Adrirobot
How to Install MicroPython on the Raspberry Pi Pico W
Let's see how to install the MicroPython programming language and the Thonny development environment on the Raspberry Pi Pico.
This is the English translation of the Italian version you can see on my blog: Come installare MicroPython sulla Raspberry Pi Pico
Key Features of the Raspberry Pi Pico W
The Raspberry Pi Pico W (datasheet) is built around the RP2040 microcontroller designed by Raspberry Pi. Its specifications include:
  • RP2040 microcontroller (datasheet) (dual-core ARM Cortex-M0+ @ 133 MHz)
  • 264 KB of SRAM
  • 2 MB of QSPI flash memory
  • 802.11n Wi-Fi connectivity (2.4 GHz) via Infineon CYW43439 chip (datasheet)
  • 26 multifunction GPIO pins
  • Support for 2× I2C, 2× SPI, 2× UART
  • PWM output on 16 pins
  • Three 12-bit analog input pins
  • On-chip clock and timer with year, month, day, weekday, hours, seconds, and automatic leap year calculation
  • On-chip temperature sensor connected to a 12-bit ADC
  • Micro-USB port for power and programming
  • Operating voltage: 1.8 V – 5.5 V
  • Form factor: 21 mm × 51 mm
  • Operating temperature range: –20 °C to +85 °C
Thanks to its compact size, it's perfectly suited for breadboards, prototyping, and DIY projects.
Pico
NOTE :The installation is similar for the Pico, Pico W, Pico 2 version
✅ Summary
  1. Download the latest firmware from the official MicroPython site.
  2. Boot the Pico W in bootloader mode (hold BOOTSEL while connecting).
  3. Copy the .uf2 file to the Pico drive to flash it.
  4. Use Thonny or a serial terminal to code and interact with MicroPython.
  5. Test with a simple LED blink script.
📌What You’ll Need
  • Raspberry Pi Pico
  • Micro-USB cable (for data, not just charging)
  • Computer running Windows, macOS, or Linux (instructions based on Windows 10)
  • Internet connection
Raspberry Pico
🔧 Additional Tips
  • If you bought a Pico or Pico W (not Pico H or WH), it won't come with header pins soldered—you'll need to solder them yourself.
  • You can use a small fine-tip soldering iron (~25–30 W) and lead-free solder (97% tin, 3% copper, 1 mm diameter).
Step 1: Download the MicroPython Firmware
  1. Go to the official MicroPython website and navigate to the Pico W firmware page: https://micropython.org/download/rp2-pico-w/
  2. Download the latest .uf2 firmware file (e.g., version v1.25.0 dated 2025-04-15).
  3. Save the .uf2 file to your computer.
Step 2: Put the Pico W into Bootloader Mode
  1. Hold down the BOOTSEL button on the Pico.
  2. Connect the Pico W to your computer using the micro-USB cable.
  3. Release the BOOTSEL button after about 1–2 seconds.
  4. The computer should detect a new USB drive labeled RPI‑RP2.
You’ll see two files: INDEX.HTM and INFO_UF2.TXT
Step 3: Install MicroPython
  1. Drag and drop the downloaded .uf2 file onto the RPI‑RP2 USB drive.
  2. The Pico will automatically reboot after a few seconds.
  3. MicroPython is now installed!
Step 4: Interact with MicroPython
You can use either a serial-terminal or an integrated development environment (IDE). A beginner-friendly method is to use Thonny:
  • Thonny is a free, open-source Python IDE ideal for beginners.
How to Install and Configure Thonny:
  • Install and launch the application.
  • Go to Tools → Options → Language, select your preferred language, and restart Thonny.
  • Then go to Tools → Options → Interpreter, and choose the Pico W as the interpreter.
  • Select:
    Interpreter: MicroPython (Raspberry Pi Pico)
    Port: It should be detected automatically (e.g., COMx or ttyACM0)
Click OK
🎺​You can now write MicroPython code and upload it directly to the Pico.
Step 5: Run a Test Program (Blinking LED)
The Pico W has a built‑in LED connected on GPIO 15 (note: GPIO 25 is used on original Pico). Type this example in Thonny:
from machine import Pin
import time led = Pin("LED", Pin.OUT) # Built-in LED on GPIO 15
while True:
led.toggle()
time.sleep(1) # 1 second pause
Running this will make the LED blink at 1 second intervals. To start the program click on the Run button
278
5
  • Like( 5 )
