) {
      Serial.println("无法打开文件进行读取"); // Unable to open file for reading
      return;
    // Read data from a file to an array
    size_t bytesRead = file.read(txt_formerly, txt_size);
    Serial.println("File content:");
    while (file.available()) {
      Serial.write(file.read());
    file.close();
  if (SPIFFS.exists("/pre.bin")) {
    File file = SPIFFS.open("/pre.bin", FILE_READ);
    if (!file) {
      return;
    size_t bytesRead = file.read(price_formerly, pre_size);
    file.close();
  1. Initialization
Upload the Code
  1. Double click the 5.79_ble_refresh.ino.
    ble-refresh-ino
    setting-bt
    upload
Update the images via bluetooth
  1. Download a BLE debugging assistant to your phone, and connect it your phone to the screen device BLE.
    connect-ble
  2. Upload the bin file(Save the bin file to your phone in advance).
    upload-image-ble
    upload-image-ble-2
  3. After successful transmission, the price and text will be replaced, and the data will be saved in flash.
    image-refresh
Demo 2 Weather Station
Obtain weather information through OpenWeather and display the information on the CrowPanel.
First, let's take a look at the weather information panel we design in this example, which is divided into 6 parts(all are images).
5.79
  • weather
  • city
  • humidity
  • wind
  • temperature
  • visibility
We need to convert the images of these 6 parts into C arrays and put them in the code, and combine them to form the UI interface above. The weather icon in the upper left corner is variable, while the other icons are fixed.
  1. downloadthe icons.
    5.79-weather-icons
    imagelcd
  3. Click open and select the images, convert them to array format.
    • Open file
    • Save and output
    top-bar-array
    You can put this array in a suitable header file, and I have placed it in pic. h here.
Register an OpenWeather account
  1. Enter https://openweathermap.org/ and click "Sing in" to register an OpenWeather account.
    openweather
  2. Log in your account.
  3. Click your user name -> "My API Keys" to find your API key.
    openweather-api
Code Explanation
Please click download to download the code file 5.79_wifi_http_openweather.zip for this demo.
Add libraries
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
#include "EPD.h"
#include "pic.h"
Modify your information
const char* ssid = " ";       // Enter your ssid
const char* password = " ";     // Enter your WiFi password
// OpenWeatherMap API key
String openWeatherMapApiKey = "You-API"; //Enter your API key
// For example: String openWeatherMapApiKey = "bd939aa3d23ff33d3c8f5dd1dd435";
// Replace with city and country code you're in
String city = "London";                    // City Name
String countryCode = "2643743";            // Country Code
Country Code
You can find the country code at: http://bulk.openweathermap.org/sample/
country-code
Function Explanation
js_analysis
This function is mainly used to parse the received JSON data, process these data separately, and save them in variables.
void js_analysis()
  // Check if successfully connected to WiFi network
  if (WiFi.status() == WL_CONNECTED) {
    // Build URL for OpenWeatherMap API request
    String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey + "&units=metric";
    // Loop until a valid HTTP response code of 200 is obtained
    while (httpResponseCode != 200) {
    //Send HTTP GET request and retrieve response content
      jsonBuffer = httpGETRequest(serverPath.c_str());
      Serial.println(jsonBuffer); // Print the obtained JSON data
      myObject = JSON.parse(jsonBuffer); // Parse JSON data
      // Check if JSON parsing is successful
      if (JSON.typeof(myObject) == "undefined") {
        Serial.println("Parsing input failed!"); // Prompt message when parsing fails
        return; // If parsing fails, exit the function
      delay(2000); // Wait for 2 seconds and retry
    // Extract weather information from parsed JSON data
    weather = JSON.stringify(myObject["weather"][0]["main"]); // Weather Information
    temperature = JSON.stringify(myObject["main"]["temp"]); // temperature
    humidity = JSON.stringify(myObject["main"]["humidity"]); // humidity
    sea_level = JSON.stringify(myObject["main"]["sea_level"]); // visibility
    wind_speed = JSON.stringify(myObject["wind"]["speed"]); // wind speed
    city_js = JSON.stringify(myObject["name"]); // City Name
    // Print extracted weather information
    Serial.print("String weather: ");
