The Aussie Repair Guy
  • 1 Projects
  • 2 Followers
  • Jan 09,2025
Simple E-Paper data feed viewer
Check and display data from various text based feeds
This is the Arduino code to accompany the video on youtube:
https://youtu.be/1nmMAhbYg0w
Remember to set the WIFI password and SSID where indicated
You can change the feed url to any .txt based feed.
Code:
#include <Arduino.h>
#include "EPD.h"
#include <WiFi.h>
#include <SPI.h>
#include <HTTPClient.h>  // Include HTTPClient for making HTTP requests
#define Max_CharNum_PerLine 66 // 792/12  - set max screen characters per line
uint8_t ImageBW[27200];       // Buffer for black and white image data
// Button Pin Definitions
#define BTN_MENU 2   //menu button on IO 2
#define BTN_UP 6     //UP   button on IO 6
#define BTN_OK 5     //OK   button on IO 5
#define BTN_DOWN 4   //DOWN button on IO 4
#define BTN_EXIT 1   //EXIT button on IO 1
// Text to display for each button
const char* btnMessages[] = {
  "Menu Button Pressed",    //message 1
  "Up Button Pressed",      //message 2
  "Checking for RSS Feed Info      ",      //message 3
  "Down Button Pressed",    //message 4
  "Exit Button Pressed"     //message 5
const char* ssid = "yourSSID";                    //insert your WIFI SSID here between the quotation marks
const char* password = "yourwifipassword";        //same here with password - insert between quotation marks
int currentLine = 0;  // To track which set of 9 lines to display
unsigned long lastUpdate = 0;  // For timing the 30-second interval
const unsigned long updateInterval = 30000;  // 30 seconds interval
unsigned long lastRSSFeedUpdate = 0;  // Last time the RSS feed was fetched
const unsigned long RSSFeedUpdateInterval = 300000;  // 5 minutes (in milliseconds)
bool wifiConnected = false;  // WiFi connection status
std::vector<String> rssFeed;  // Global RSS feed storage
void connectToWiFi() {
  WiFi.begin(ssid, password);
  Serial.print("Connecting to Wi-Fi...");
      delay(500);
      Serial.print(".");
  wifiConnected = true;
  Serial.println("\nConnected to Wi-Fi!");
  Serial.print("IP Address: ");
  Serial.println(WiFi.localIP());
// Function to fetch RSS feed and return a list of lines (ignoring empty lines)
std::vector<String> fetchRSSFeed() {
  HTTPClient http;
  std::vector<String> lines;
//----------------------------------- data feed retrieveal ----------------------------------------------------------------------
  http.begin("https://services.swpc.noaa.gov/text/aurora-nowcast-hemi-power.txt");   //alther the location of the data feed here
  int httpCode = http.GET(); // Send HTTP GET request
//------------------------------------ this only seems to work with .txt feeds, not .rss feeds.----------------------------------
  if (httpCode == 200) {  // Check if the request was successful
    String feed = http.getString();
    int startIdx = 0;
    int endIdx = feed.indexOf("\n", startIdx);
    // Parse each line, skipping empty lines
    while (endIdx != -1) {
      String line = feed.substring(startIdx, endIdx);
      if (line.length() > 0) {
        lines.push_back(line);  // Add line to list if it's not empty
      startIdx = endIdx + 1;
  } else {
    Serial.println("Error in HTTP request");
  http.end();  // Close the connection
  return lines;
  // Screen Power Initialization
  pinMode(7, OUTPUT);
  digitalWrite(7, HIGH);
  connectToWiFi();
  // EPD Initialization
  EPD_GPIOInit();
  Paint_NewImage(ImageBW, EPD_W, EPD_H, Rotation, WHITE);
  Paint_Clear(WHITE);
  EPD_FastMode1Init();    //set to fast mode?
  EPD_Display_Clear();    //clear display
  EPD_Update();           //update display buffer
  EPD_GPIOInit();         //init general purpose IO
  // Display WiFi Status Message
  if (wifiConnected) {
    Long_Text_Display(0, 0, "WiFi Connected!", 24, BLACK);
    Long_Text_Display(0, 30, "Push OK button to start RSS feed", 24, BLACK);
  } else {
    Long_Text_Display(0, 0, "WiFi Connection Failed", 24, BLACK);
  // Initial Message Display
  EPD_Display(ImageBW);   //set to black and white mode?
  EPD_FastUpdate();       //fast update?
  EPD_DeepSleep();        //put display to sleep.
  // Button Initialization
  pinMode(BTN_MENU, INPUT_PULLUP);
  pinMode(BTN_UP, INPUT_PULLUP);
  pinMode(BTN_OK, INPUT_PULLUP);
  pinMode(BTN_DOWN, INPUT_PULLUP);
  pinMode(BTN_EXIT, INPUT_PULLUP);
  // Load initial RSS feed
  rssFeed = fetchRSSFeed();
  lastRSSFeedUpdate = millis();
  // Re-check RSS feed every 5 minutes
  if (millis() - lastRSSFeedUpdate >= RSSFeedUpdateInterval) {
    Serial.println("Re-fetching RSS feed...");
    lastRSSFeedUpdate = millis();  // Reset the timer
  // Check Button Presses
  if (digitalRead(BTN_OK) == LOW) {
    displayButtonMessage(btnMessages[2]);
  // Check if 30 seconds have passed to update the display
  if (millis() - lastUpdate >= updateInterval) {
    // Only update the screen if RSS feed is available
    int totalLines = rssFeed.size();
    if (totalLines > 0) {
      // Calculate the starting line based on current position
      int startLine = currentLine * 9;
      int endLine = startLine + 9;
      // Only update the screen if necessary (reducing flicker)
      EPD_FastMode1Init();  // Fast mode for partial updates
      for (int i = startLine; i < endLine && i < totalLines; i++) {
        Long_Text_Display(0, (i - startLine) * 30, rssFeed[i].c_str(), 24, BLACK);
      // Update the currentLine for the next set of 9 lines
      currentLine++;
      // If we reach the end of the feed, reset to display from the beginning
      if (startLine + 9 >= totalLines) {
        currentLine = 0;
      // Refresh the display (only partial update here)
      EPD_FastUpdate();
      EPD_DeepSleep();  // Put display to sleep after updating
    } else {
      Serial.println("Failed to fetch RSS content.");
    // Update the last update time
    lastUpdate = millis();
  delay(200); // Debounce delay
// Display button acknowledgment on screen
void displayButtonMessage(const char* message) {
  clear_all();
  Long_Text_Display(0, 30, message, 24, BLACK);
  EPD_FastUpdate();
  EPD_DeepSleep();
void clear_all() {
  EPD_Update();
// Display text on screen
void Long_Text_Display(int x, int y, const char* content, int fontSize, int color) {
  int length = strlen(content);
  int i = 0;
  char line[Max_CharNum_PerLine + 1]; // +1 for null terminator
  while (i < length) {
    int lineLength = 0;
    memset(line, 0, sizeof(line)); // Clear line buffer
    while (lineLength < Max_CharNum_PerLine && i < length) {
      line[lineLength++] = content[i++];
    EPD_ShowString(x, y, line, fontSize, color);
    y += fontSize; // Move to the next line
    if (y >= 272) break; // Stop if out of screen space
18.1k
15
  • Comments( 1 )
  • Like( 15 )
  • Nice project.
    Jan 20,2025 0 comments
    Reply
