Kapacita22uF
IMK8K-macro keyboard
The IMK8K is a smart macro keyboard with 8 mechanical switches and multiple integrated sensors/peripherals. Designed for developers, automation tasks, or educational use.
NOTE: The device does not include a microcontroller (MCU) – external MCU required (e.g., STM32, ESP32, Arduino).
NOTICE: This version of the IMK8K device is a development prototype. It is not intended for end-user deployment or mass production. It may contain errors, unoptimized circuitry, or experimental features. Use is strictly intended for testing, experimentation, and development purposes. We recommend verifying all functions before applying it to any specific use case.
Technical Specifications
Parameter Value / Type
Number of Keys 8 mechanical switches (SW1 – SW8)
Charging Circuit LTC4054ES5-4.2#PBF (Li-Ion charging at 4.2 V)
EEPROM AT24C128-HXY (128 kbit, I2C)
Temp/Humidity Sensor AHT30 (I2C)
Light Sensor Photoresistor (analog input)
IR Transmitter IR LED
IR Receiver IR module
Display OLED 0.96" I2C (SSD1306)
Storage MicroSD slot (SPI)
Power Supply 3.3 V or 5 V, battery charging supported
Battery Slot CR2032 or compatible Li-ion cell
Interfaces I2C, SPI, GPIO, SWD
PCB Dimensions 100*80
Assembly THT + SMD mixed
Connectivity & Compatibility
  • MCU Required: Yes (not included on board)
  • Recommended Platforms:CHxxx, STM32, ESP32, Arduino, Raspberry Pi Pico, nRF5...
Features & Use Cases
  • Macro productivity keyboard (e.g., for CAD, editing, coding)
  • Home automation via IR
  • OLED visual feedback display
  • Data logging or configuration via EEPROM and microSD
Board Contents
  •  8x mechanical key slots (switch + LED capable)
  •  Encoder
  •  Battery holder
  •  IR TX + RX
  •  Light sensor
  •  EEPROM
  •  AHT30 sensor
  •  OLED display
  •  Charging circuit
  •  MicroSD slot
  • ❌ No onboard MCU
BOM for CH591D modul:
ID
Name
Designator
Footprint
Quantity
0.1u
C1,C2,C3,C4,C5,C6,C7,C8
C0402
8
2
22u
C12
C1206
10n
CE1,CE2
C0603
2
4
1N5819HW1-7-F
D1,D2,D3,D4,D5,D6,D7,D8,DE1
1N5819HW1-7-F
9
5
1N5819_C437199
D9,D10
SMA_L4.4-W2.6-LS5.0-RD
2
6
EC11E18244A5
EC1
SW-TH_EC11E18244A5
SMD0805-010C-15V
F1
FUSE-SMD_L2.1-W1.4
排母2*5P 1.27MM
H1,H2,H3
HDR-TH_10P-P1.27
3
9
HDR-F-2.54_1x5
H4
HDR-F-2.54_1X5
HDR-M-2.54_1x1
J1
HDR-M-2.54_1X1
LED-0805_R
LED1
LED0805_RED
27
R1,R2,R3,R4
R0603
4
13
220
R7
R0805
330
RC1
R0805
10k
RC2
R0805
10k
RE1,RE2,RE3,RE4
R0603
4
17
RP1
R0402
RP2
R0805
0 RP4 R0603
SK6812-mini e
SW1,SW2,SW3,SW4,SW5,SW6,SW7,SW8
SK6812-mini e
8
21
SW_MSK-12C01-07
SW9
SW-SMD_MSK-12C01-07
LTC4054ES5-4.2#PBF
U3
SOT-23-5_L3.0-W1.7-P0.95-LS2.8-BL
JUMPER
JP1 VBUS/+5V INPUT FOR U3V3(3.3V REGULATOR) NC FOR CH591D MODUL
JP2 5V/3.3V POWER FOR U2 NC FOR CH591D MODUL
JP3 5V/3.3V POWER FOR U1 NC FOR CH591D MODUL
JP4 VBUS/+5V POWER FOR CHARGER VBUS CON.
JP5 BAT+/VBAT LIR2032 POWER FOR IMK8K(BAT+) OR CR2032 FOR RTC (VBAT) NC
JE1 5V/3.3V POWER FOR ENCODER 3.3V FOR CH591D
743
9
  • Like( 9 )