    Serial.println(weather);
    Serial.print("String Temperature: ");
    Serial.println(temperature);
    Serial.print("String humidity: ");
    Serial.println(humidity);
    Serial.print("String sea_level: ");
    Serial.println(sea_level);
    Serial.print("String wind_speed: ");
    Serial.println(wind_speed);
    Serial.print("String city_js: ");
    Serial.println(city_js);
    // Set weather icon flags based on weather description
    if (weather.indexOf("clouds") != -1 || weather.indexOf("Clouds") != -1 ) {
      weather_flag = 1; // Clouds
    } else if (weather.indexOf("clear sky") != -1 || weather.indexOf("Clear sky") != -1) {
      weather_flag = 3; // Clear sky
    } else if (weather.indexOf("rain") != -1 || weather.indexOf("Rain") != -1) {
      weather_flag = 5; // rain
    } else if (weather.indexOf("thunderstorm") != -1 || weather.indexOf("Thunderstorm") != -1) {
      weather_flag = 2; // thounderstorm
    } else if (weather.indexOf("snow") != -1 || weather.indexOf("Snow") != -1) {
      weather_flag = 4; // snow
    } else if (weather.indexOf("mist") != -1 || weather.indexOf("Mist") != -1) {
      weather_flag = 0; // mist
  else {
    // If WiFi is disconnected, print a prompt message
    Serial.println("WiFi Disconnected");
// Define the function for HTTP GET requests
String httpGETRequest(const char* serverName) {
  WiFiClient client;
  HTTPClient http;
  // Initialize the HTTP client and specify the requested server URL
  http.begin(client, serverName);
  // Send HTTP GET request
  httpResponseCode = http.GET();
  // The response content returned by initialization
  String payload = "{}";
  // Check the response code and process the response content
  if (httpResponseCode > 0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode); // Print response code
    payload = http.getString(); // Obtain response content
  else {
    Serial.print("Error code: ");
    Serial.println(httpResponseCode); // Print error code
  // Release HTTP client resources
  http.end();
  return payload; // Return response content
UI_weather_forecast
Display the processed data saved in the variable on the screen.
void UI_weather_forecast()
  char buffer[40];  // Create a character array for storing information
  // Clear the image and initialize the e-ink screen
  Paint_NewImage(ImageBW, EPD_W, EPD_H, Rotation, WHITE); // Create a new image
  Paint_Clear(WHITE); // Clear image content
  EPD_FastMode1Init(); // Initialize the e-paper screen
  EPD_Display_Clear(); // Clear screen display
  EPD_Update(); // Update Screen
  EPD_Clear_R26A6H(); // Clear the electronic ink screen cache
  // display picture
  EPD_ShowPicture(0, 0, 792, 272, pic, WHITE); // Display background image
  // Display the corresponding weather icon according to the weather icon logo
  EPD_ShowPicture(4, 3, 432, 184, Weather_Num[weather_flag], WHITE);
  // Draw partition lines
  EPD_DrawLine(0, 190, 792, 190, BLACK); // Draw a horizontal line
  EPD_DrawLine(530, 0, 530, 270, BLACK); // Draw a vertical line
  // Display update time
  memset(buffer, 0, sizeof(buffer));
  snprintf(buffer, sizeof(buffer), "%s ", city_js); // Format the update time as a string
  EPD_ShowString(620, 60, buffer, 24, BLACK); // Display update time
  // Display temperature
  snprintf(buffer, sizeof(buffer), "%s C", temperature); // Format temperature as a string
  EPD_ShowString(340, 240, buffer, 24, BLACK); // Display temperature
  // Display humidity
  snprintf(buffer, sizeof(buffer), "%s ", humidity); // Format humidity as a string
  EPD_ShowString(620, 150, buffer, 24, BLACK); // Display humidity
  // Display wind speed
  snprintf(buffer, sizeof(buffer), "%s m/s", wind_speed); // Format wind speed as a string
  EPD_ShowString(135, 240, buffer, 24, BLACK); // Display wind speed
  // display visibility
  snprintf(buffer, sizeof(buffer), "%s ", sea_level); // Format visibility as a string
  EPD_ShowString(620, 240, buffer, 24, BLACK); // display visibility
  // Update the display content of the e-paper screen
  EPD_Display(ImageBW); // display image
  EPD_PartUpdate(); // Partially updated screen
  EPD_DeepSleep(); // Enter deep sleep mode
Upload the Code
  1. Double click the 5.79_wifi_http_openweather.ino.
    open-weather
    dl-op
  5. After downloading, the weather information for the city you have selected will be displayed on CrowPanel.
    weather-ui
Examples for the CrowPanel Interfaces
Please click download to download the code file for the examples.
