Grovety
  • 23 Projects
  • 25 Followers
  • May 12,2025
Natural Language Robot Control via CrowPanel + OpenAI
Voice-controlled robot interface using CrowPanel Advance and OpenAI. Spoken commands are interpreted via API and sent over Bluetooth to a robot. Works with CrowBot and can be adapted for other devices.
Goods
This project demonstrates how to build a compact, intelligent voice-controlled robot system using the CrowPanel Advance and the OpenAI Realtime API. The CrowPanel records the user's voice, sends it to OpenAI for transcription and interpretation, and receives a structured command. This command is interpreted on the panel and then transmitted to the robot (CrowBot) over Bluetooth.
Thanks to GPT-based natural language understanding, the robot can respond not only to simple instructions like “Go forward”, but also to indirect phrases like “It’s kind of dark in here” — and respond by turning on headlights.
While this setup works out-of-the-box with CrowBot, it can be easily adapted to control other DIY robotic platforms, Bluetooth-enabled smart toys, or even home automation systems.
🔗 Project repository: Grovety/OpenAI_Robot_Control
📽️ Demo video: Watch on YouTube
✨ Features
  • - Hands-free voice control using CrowPanel Advance's built-in microphone
  • - Natural language understanding powered by OpenAI (Realtime API)
  • - Function calling via structured JSON for safe, extensible command execution
  • - Bluetooth-based command transmission to CrowBot
  • - Simple GUI for Wi-Fi setup and API key entry
  • - Open-source and extensible: adapt it for your own robots or systems
⚙️ How It Works
  1. The user holds the CrowPanel Advance, running a custom control application.
  2. They speak a command — e.g., “Go forward and turn right”, or “It’s kind of dark in here”.
  3. The voice is streamed to OpenAI Realtime API, where it is transcribed (via gpt-4o-mini-transcribe) and processed.
  4. OpenAI returns a structured JSON with function names and parameters.
  5. The CrowPanel interprets the response and transmits commands via Bluetooth to the CrowBot.
  6. The robot executes the actions (e.g., moving, turning, lights on/off).
  7. Unsupported or unclear requests are safely handled using a built-in reject_request function.
Thanks to the OpenAI integration, even complex or indirect voice commands are parsed into actionable steps, making robot control more intuitive and fun.
🔧 Required Hardware
  • - CrowPanel Advance
  • - CrowPanel Addon (with Bluetooth module)
  • - CrowBot or any robot accepting Bluetooth UART commands
  • - OpenAI API Key
🖥️ Firmware
CrowPanel firmware and voice control logic:
👉 Grovety/OpenAI_Robot_Control
Custom CrowBot firmware:
👉 CrowBot GRC Firmware
🛠️ Tutorial – Quick Start Guide
There are two installation options:
  • - A quick setup using prebuilt images
  • - A full build-from-source option for developers and makers
🔹 Option 1: Flash prebuilt firmware
  1. Download flash_tool.exe from the repository with binaries folder
    Что должно быть в папке для прошивки панели
  2. Connect CrowPanel via USB and run the flasher."Прошиватор" ожидает подключения CrowPanel
  3. After flashing, connect to Wi-Fi
    Экран подключения к Wi-Fi
  4. And input your OpenAI API key.
    Ввод ключа. Придётся попотеть: ввод только руками с клавиатуры (либо добавьте свой ключ прямо в исходниках)
  5. Power on CrowBot.
  6. Start speaking — try commands like:
    • “Forward”
    • “Turn left and switch on the lights”
Ожидание команды от пользователя
🔹 Option 2: Build from source
  1. Clone the Grovety/OpenAI_Robot_Control repo
  2. Use ESP-IDF v5.4+ to build and flash the CrowPanel firmware
  3. Customize GUI, Bluetooth logic, or the command parser as needed
  4. Flash CrowBot with compatible firmware using Arduino or PlatformIO
📦 About Command Processing
Instead of using a long text prompt, this project uses OpenAI’s function calling feature to safely map user speech to valid robot actions.
A JSON file defines all available functions:
👉 function_list_robot.json
Each function has a name (e.g. go_forward), a description, and optional parameters.
When the user says something like:
“Go forward and turn on the lights”
CrowPanel sends:
  • - the recognized text
  • - the JSON function list
  • - and the instruction function_call: auto
OpenAI returns structured output like:
{ "name": "go_forward", "arguments": {} }
CrowPanel parses the result and sends corresponding Bluetooth commands to CrowBot.
✅ Why this approach is great:
  • - Only approved functions can be called — no surprises
  • - Adding new commands is easy — just update the JSON
  • - Supports safe fallbacks like reject_request for unclear input
  • - Scalable and secure — follows OpenAI's recommended architecture for embedded AI
🧪 Ideas for Expansion
Want to take it further? Here are some directions:
  • - Add a voice response system using a speaker and OpenAI’s voice synthesis
  • - Integrate a dialog system with contextual memory
  • - Use the same setup to control smart home devices via Bluetooth relays
  • - Combine it with gesture recognition or visual feedback
  • - Extend the command set via JSON — just update function_list_robot.json
  • - Switch from one-shot transcription to real-time voice ↔️ voice interaction using OpenAI's streaming API
  • https://github.com/Grovety/OpenAI_Robot_Control
4.5k
53
7
  • Comments( 7 )
  • Like( 53 )
  • Interesting approach. I wonder how consistent the voice recognition is in noisy environments.
    May 19,2025 1 comments
    • Grovety 2025-05-19 19:27:28
      Thanks! Good question — in noisy environments, recognition quality depends a lot on the background level and clarity of speech. Since the CrowPanel uses a built-in mic and streams audio to OpenAI, it's surprisingly good at filtering noise, but not immune.
      Reply
    Reply
  • "Use ESP-IDF v5.4+ to build and flash the CrowPanel firmware" Unfortunately, I don't know how to work with ESP-IDF v5.4, but I would really like to use your system. Could you make a video showing the complete build process? I only want to write for tablets.
    • Grovety 2025-05-19 19:40:33
      Thanks for your interest! You're not alone — ESP-IDF can be a bit tricky at first, especially if you're only planning to work with CrowPanel tablets. In the meantime, if you only want to use the tablet side (voice + GUI), you can try the prebuilt firmware (binaries folder) using flash_tool.exe — no coding or build tools needed.
      Reply
    Reply
  • Looks like a solid demo. I’ll give it a try this weekend and see how it behaves with my CrowPanel.
    • Grovety 2025-05-19 19:48:52
      Thanks! That sounds great — let us know how it goes with your CrowPanel. If you run into any setup issues or have ideas for improvement, feel free to post here or open an issue on GitHub. Always happy to hear real-world feedback!
      Reply
    Reply
  • cool project. Do u think the voice recognition will stay consistent in noisy envrionment
    Sep 08,2025 0 comments
    Reply
