Crowtail- Linear Potentiometer
The Crowtail- Linear Potentiometer module uses a linear variable resistor with a maximum resistance of 10KΩ. When you move the slider from one side to the other, its output voltage will range from 0 V to the Vcc you applied. The panel mount design makes this module easy to be installed in projects.
Model: CT0022LP
  • 30 mm long slide length
  • Linear resistance taper
  • Connection Mode:A(Analog)
Dimensions(mm):60.0(L)x20.0(W)x18.0(H)
Item Min Typical Max Unit
Voltage 3.5 5.0 30 V
Current - - 30 mA
Dimension 20 x 60 mm
Net Weight 8.3 g
Rotational life >15000 cycles
Total resistance 10
Stroke length 30 mm
Total resistance tolerance +/- 20% /
Usage
With Arduino
Follow these simple steps to make the Linear potentiometer module function as a voltage divider:
1.When using the module in conjunction with an Arduino or a Crowduino, use the Crowtail - Base Shield and connect the Crowtail - Linear Potentiometer module to the shield using a designated Crowtail Interface (e.g., Analog Port 0 as shown below):
3.Upload the following sample sketch:
int sensorpin=A0;
int sensorValue=0;
  sensorValue = analogRead(sensorpin);
  Serial.print("sensorValue ");
  Serial.println(sensorValue);
4.Open the serial monitor. You should see some data from ADC.
Resource
