Overview
This project demonstrates how to convert a standard bicycle into a high-performance electric bike (e-bike) capable of reaching speeds up to 50 km/h. It involves integrating an electric motor, battery system, throttle controller, and other essential electronics. The project blends mechanical engineering, electrical systems, and DIY fabrication skills to build a cost-effective and powerful personal transportation solution.
Project Goals
Convert a regular bicycle into an electric-powered vehicle
Achieve a top speed of ~50 km/h
Ensure good range (20–40 km depending on battery)
Maintain balance between speed, torque, and safety
Build a system that supports throttle control and regenerative braking (optional)
Components Used
Component | Description |
Brushless DC (BLDC) Hub Motor | 500W–1000W rear or front wheel hub motor |
Lithium-ion Battery Pack | 36V or 48V, typically 10Ah–20Ah |
Motor Controller | Matched to motor voltage/current, with hall sensor support |
Throttle (Thumb or Twist) | Sends variable voltage signal to controller |
Pedal Assist System (Optional) | Enables hybrid manual + motor riding |
Display Unit / Speedometer | Shows speed, voltage, distance |
Controller Box / Mounts | Protects electronics from weather/shock |
Wiring Harness + Connectors | High-current cables, XT60/XT90 or Anderson connectors |
Fuses / Circuit Breaker | Overcurrent protection |
Mechanical Brake System | Disc or V-brake with possible motor cutoff |
How It Works
Throttle Input: The rider uses a twist or thumb throttle to signal the motor controller.
Controller Logic: Based on throttle position and battery status, the controller sends power to the motor.
Motor Drive: The BLDC hub motor rotates the wheel, propelling the bike.
Speed Regulation: Speed can be limited by the controller or manually via throttle input.
Battery Supply: A lithium-ion battery supplies DC power to the controller and motor. Proper BMS (Battery Management System) manages charging/discharging safely.
Build Process (Simplified)
Mount the Hub Motor Wheel:
Replace rear or front wheel with the motor-integrated hub.
Ensure axle fit and torque arms are installed to prevent rotation.
Install Battery and Controller:
Mount battery pack inside the bike frame or on a rear rack.
Mount the controller in a waterproof box near the frame.
Wire Everything Up:
Connect motor phase wires and hall sensor wires to the controller.
Wire throttle, brakes (cutoff), display, and battery connections.
Secure and weatherproof all exposed terminals.
Test and Tune:
Power on and check motor rotation.
Use the display to monitor voltage, current, and error codes.
Test ride and adjust throttle response and speed limits.
Performance Metrics
Parameter | Estimate (Varies by Setup) |
Top Speed | ~45–50 km/h |
Range | 20–50 km (depending on battery size & terrain) |
Motor Power | 500W–1000W |
Voltage | 36V / 48V |
Charging Time | 4–6 hours |
Advantages
Eco-friendly personal transportation
Customizable performance (speed, range)
No fuel cost, minimal maintenance
Great learning project for e-mobility and power systems
Safety Tips
Always wear a helmet
Use brake cutoff switches to avoid throttle-while-braking
Mount battery securely and away from impact zones
Include fuses or BMS for battery protection
Ensure legal compliance with local e-bike laws (speed/power limits)
???? Optional Upgrades
Regenerative Braking
Cruise Control
Bluetooth App Integration for stats monitoring
Solar Charging
Smart BMS with individual cell monitoring
LED lights and horn integration
