GPS shield
The GPS Shield is base on the ublox's NEO-6M receiver module , and the footprints is compatible with Arduino/MEGA boards. The regular GPS pins (RX, TX) can be connected to D0-D7 of Arduino. Support software SerialPort and Micro SD card interface.
It's very easy using. You just need read SerialPort and then will get the GPS data. It also could use with GPRS Shield(click here to know how to use GPRS). So you can send GPS data to phone by SMS, then you can get the position of the GPS Shield.
The GPS Shield module interfaces to the customer’s application via one serial port, which uses CMOS voltage levels. support 3.3V / 5V IO operating. That's means 100% all Arduino main board compatible.
Model: MCS01107S
- With standard Shield interface,it is compatible to all arduino main board.
- With Micro SD interface
- 3.3v and 5v logical voltage compatible
- Active antenna design with high receive sensitivity, compatible normal antenna
- Extremely fast time to first fix at low signal level
- Operation temperature: -40c„ƒ ~ +85c
Specifications¶
NEO-6M-0-001
Interface function¶
Application 1: Print the GPS data with serial port¶
This example simply prints the output of the frames received by the GPS module to the serial port of an arduino.
first, connect the UART_RX to PD3, UART_TX to PD2.
second, upload the following demo code to Arduino or Crowduino.
//at 9600 bps 8-N-1
//Computer is connected to Arduino/Crowduino
//SoftSerial Shield is connected to the Software UART:D2&D3
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(6, 7);
unsigned char buffer[256]; // buffer array for data recieve over serial port
int count=0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
if (SoftSerial.available()) // if date is comming from softwareserial port ==> data is comming from SoftSerial shield
while(SoftSerial.available()) // reading data into char array
buffer[count++]=SoftSerial.read(); // writing data into array
if(count == 256)break;
Serial.write(buffer,count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the storaged data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardwareserial port ==> data is comming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
for (int i=0; i<count;i++)
{ buffer[i]=NULL;} // clear all index of array with command NULL
Third, Open the serial monitor, select the serial rate as 9600. you will get the data return from the GPS modual.
Application 2: Use the u-center software to Locate your place¶
1. Down load the U-center software. you can also go to the U-blox office website to download this software. And install it.
2. Upload the demo code in Application 1 to Arduino.
3. Open U-center, choose the serial port and set the serial rate as 9600. After a while, you will get the location of the GPS shield.
See Also¶
FAQ¶
Please feel free to connect with techsupport@elecrow.com. We will list the normal question here and do our best to solve your problem.
