Crowtail- Electricity Sensor
The Electricity sensor module is a member of Crowtail. It is based on the TA12-200 current transformer which can transform the large AC into small amplitude. You can use it to test large alternating current up to 5A.
Model: CT010593E
  • Crowtail compatible interface
  • Maximum 5A input
  • High accuracy
  • Small size
Dimensions(mm):40.0(L)x20.0(W)x21.7(H)
Items Min Norm Max Unit
Transformation ratio - 2000:1 - -
Input Current 0 - 5 A
Output Current 0 - 2.5 mA
Sampling Resistance - 800 - Ω
Sampling Voltage 0 - 2 V
Working Frequency 20 - 20K HZ
Nonlinear scale - - 0.2% -
Phase Shift - - 5' -
Operating Temperature -55 - 85 ℃
Dielectric strength - 6 - KVAC/1min
Usage
With Arduino
The following sketch demonstrates a simple application of measuring the amplitude of the alternating voltage.The SIG pin will output a alternating voltage based on the alternating current being measured. You can measure the value using ADC.
Connect the module to the analog A0 of Crowtail- Base board Put the alternating current wire through the hole of the current transformer.
1.Copy and paste code as below to a your Arduino sketch.
//  Function: Measure the amplitude current of the alternating current and
//            the effective current of the sinusoidal alternating current.
//  Hardware: Crowtail - Electricity Sensor
//  Date:    June 2,2016
//  by www.elecrow.com
#define ELECTRICITY_SENSOR A0 // Analog input pin that sensor is attached to
float amplitude_current;               //amplitude current
float effective_value;       //effective current
    pins_init();
    int sensor_max;
    sensor_max = getMaxValue();
    Serial.print("sensor_max = ");
    Serial.println(sensor_max);
    //the VCC on the Crowtail interface of the sensor is 5v
    amplitude_current=(float)sensor_max/1024*5/800*2000000;
    effective_value=amplitude_current/1.414;//minimum_current=1/1024*5/800*2000000/1.414=8.6(mA)
                        //Only for sinusoidal alternating current
    Serial.println("The amplitude of the current is(in mA)");
    Serial.println(amplitude_current,1);//Only one number after the decimal point
    Serial.println("The effective value of the current is(in mA)");
    Serial.println(effective_value,1);
void pins_init()
    pinMode(ELECTRICITY_SENSOR, INPUT);
/*Function: Sample for 1000ms and get the maximum value from the SIG pin*/
int getMaxValue()
    int sensorValue;             //value read from the sensor
    int sensorMax = 0;
    uint32_t start_time = millis();
    while((millis()-start_time) < 1000)//sample for 1000ms
        sensorValue = analogRead(ELECTRICITY_SENSOR);
        if (sensorValue > sensorMax)
            /*record the maximum sensor value*/
            sensorMax = sensorValue;
    return sensorMax;
Note: The minimum effective current that can be sensed by the code can be calculated using the equation below. minimum_current=1/1024*5/800*2000000/1.414=8.6(mA).
2.Open the serial monitor, The results is as follows:
Resource
