Whether you are a seasoned design engineer, an electronics hobbyist, or a startup preparing for your first manufacturing run, a thorough understanding of how to generate a Pick and Place (PnP) file is critical to your project's success. This file serves as the digital instruction set for automated placement machines, making it an indispensable part of the entire PCB assembly process. This comprehensive guide will detail the technical fundamentals of PnP files, standard formats, and how to export them from nine leading PCB design tools.
A Pick and Place file, also known as a Centroid File or XY Coordinate File, is a text-based data file that contains the precise location, rotation angle, and layer information for every Surface Mount Device (SMD) on a printed circuit board. Automated SMT (Surface Mount Technology) placement machines directly read this file to achieve high-speed, high-precision component placement.
A standard PnP file typically includes the following key data columns:
Most PCB assembly service providers accept files in several standard formats. It is always best practice to confirm the preferred format with your partner before exporting.
.CSV
(Comma Separated Values): The most common and recommended format due to its clear structure and ease of review..TXT
(Text File): A plain text file using tabs or spaces as delimiters..XY / .CEN
(Centroid File): A default centroid file format for some software..POS
(Position File): A position file format commonly used by KiCad..XLS / .XLSX
(Excel Spreadsheet): Also a very popular and easy-to-edit format.File
> Assembly Outputs
> Generates Pick and Place Files
.Metric (mm)
for units and choose your output format (CSV is recommended).Output Job Files
to manage all manufacturing files consistently.File
> Fabrication Outputs
> Footprint Position (.pos) File...
.CSV
as the format and select Millimeters
for units..brd
board file.ulp/mountsmd.ulp
user language program.File
> Export
> Placement
.File
> Export
> Pick and Place File...
..csv
file with all necessary information.File
> Export
> Pick and Place
.Output
> Reports
> Component Placement Report
..CSV
file and verify the coordinate system.File
> Assembly Outputs
.Output
> Pick and Place Report
.Generating a correctly formatted and accurate Pick and Place file is the cornerstone of an efficient, error-free PCB assembly process. Its quality is paramount, especially when dealing with high-density or fine-pitch component designs. While modern CAD tools have simplified the export process, investing time in careful validation and review will save significant potential costs and delays on the production line.
If you're working on a prototype or production run and require reliable, one-stop PCB assembly services, the expert team at Elecrow is here to help.
Please send your design files to our engineering team for a quote and review:
Contact Us: info@elecrow.com
Get an instant quote for your next PCB manufacturing and assembly project today!
