CrowPanel ESP32 Terminal RGB with Arduino IDE¶
Overview¶
The example tutorial is an environmental monitoring project, demonstrate how to create a UI and use a Humidity&Temperature sensor to obtain the environment temperature and humidity and display it on the screen; and how to control the LED on and off by the buttons on the screen.
Hardware Preparation¶
| ESP32 Terminal RGB | Crowtail-AM2302 | Crowtail-LED |
Please click
to download the demo for "Example Demonstration" section in "Get Started with SquareLine Studio".
Open the SquareLine Studio and create a project. Select "Elecrow"->"DLC35010R - ESP32 Terminal...-Arduino-IDE".
Set the name of the project, you can select the folder to save the project. Click CREATE to create the project.
Please click
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Please click
to download the main program(and the expert UI is included). -
Modify the button event code.
First, define an extern variable in the ui.h file to store the status of the LED. In the main program, the LED light is controlled to turn on and off by judging the status of this variable.
Build the Project with Arduino IDE¶
Get Started with Arduino IDE¶
Install Libraries¶
#include<Arduino.h>
#include <lvgl.h>
#include <LovyanGFX.hpp>
#include "FT6236.h"
#include "ui.h"
#include "DHT.h"
#include <Arduino.h>: contains the Arduino core library, providing commonly used functions and data types.#include <LovyanGFX.hpp>: A library for drawing graphics on embedded systems, providing rich graphics functions and APIs.#include "FT6236.h": A library for the FT6236 touch chip to handle touch input.#include "ui.h": is a custom header file that contain UI-related functions or definitions.#include "DHT.h": to read data from the temperature and humidity sensor.
Please click
to download the libraries we modified.
Tips:
If you install the lvgl libraries by Library Manager, you need to copy the demos folder and examples folder and paste them to src folder. And modify the lv_conf_template.h file and rename it to lv_conf.h, and place it in libraries folder.(Please refer to the library provided)
Code Explanation¶
Basic Definition¶
Pin Definition
Touch I2C definition, LCD backlight definition pin, temperature and humidity sensor definition pin and initialization.
const int i2c_touch_addr = TOUCH_I2C_ADD;
#define LCD_BL 46
#define DHTPIN 40 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
// Initialize DHT20 sensor
DHT dht(DHTPIN, DHTTYPE);
#define SDA_FT6236 38
#define SCL_FT6236 39
//FT6236 ts = FT6236();
LGFX Class Definition
This part is the definition of a class LGFX, which is a subclass of lgfx::LGFX_Device. The main function is to configure and initialize an RGB panel, and then connect it to the RGB bus on the ESP32-S3 microcontroller to display graphics on the panel.
lgfx::Panel_ILI9488 _panel_instance;
lgfx::Bus_Parallel16 _bus_instance;
public:
LGFX(void)
cfg.port = 0;
cfg.freq_write = 80000000;
cfg.pin_wr = 18;
cfg.pin_rd = 48;
cfg.pin_rs = 45;
cfg.pin_d0 = 47;
cfg.pin_d1 = 21;
cfg.pin_d2 = 14;
cfg.pin_d3 = 13;
cfg.pin_d4 = 12;
cfg.pin_d5 = 11;
cfg.pin_d6 = 10;
cfg.pin_d7 = 9;
cfg.pin_d8 = 3;
cfg.pin_d9 = 8;
cfg.pin_d10 = 16;
cfg.pin_d11 = 15;
cfg.pin_d12 = 7;
cfg.pin_d13 = 6;
cfg.pin_d14 = 5;
cfg.pin_d15 = 4;
_bus_instance.config(cfg);
cfg.pin_cs = -1;
cfg.pin_rst = -1;
cfg.pin_busy = -1;
cfg.memory_width = 320;
cfg.memory_height = 480;
cfg.panel_width = 320;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
cfg.offset_rotation = 2;
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = true;
cfg.invert = false;
cfg.rgb_order = false;
cfg.dlen_16bit = true;
cfg.bus_shared = true;
_panel_instance.config(cfg);
setPanel(&_panel_instance);
LGFX tft;
Define LED variables and screen resolution parameters
int led;
/*Changing the screen resolution*/
/*Change to your screen resolution*/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
Defining buffer variables
Initialize the LVGL display driver and prepare a buffer to store the pixel data to be rendered on the screen. The size of this buffer should be about 1/10 of the product of the screen pixel value, which can take into account both the main control performance and the smoothness of the screen display. Here, take 5 as an example, the display will be smoother.
Functions¶
my_disp_flush()
This code is a callback function for refreshing the display, usually used with a graphics library. The function is to write pixel data to the display device based on the given area and color data to implement the display refresh operation.
