cris
  • 74 Projects
  • 23 Followers
  • Aug 03,2024
Simple temperature Regulator
Simple electronic circuit.
  • Kicad
Simple temperature regulator
Circuit description
The temperature controller uses as a temperature transducer a thermistor connected diagonally to a Wheatstone bridge. Transistors Q1 and Q2 form a flip-flop amplifier with a hysteresis loop in the 'YES / NO' system. This hysteresis is ensured by the value of resistor R5. If you want to increase the hysteresis effect to about 3% of the default value, using the RV1 potentiometer, then the value of R5 will increase to 100Ω. The temperature control range is +30 ... 95 * C. The thermistor should have an 10KOhm resistance at 25°Celsius .
Bill of materials available in the download section, and the schematic as well.
Have fun with it!
12.4k
15
  • Like( 15 )
