Kapacita22uF
PCB Keychain -Dog V2 (Mirrored Version)
Keychain with3*ws2812b-2020 LEDs, MCU ch32x035,IR TX and USBC
PCB Keychain “Dog” V2 (Mirrored Version)
This PCB keychain is a mirrored version of the previous “Keychain dog v1” . It follows the same playful dog-shaped PCB aesthetic but adds USBC,IR TX, powered by a CH32X035 microcontroller. Designed as a complement to the original version, the two can be connected physically or via logic.
Technical Specifications
Parameter Description
Microcontroller CH32X035 (32-bit, RISC-V, WCH)
USB Connector USB Type-C
RGB LEDs 3× WS2812B-2020 (addressable RGB)
White LED 1× high-brightness 1W SMD LED
Touch Sensors 2× TP223-BA6 capacitive sensors
Power Supply 5V via USB-C
Interfaces USB, GPIO
Supported Protocols USB HID / Custom logic (based on firmware)
PCB Dimensions 50*59
Interconnect Option Connectable with Dog V1 (physical/logical pairing)
Component Summary
  • CH32X035 MCU – 32-bit microcontroller with native USB and high-speed GPIO.
  • 3× WS2812B-2020 – Compact addressable RGB LEDs for animations.
  • 1W SMD LED – High-brightness white LED
  • 2× TP223-BA6 – Capacitive touch inputs .
  • USB-C – Provides power and potential USB interface.
Use Cases
  • Light-up decorative or interactive keychain
  • Demonstration of embedded electronics and PCB design
  • USB HID button or macro device
  • Learning tool for working with USB HID,LEDs and capacitive sensing
Development Info
Feature Support
IDE MounRiver Studio (WCH)
Programming USB DFU, optional SWD
Language C / C++ (WCH SDK)
LED Control WS2812 libraries / GPIO timing
Touch Input Digital output from TP223
Compatibility
  • Mirrored PCB layout relative to Dog V1
  • Can be joined physically or logically for pairwise applications
  • Shared power/signal lines for unified logic
Prototype Notice
NOTICE: The Dog Keychain V2 PCB is an untested prototype. Circuitry and functionality have not been verified yet. Use is currently limited to visual inspection, layout testing, and pre-production analysis.
3.6k
16
  • Like( 16 )
