Dharani Creations
Track Anything in Real-Time! GPS + NodeMCU Project
This is a real-time GPS tracking project built around the NodeMCU ESP8266 module and a Neo‑6M GPS module, powered by Wi-Fi rather than cellular networks
  • NodeMCU
  • GPS NEOM6
  • Jumper Wires
  • Fritzing
Project Overview: Real‑Time GPS Tracker with NodeMCU (No SIM Required)
Platform:
This is a real-time GPS tracking project built around the NodeMCU ESP8266 module and a Neo‑6M GPS module, powered by Wi-Fi rather than cellular networks .
Key Features:
  • Simple, cost-effective GPS tracking without SIM card or GSM network
  • Real-time transmission of GPS data (latitude, longitude, accuracy) over Wi‑Fi to a web or map interface (typically Google Maps)
  • The project is attributed to Dharani Creations, recently published (~last week)
  1. NodeMCU ESP8266 board – microcontroller with built-in Wi‑Fi
  2. Neo‑6M GPS module – provides NMEA GPS data via serial
  3. Micro‑USB cable – for power and programming
  4. Optionally a display (LCD/OLED) or serial interface for basic debugging (per other read‑alike tutorials)
 Circuit Wiring
  • GPS TX → NodeMCU RX
  • GPS RX → NodeMCU TX
  • GPS power: 3.3 V (or VCC to VIN depending on board)
  • NodeMCU powered over USB from PC or power bank
  • (Optional) Add a display to show coordinates locally in real time
 Firmware & Code Structure
  • Arduino IDE is used to write/upload code
  • Core logic:
    • Connect to predefined Wi‑Fi SSID/password
    • Read NMEA sentences from the Neo‑6M GPS to parse latitude/longitude
    • Send data periodically (e.g. every few seconds) to a server or live map interface over HTTP
    • Display or log coordinates via serial monitor or display
    • The video implies Google Maps integration for live tracking
Many tutorials (notably older ones like from JustDoElectronics or CircuitDigest) also include optional display feedback or local webserver hosting features .
 Software Workflow (General Steps)
Step Operation
1 Import Wi‑Fi + GPS + JSON libraries (e.g., SoftwareSerial, TinyGPS++, ESP8266WiFi)
2 Initialize serial ports for GPS and debug output
3 Connect to Wi‑Fi at startup
4 In loop(): read GPS data, parse coordinates
5 If fix is valid, send JSON containing coordinates and accuracy to a web endpoint or Google Maps link
6 Repeat at set intervals (e.g. every 5 seconds)
7 Optionally buffer data if offline and sync when reconnected
The code may also include minimal error handling to retry Wi‑Fi or GPS fix acquisition.
 Extended Capabilities & Enhancements
Though not explicitly shown in the video, similar projects support:
  • Local display output (e.g. using 16×2 LCD or OLED) to show live coordinates
  • Offline data buffer: Store location data if Wi‑Fi is down, then upload once it comes back
  • Web interface / dashboard powered by simple server or Google Maps API for visualization
  • Adjustable update frequency and power-saving modes for long-term deployment
  • Status messages via serial like “Connected to Wi‑Fi”, “GPS fix acquired”, or error states
 Summary
In short, the project is:
  • Built with NodeMCU ESP8266 and Neo‑6M GPS module
  • Sends your GPS coordinates over Wi‑Fi in real-time (no SIM card needed)
  • Integrates with mapping (e.g. Google Maps) to visualize live location
  • Flexible and low-cost—great for learning embedded IoT and GPS-based tracking
 Suggestions if You Want to Recreate This
  1. Gather hardware: NodeMCU + Neo‑6M module
  2. Use Arduino IDE + required libraries
  3. Implement logic to parse GPS NMEA output
  4. Establish Wi‑Fi connectivity and HTTP POST/update logic
  5. Create a map link or simple server to visualize location
  6. Optional: add display or offline buffering
  7. Test, tweak interval settings and accuracy thresholds
  • Code
    https://github.com/DharaniCreations/Track-Anything-in-Real-Time-GPS-NodeMCU-Project-No-SIM-Card-Needed-
  • Diagram
    https://github.com/DharaniCreations/Track-Anything-in-Real-Time-GPS-NodeMCU-Project-No-SIM-Card-Needed-/tree/main
55
7
  • Like( 7 )
