Crowbits-Potentiometer
The potentiometer is an analog input module, it acts like a variable resistor, it controls your circuit through adjusting the resistance in the whole circuit.
  • Analog input module
  • Operating Voltage: 3.3V DC
  • The range of resistance of the potentiometer: 0~5KΩ
Usage
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. Rotate the rheostat, you can see that the LED will have a progressive effect of darkening or brightening.
