SELAHATTİN BULUT
RC BOAT
I designed and built an RC ship using a 3S battery and a 1400KV brushless motor, with a custom-made drive shaft from a modified concrete nail, Arduino-NRF control system, and waterproofed components
RC BOAT
  • lityum-ion battery
    X 5
  • 3s bms
  • A2212 2212 brussles Drone Motor
  • Gearwell RC Boat Shaft Propellers, 4mm Drive Shaft Assembly for
  • Bambu Lab PLA Filament
    Bambu Lab
  • brussles motor driver
  • M3 x 3mm Female Thread Brass Knurled Threaded Insert Countersunk
  • 5.5x2.1mm Female + Male CCTV DC Power Connector Adapter
  • M3 10mm YHB inox
    X 10
  • switch
    X 2
  • joystick
    X 2
  • 2s bms
Hello, this is the 2nd version of my rc boat design that I made before. There is a shaft in my vehicle ready in the dimensions of Shaft Length: Approx. 10 cm/3.9 inches Shaft Sleeve: Approx. 5 cm/2.0 inches Shaft Diameter: Approx. 4 mm/0.15 inches.
You need to apply liquid gasket under the cover to seal it.
Screw dimensions are M3 10mm.
The hole on the back is the battery charging hole.
The rectangular space above it is the key hole. I recommend that you either waterproof the key or seal it with a bag.
The hole on the top of the vehicle is the antenna hole.
You need to insulate all of these holes with silicone.
Brushless motor as the motor.
Processor and connection type arduino nano and nrf
  • receiver
    https://github.com/SeloBulutt/3D-RC-Boat/tree/main/receiver/al_c_
  • transmitter
    https://github.com/SeloBulutt/3D-RC-Boat/tree/main/transmitter/verici
RC BOAT
14.7k
15
  • Like( 15 )