Example 1 Control the GPIO
  1. Open the 5.79_GPIO.ino.
    #include "EPD.h"  // include header files for EPD display library, providing functionality for operating electronic paper display screens
    // Define an array for storing display images, with a size of 27200 bytes
    uint8_t ImageBW[27200];
    // Determine the status of GPIO pins and display status information on EPD
    void judgement_function(int* pin) {
      char buffer[30];  // Store the string to be displayed
      EPD_GPIOInit();  // Initialize GPIO settings for EPD display screen
      // Create a new image with a white background color
      Paint_Clear(WHITE);  // Clear the canvas with a white background color
      // Create a new image again (possibly to ensure clarity) with a white background color
      // Initialize the quick mode of EPD display
      EPD_Update();  // Update EPD display
      EPD_Clear_R26A6H();  // Clear EPD cache
      // Traverse all GPIO pins, read the status of each pin and display it on EPD
      for (int i = 0; i < 12; i++) {
        int state = digitalRead(pin[i]);  // Read the status of the specified pin (HIGH or LOW)
        if (state == HIGH) {
          // If the pin status is HIGH, format the string and display it
          int length = sprintf(buffer, "GPIO%d : on", pin[i]);
          buffer[length] = '\0';  // Ensure that the string ends with '\ 0'
          EPD_ShowString(0, 0 + i * 20, buffer, 16, BLACK);  // Display pin status on EPD
        } else {
          // If the pin status is LOW, format the string and display it
          int length = sprintf(buffer, "GPIO%d : off", pin[i]);
      EPD_Display(ImageBW);  // Display the image to EPD
      EPD_PartUpdate();  // Perform partial update (refresh display)
      EPD_DeepSleep();  // Set EPD to deep sleep mode to save power
    // Define GPIO pin array
    int pin_Num[12] = {8, 3, 14, 9, 16, 15, 18, 17, 20, 19, 38, 21};
      Serial.begin(115200);  // Initialize serial communication, baud rate 115200
      // Configure pin 7 to output mode and set it to HIGH (possibly for power control)
      pinMode(7, OUTPUT);
      digitalWrite(7, HIGH);
      // Configure GPIO pins to output mode
      pinMode(8, OUTPUT);
      pinMode(3, OUTPUT);
      pinMode(14, OUTPUT);
      pinMode(9, OUTPUT);
      pinMode(16, OUTPUT);
      pinMode(15, OUTPUT);
      pinMode(18, OUTPUT);
      pinMode(17, OUTPUT);
      pinMode(20, OUTPUT);
      pinMode(19, OUTPUT);
      pinMode(38, OUTPUT);
      pinMode(21, OUTPUT);
      // Set all GPIO pins to HIGH
      digitalWrite(8, HIGH);
      digitalWrite(3, HIGH);
      digitalWrite(14, HIGH);
      digitalWrite(9, HIGH);
      digitalWrite(16, HIGH);
      digitalWrite(15, HIGH);
      digitalWrite(18, HIGH);
      digitalWrite(17, HIGH);
      digitalWrite(20, HIGH);
      digitalWrite(19, HIGH);
      digitalWrite(38, HIGH);
      digitalWrite(21, HIGH);
      // Call a function to determine the status of GPIO pins and display the result
      judgement_function(pin_Num);
      // Main loop, currently not performing any operations, only delaying by 1 second
      delay(1000);  // Delay of 1000 milliseconds (1 second)
