Fawaz Yousif
BLDC Motor Electronic Speed Controller
Open Hardware and Firmware for a Hall-sensor-based 6-step BLDC motor controller using PIC18F Microcontroller.
3-Phase BLDC Motor Controller (ESC)
Open Hardware & Firmware for a Hall-sensor-based 6-step BLDC motor controller using PIC18F.
Project Overview
This project implements a 3-phase BLDC motor controller using Hall sensor-based 6-step commutation with PWM speed control. The system uses a PIC18F46K22 microcontroller and IR2101 gate drivers for driving the MOSFET bridge.
  • ✅ 3-phase BLDC control using 6-step commutation
  • ✅ Speed control using analog potentiometer (ADC) with PWM
  • ✅ Direction control with REVERSE button
  • ✅ Start/Stop functionality
  • ✅ LED indicators for direction status
  • ✅ Open Hardware under CERN OHL v2 license
⚙️ Hardware
  • Microcontroller: PIC18F46K22
  • Gate Driver: IR2101
  • MOSFETs: IRF540N or IRFZ44N
  • Sensors: Hall sensors for rotor position
  • PCB: 4-layer (2 signal, 2 GND planes)
  • Simulation: Proteus for pre-validation
  • CAD: Altium Designer for schematic and layout
Firmware
  • Developed in CCS C for the PIC18F46K22.
  • Uses interrupts for Hall sensor capture and commutation lookup table.
  • ADC reads potentiometer voltage to control PWM duty cycle.
  • PWM generated for speed control.
  • GITHUB- 3-Phase BLDC Motor Controller
    https://github.com/Fawwazoa/bldc-motor-controller
  • GitHub- 3-Phase BLDC Motor Controller
243
7
  • Like( 7 )
