Have you ever found that scaling a Raspberry Pi concept from a test bench to a reliable, deployable system introduces significant challenges in housing, display integration, and I/O expansion? The Elecrow Pi Terminal is engineered to solve this exact problem. It is not an accessory, but an all-in-one platform that seamlessly integrates a Raspberry Pi Compute Module 4, a 7-inch touchscreen, and a comprehensive suite of industrial-grade interfaces.
But with such a capable device, the critical question becomes: "How can it be leveraged in a professional setting?"
For a quick overview, the table below summarizes the core applications. Click on any application title to jump directly to the detailed section.
| Application | Core Function | Key Enabling Features |
| #5. Edge AI & Machine Vision Terminal | On-device AI for real-time visual inspection, analysis, and response. | CM4 Processor, CSI Camera Interfaces |
| #4. Compact PLC & Automation Controller | Reliable automation for machinery, process control, and workshop tasks. | Isolated Digital I/O, Onboard Relays |
| #3. CAN Bus Analyzer & Diagnostic Tool | Professional diagnostics and data logging for automotive & industrial machinery. | Native CAN Bus Interface |
| #2. Industrial IoT (IIoT) Gateway | Connecting legacy industrial equipment to modern IT networks and cloud platforms. | RS485 Port, Gigabit Ethernet/Wi-Fi, 4G/LoRa Expansion (Mini-PCIe) |
| #1. Interactive HMI & SCADA Node | Centralized, interactive touch control for any machine or process. | 7" Capacitive Touchscreen, Pre-installed Node-RED Software |
Deploying intelligent vision systems directly at the source of data, reducing latency and network dependency.
CM4-Excellent Ability
Serving as a reliable automation core for small-scale machinery, process control, and workshop automation.
Streamlining the development and diagnostics for automotive, robotics, and industrial machinery applications.
can-utils software suite in Raspberry Pi OS, engineers can monitor, log, and transmit CAN packets professionally.Many Systems Supported
Bridging the gap between legacy Operational Technology (OT) and modern IT infrastructure, enabling data connectivity for non-networked equipment.
To serve as a professional, intuitive touch-control center for any machine, process, or project—this is its primary mission.
Regardless of which of the other applications you implement, an HMI provides the essential layer for observation and control. The Pi Terminal is, by its very design, a perfect HMI device, making this its most direct and powerful capability.
This foundational project demonstrates the device's power by creating an HMI to monitor sensors, control actuators, and respond to inputs.
Objective:
Key Implementation Steps:
ADC_IN0 Phoenix terminal.Relay interface (using NO1 and COM1 terminals) to its external power source.DI0 (Isolated Digital Input) and GND terminals.http://:1880.ui_switch node (for the UI button) and an rpi gpio out node (configured to the relay's GPIO) onto the canvas. Connect them. This creates a functional touchscreen switch.rpi gpio in node to read the button's state. Feed this into a switch node to determine the logic ("Normal" vs. "Emergency"). Output the corresponding text to a ui_text node for display./ui URL.Various Interfaces on Pi Terminal
These five applications illustrate a core principle: the Elecrow Pi Terminal is engineered to remove foundational hardware hurdles, allowing your team to focus on what truly matters—your software and application logic. It effectively bridges the gap between a promising proof-of-concept and a deployable, industrial-grade solution. The hardware integration is solved. The platform is ready. The only remaining question is: which of your operational challenges will you address first?
