Playing Raspberry Pi Magic Minecraft Blocks without CrowPi
Not all of us we’re able to buy or get CrowPi for our own, In Elecrow, we care about all our customers so we crafted a special tutorial on how to use Minecraft magic blocks with NFC chips without CrowPi!
Play minecraft with Raspberry Pi 3
Follow this instructions step by step on your fresh new raspberry pi image in order to get the RFID working on your raspberry pi with RC-522 module and be able to play using RFID Module and the NFC chips!
https://github.com/Elecrow-keen/CrowPi.git clone and install the RC-522 driver from the Drivers/RFID/ directory using the command “python setup.py install”
After installing the driver, make sure to connect the RFID module properly to your raspberry pi:
Check the following pins information and connect it by the by the BCM (physical pins) names, make sure you connect everything properly else the project might not work!
NFC Minecraft Project cable connection
MISO  => PIN21 (SPI_MISO)
MOSI => PIN19 (SPI_MOSI)
SCK => PIN23 (SPI_CLK)
SDA => PIN24 (CE0)
IRQ => PIN18 (GPIO24)
GND => PIN6 (GND)
3.3V => PIN1 (3.3v)
RST => PIN39 (GND)
Image result for raspberry pi 3 GPIo
After you successfully connected and installed the driver it’s time to test it!
From inside of the CrowPi folder, run the following command: “sudo python RFID_Read.py” now try to touch using one of the NFC tags on top of the RC-522 module, it should be able to read it!
If everything is fine, you can now follow the Minecraft tutorial and lessons and all the functionalities now will work for you exactly as they work on the CrowPi!
Here are the links you may need
Buy the RFID Reader and card
>>https://www.elecrow.com/rfid-reader-with-cards-kit-1356mhz-p-756.html
Buy Raspberry Pi monitor
>>http://www.elecrow.com/display-1.html
Buy Raspberry Pi adpter
>>https://www.elecrow.com/raspberry-pi-3b-power-adapter-micro-usb-with-switch-button-us-eu-au-uk-plug-type.html
Buy Raspberry Pi 3 model B+
>>https://www.elecrow.com/raspberry-pi-3-model-b.html
Download all the Minecraft lessons with Raspberry Pi
>>https://www.elecrow.com/download/crowpi/Minecraft-Lessons.pdf
Find the Minecraft blocks paper folder
>>http://www.pixelpapercraft.com/minecraft block paper folder
5 thoughts on “Playing Raspberry Pi Magic Minecraft Blocks without CrowPi
  1. bong88
    The process begins from your uncomplicated activity of your account option. Warrior bands moved
    south and east on the rich pickings of the peoples whom that they had traded with.
    The Open Video Project: This is site using
    a huge number of digital video for sharing.
Comments are closed.