  2. Connect the LED to the GPIO pins.
  3. Upload the code to the CrowPanel. The LEDs will turn on, and the status of the GPIO will show on the screen.
    leds
    gpio
Example 2 Count the times of pressing the keys
  1. Open 5.79_key.ino
    #include "EPD.h"
    // Pre allocated black and white image array
    // key definition
    #define HOME_KEY 2      // Connect the home button to digital pin 2
    #define EXIT_KEY 1      // Exit key connected to digital pin 1
    #define PRV_KEY 6       // Previous page key connected to digital pin 6
    #define NEXT_KEY 4      // Next page key connected to digital pin 4
    #define OK_KEY 5        // Confirm key connected to digital pin 5
    // Initialize each key counter
    int HOME_NUM = 0;
    int EXIT_NUM = 0;
    int PRV_NUM = 0;
    int NEXT_NUM = 0;
    int OK_NUM = 0;
    // Storage key count array
    int NUM_btn[5] = {0};
    // Key counting and display function
    void count_btn(int NUM[5])
      char buffer[30];  // Buffer for storing strings
      // EPD (Electronic Paper Display) initialization
      EPD_GPIOInit();
      Paint_Clear(WHITE);
      // Clear the display screen and initialize it
      EPD_Update();
      EPD_Clear_R26A6H();
      // Display the count of each button
      int length = sprintf(buffer, "HOME_KEY_NUM:%d", NUM[0]);
      EPD_ShowString(0, 0 + 0 * 20, buffer, 16, BLACK);
      length = sprintf(buffer, "EXIT_KEY_NUM:%d", NUM[1]);
      EPD_ShowString(0, 0 + 1 * 20, buffer, 16, BLACK);
      length = sprintf(buffer, "PRV_KEY_NUM:%d", NUM[2]);
      EPD_ShowString(0, 0 + 2 * 20, buffer, 16, BLACK);
      length = sprintf(buffer, "NEXT__NUM:%d", NUM[3]);
      EPD_ShowString(0, 0 + 3 * 20, buffer, 16, BLACK);
      length = sprintf(buffer, "OK_NUM:%d", NUM[4]);
      EPD_ShowString(0, 0 + 4 * 20, buffer, 16, BLACK);
      // Update display content and enter deep sleep mode
      EPD_PartUpdate();
      EPD_DeepSleep();
      // Set button pins
      pinMode(7, OUTPUT);    // Set pin 7 as output for power control
      digitalWrite(7, HIGH); // Set the power to high level and turn on the screen power
      pinMode(HOME_KEY, INPUT);  // Set the home button pin as input
      pinMode(EXIT_KEY, INPUT);  //
      pinMode(PRV_KEY, INPUT);   //
      pinMode(NEXT_KEY, INPUT);  //
      pinMode(OK_KEY, INPUT);    //
          int flag = 0; // Mark whether any buttons have been pressed
      // Check if the home button is pressed
      if (digitalRead(HOME_KEY) == 0)
        delay(100); // Anti shake delay
        if (digitalRead(HOME_KEY) == 1)
          Serial.println("HOME_KEY");
          HOME_NUM++; // Increase homepage key count
          flag = 1; // set mark
      // Check if the exit button has been pressed
      else if (digitalRead(EXIT_KEY) == 0)
        delay(100); // delay
        if (digitalRead(EXIT_KEY) == 1)
          Serial.println("EXIT_KEY");
          EXIT_NUM++; // Increase exit key count
          flag = 1;
      else if (digitalRead(PRV_KEY) == 0)
        delay(100);
        if (digitalRead(PRV_KEY) == 1)
          Serial.println("PRV_KEY");
          PRV_NUM++;
          flag = 1;
      else if (digitalRead(NEXT_KEY) == 0)
        delay(100);
        if (digitalRead(NEXT_KEY) == 1)
          Serial.println("NEXT_KEY");
          NEXT_NUM++;
          flag = 1;
      else if (digitalRead(OK_KEY) == 0)
        delay(100);
        if (digitalRead(OK_KEY) == 1)
          Serial.println("OK_KEY");
          OK_NUM++;
          flag = 1;
      }Reset Tag
      // If a button is pressed, update the display content
      if (flag == 1)
        NUM_btn[0] = HOME_NUM;
        NUM_btn[1] = EXIT_NUM;
        NUM_btn[2] = PRV_NUM;
        NUM_btn[3] = NEXT_NUM;
        NUM_btn[4] = OK_NUM;