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
tft.endWrite();
lv_disp_flush_ready( disp );
my_touchpad_read()
This code is a callback function for reading touch screen input, usually used with the graphics library. The function is to set the corresponding input data according to the input state and coordinates of the touch screen so that the graphics library can perform subsequent processing and display.
int pos[2] = {0, 0};
ft6236_pos(pos);
if (pos[0] > 0 && pos[1] > 0)
data->point.x = tft.width()-pos[1];
data->point.y = pos[0];
// data->point.y = pos[1];
// data->point.x = pos[0];
Serial.printf("x-%d,y-%d\n", data->point.x, data->point.y);
else {
touch_init()
This code is a function for initializing the touch screen. It is used to initialize the touch screen and detect whether it is successfully connected to the touch screen device.
void touch_init()
// I2C init
Wire.begin(SDA_FT6236, SCL_FT6236);
byte error, address;
Wire.beginTransmission(i2c_touch_addr);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
Serial.print(i2c_touch_addr, HEX);
Serial.println(" !");
else if (error == 4)
Serial.print("Unknown error at address 0x");
Serial.println(i2c_touch_addr, HEX);
Set Up Part¶
Serial.begin( 115200 ); /*Initializing the Serial Port*/
//IO Port Pins
pinMode(19, OUTPUT);
digitalWrite(19, LOW);
tft.begin(); /* TFT init */
tft.setRotation( 1 ); /* Landscape orientation, flipped */
tft.fillScreen(TFT_BLACK);
delay(500);
pinMode(LCD_BL, OUTPUT);
digitalWrite(LCD_BL, HIGH);
touch_init();
lv_init();
/*This code is used to configure and initialize the display driver and input device driver of the LittlevGL (LVGL) graphics library to implement the display and interaction of the graphical interface in the embedded system. The main steps include:
Get the width and height of the screen and initialize the drawing buffer.
Initialize the display driver and set its parameters, including resolution, refresh callback function and drawing buffer.
Register the display driver to the LVGL library.
Initialize the input device driver and set its type and read callback function.
Register the input device driver to the LVGL library.*/
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 5 );
/*Initialize the display*/
lv_disp_drv_init( &disp_drv );
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
/*Initialize the (dummy) input device driver*/
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
/*Initialize the (virtual) input device driver. This code is used to initialize a virtual input device driver and associate it with the LVGL framework to handle the interaction of the input device. It provides the necessary configuration and functions for the input device driver by setting the input device type and defining the read callback function.*/
/* Initialize the (dummy) input device driver */
ui_init(); // UI initialization
lv_timer_handler();
Main Program Part¶
/*Get the temperature and humidity data and use a char array to store it. First, use two integer variables a and b to store the obtained temperature and humidity.*/
char DHT_buffer[6];
int a = (int)dht.readTemperature();
int b = (int)dht.readHumidity();
/*Then the value is stored in an array through conversion and displayed on the label*/
/*udge the value of LED. In the ui.c program, press the "ON" button to set LED to 1, and the LED light will be on.*/
if(led == 1)
digitalWrite(19, HIGH);
/*In the ui.c program, press the "OFF" button to set the led to 0, and then the control turns off the led light.*/
if(led == 0)
/*Let the GUI complete its work. Only by executing this function can the entire animation run.*/
delay( 10 );
Upload the Code¶
After completing the installation of the ESP32 board according to "Get Started with Arduino IDE" and the installation of the library according to "Install Libraries", open the program and connect the ESP32 Terminal to the computer via a USB-C cable.
Select Board: click "Tools" -> "Board" -> "esp32" and select "ESP32S3 Dev Module"
Select Port
Select the serial port corresponding to the ESP32 terminal board.
Upload the code
After the program is successfully uploaded, connect the sensor to the D Port(IO40) port and the LED to A Port(IO19), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
Examples¶
Please click
to download the code for the examples.
Note:
The library used in this section is in the compressed package of the library downloaded above.
Example 1: Switch color screen¶
- Open and upload the B-ScreenColor.ino
- The screen will display different colors
Example 2: Display the pictures from TF card¶
- Insert the TF card in to card slot
- Open and upload the F-photo.ino
- The pictures will show on the screen
Example 3: LED Blinking¶
- Plug the LED into the D port
- Open and upload the D-D-PortOut.ino
- The LED will blink alternately
Example 4: I2C communication¶
- Plug an OLED screen to the I2C port
- Open and upload the E-IIC.ino
- The OLED screen will display the content sent from the ESP terminal
Example 5: Read the external ADC through the A port¶
- Plug a sensor into the A port
- Open and upload A-ADC.ino
- The value of the sensor will show on the screen
Example 6: Make sound¶
- Upload the A-BUZZER.ino
- The on-board buzzer will sounds "beep"
Example 7: Connect WiFi¶
Open the A-WIFI.ino
Modify the code to connect your WiFi
const char *ssid = "elecrow888"; //change to your network name
const char *password = "elecrow2014"; //change to your network password
- Upload the code and the screen will show "WIFI is connected"
