Device Overview
The CH591D module-Bluetooth Low Energy (BLE) and USB-C connectivity, making it ideal for low-power wireless applications that also require USB communication .
Technical Specifications
Parameter | Value / Description |
Microcontroller | CH591D |
Flash | 192+24+32 KB |
RAM | 24+2 KB |
Bluetooth | BLE 5.4 |
USB | USB 2.0 Full Speed (via USB-C connector) |
Power Supply | 3.3 V (via USB-C ) |
USB Connector | USB Type-C |
Interfaces | UART, , SPI, ADC, GPIO |
ADC | 4+1 |
GPIO | 12 |
Programming | Support ICP, ISP and IAP, support OTA wireless upgrade |
Antenna | PCB |
Board Size | 40*20mm |
Connection & Pins
Pin | Function |
USB-C | Power and USB communication |
VCC | USB VBUS |
GND | Ground |
RX / TX | UART communication |
PB7 | BOOT |
GPIOx | Multi-function (ADC, SPI) |
Use Cases
Wireless controllers or macro keypads( IMK8K )
Portable BLE-enabled gadgets
USB-HID device development
IoT modules with BLE notifications
Development and testing of BLE applications
Software Support
IDE: MounRiver Studio (official from WCH)
- WCHISPTool
Available libraries: BLE, USB HID, UART, SPI
- Datasheet...
- WCH Tools,drivers
Programming Steps:
1. Preparation
Download and install MounRiver Studio from: https://www.wch.cn
Create a new project for CH591D:
File → New → Project → CH591
Select target chip:
CH591D
2. Write Code
Write your C code (e.g., LED blink).
Make sure you have a
main()
function. -
Save your
.c
file in thesrc
directory. -
Generating HEX File
Right-click your project in MounRiver → Build Project
The generated
.hex
file will be located at:ProjectFolder/output/ch591.hex
3. USB DFU Boot Setup
CH591D can be programmed over USB if PB7 is pulled to GND during power-up.Steps:
Press and hold the button BOOT1 (PB7 = GND)
Plug in the USB cable
Release the button
The device will show up as WCHISP (depends on OS)
4. Uploading to Chip
In MounRiver go to: Tools → WCHISPTool
Or use standalone WCHISPTool -
Load the HEX file and click Download
The firmware will be flashed over USB
Prototype Notice
NOTICE: This CH591D module is a development prototype. It may contain limitations, experimental firmware, or test components. Intended for development, debugging, and testing only.