        count_btn(NUM_btn); // Call function to update display
        flag = 0; // Reset flag
  2. Press the button.
  3. The times each button is pressed will be displayed on the screen.
    key-counts
Example 3 Control PWR LED with menu Key
  1. Open the 5.79_PWR.ino
    #include "EPD.h"
    // Define a black and white image array as the buffer for the e-paper display
    // Define the pin for the home button
    #define HOME_KEY 2
    // Variable to count the state of the home button
    int HOME_NUM = 0;
      // Initialize serial communication with a baud rate of 115200
      // Set the screen power pin as an output and set it high to turn on the power
      pinMode(7, OUTPUT);
      // Set the POWER LED pin as an output
      pinMode(41, OUTPUT);
      // Set the home button pin as an input
      // Flag variable to indicate if any button has been pressed
      int flag = 0;
        delay(100); // Debounce delay to ensure the button press is stable
        // Re-check the home button state to prevent false triggering due to bouncing
          Serial.println("HOME_KEY"); // Print the home button press information to the serial monitor
          HOME_NUM = !HOME_NUM; // Toggle the state of the home button (on/off)
          flag = 1; // Set the flag to indicate that the display content needs to be updated
      // If a button has been pressed, update the display content
      if (flag == 1)
        char buffer[30]; // Buffer to store the display content
        // Initialize the e-paper display
        EPD_GPIOInit();
        Paint_Clear(WHITE);
        // Initialize the e-paper display and clear the previous display content
        EPD_Update();
        EPD_Clear_R26A6H();
        // Set the state of the POWER LED and display content based on the home button state
        if (HOME_NUM == 1)
          digitalWrite(41, HIGH); // Turn on the POWER LED
          strcpy(buffer, "PWR:on"); // Set the display content to "PWR:on"
        } else
          digitalWrite(41, LOW); // Turn off the POWER LED
          strcpy(buffer, "PWR:off"); // Set the display content to "PWR:off"
        // Display the content on the e-paper
        // Refresh the e-paper display content
        EPD_PartUpdate();
        EPD_DeepSleep(); // Enter deep sleep mode to save power
  2. Upload the code to the CrowPanel.
  3. Press the menu key and the PWR LED will turn on/off.
    PWR1
    PWR2
Example 4 Initialize SD card
  1. Open 5.79_TF.ino
    #include <Arduino.h>  // Include the Arduino library
    #include "EPD.h"      // Include the e-paper display library
    #include "SD.h"       // Include the SD card library
    // Define the SPI pins for the SD card
    #define SD_MOSI 40    // SD card MOSI pin
    #define SD_MISO 13    // SD card MISO pin
    #define SD_SCK 39     // SD card SCK pin
    #define SD_CS 10      // SD card CS pin
    // Create an instance of SPIClass for SD card SPI communication
    SPIClass SD_SPI = SPIClass(HSPI);
      pinMode(7, OUTPUT);
      // Set another power pin as an output and set it high to turn on the power
      pinMode(42, OUTPUT);
      digitalWrite(42, HIGH);
      // Brief delay to ensure power stability
      delay(10);
      // Initialize the SD card
      SD_SPI.begin(SD_SCK, SD_MISO, SD_MOSI); // Initialize SPI with specified pins
      // Try to mount the SD card file system and set the SPI clock speed to 80 MHz
      if (!SD.begin(SD_CS, SD_SPI, 80000000)) {
        // If SD card initialization fails, print error message to the serial monitor
        Serial.println(F("ERROR: File system mount failed!"));
      } else {
        // If SD card initialization succeeds, print SD card size information to the serial monitor
        Serial.printf("SD Size: %lluMB \n", SD.cardSize() / (1024 * 1024));
        // Create a buffer to store the display content
        char buffer[30]; // Assume the display content will not exceed 30 characters
        // Use sprintf to format the string and store the SD card size information in buffer
        int length = sprintf(buffer, "SD Size:%lluMB", SD.cardSize() / (1024 * 1024));
        buffer[length] = '\0'; // Ensure the string ends with a null character
        EPD_GPIOInit(); // Initialize the GPIO pins for the e-paper
        Paint_Clear(WHITE); // Clear the image, fill with white
        // Recreate and clear the image
        Paint_Clear(WHITE);
        // Initialize the e-paper display mode
        EPD_Display_Clear(); // Clear the e-paper display
        EPD_Update();        // Update the e-paper display
        EPD_Clear_R26A6H(); // Further clear the display
        // Print the display content to the serial monitor
        Serial.println(buffer);
        EPD_ShowString(0, 0, buffer, 16, BLACK); // Draw the string on the e-paper
        EPD_PartUpdate();
      // Main loop code
      delay(10); // Wait for 10 milliseconds
  2. Insert the TF card to the card slot.
  4. The size of the TF card will show on the screen.
    tf-size
Example 5 Connect Bluetooth
  1. Open 5.79_BLE.ino
  3. After the blutooth is connected, the screen will show:
    ble
Example 6 Connect WiFi
  1. Open 5.79_wifi.ino
  2. Modify your ssid and password
    String ssid = "";
    String password = "";
  4. After the WiFi is connected, the screen will show:
    wifi-ip
Example 7 Refresh image
This example will demonstrate two scenarios: refreshing full screen images and non full screen images.
  • Full screen image: The resolution of the image is the same as the screen
  • Non full screen image: The image resolution is lower than the screen resolution
Refresch full screen image
  1. Open 5.79_Global_refresh.ino
    #include <Arduino.h>         // Include the core Arduino library to provide basic Arduino functionality
    #include "EPD.h"             // Include the EPD library for controlling the electronic ink screen (E-Paper Display)
    #include "pic_home.h"        // Include the header file containing image data
    uint8_t ImageBW[27200];      // Declare an array of 27200 bytes to store black and white image data
      // Initialization settings, executed once when the program starts
      pinMode(7, OUTPUT);        // Set pin 7 to output mode
      digitalWrite(7, HIGH);     // Set pin 7 to high level to activate the screen power
      EPD_GPIOInit();            // Initialize the GPIO pin configuration for the EPD electronic ink screen
      Paint_NewImage(ImageBW, EPD_W, EPD_H, Rotation, WHITE); // Create a new image buffer with dimensions EPD_W x EPD_H and a white background
      Paint_Clear(WHITE);        // Clear the image buffer and fill it with white
      /************************ Fast refresh screen operation in partial refresh mode ************************/
      EPD_FastMode1Init();       // Initialize the EPD screen's fast mode 1
      EPD_Display_Clear();       // Clear the screen content
      EPD_Update();              // Update the screen display
      EPD_GPIOInit();            // Reinitialize the GPIO pin configuration for the EPD electronic ink screen
      EPD_FastMode1Init();       // Reinitialize the EPD screen's fast mode 1
      EPD_ShowPicture(0, 0, 792, 272, gImage_home, WHITE); // Display the image gImage_home starting at coordinates (0, 0), width 792, height 272, with a white background
      EPD_Display(ImageBW);      // Display the image stored in the ImageBW array
      //  EPD_WhiteScreen_ALL_Fast(gImage_boot_setup); // Commented-out code: Display the boot setup image using fast mode
      //  EPD_PartUpdate();       // Commented-out code: Update part of the screen
      EPD_FastUpdate();          // Perform a fast update to refresh the screen
      delay(5000);               // Wait for 5000 milliseconds (5 seconds)
      clear_all();               // Call the clear_all function to clear the screen content
      // Main loop function, currently does not perform any actions
      // Code that needs to be executed repeatedly can be added here
    void clear_all() {
      // Function to clear the screen content
  3. The image will refresh on the screen.
Refresh non full screen image
  1. Open 5.79_partial_refresh.ino
    #include "pic_scenario.h"    // Include the header file containing image data
      // Configure the screen power pin
      EPD_HW_RESET();            // Perform a hardware reset operation to ensure the screen starts up properly
      EPD_ShowPicture(0, 0, 312, 152, gImage_1, WHITE); // Display the image gImage_1 starting at coordinates (0, 0), width 312, height 152, with a white background
      EPD_PartUpdate();          // Update part of the screen to show the new content
    void clear_all()
Resources
