Luc Paquin
  • 32 Projects
  • 11 Followers
  • Dec 11,2024
Project #15: Environment – Soil Moisture Sensor – Mk20
https://www.donluc.com/?p=4209
https://youtu.be/pucAV2543rc
https://www.tiktok.com/@luc.paquin8/video/7446840226711964934
https://www.hackster.io/luc-paquin/project-15-environment-soil-moisture-sensor-mk20-ff1b4b
#DonLucElectronics #DonLuc #Arduino #ASM #Project #Patreon #Electronics #Microcontrollers #IoT #Fritzing #Programming #Consultant
Soil moisture is the critical parameter in agriculture. If there is a shortage or overabundance of water, plants may die. At the same time, this data depends on many external factors, primarily weather conditions and climate changes. That is why it is so vital to understand the most effective methods for analyzing soil moisture content.
This term refers to the entire quantity of water in the ground’s pores or on its surface. The moisture content of soil depends on such factors as weather, type of land, and plants. The parameter is vital in monitoring soil moisture activities, predicting natural disasters, managing water supply, etc. This data may signal a future flood or water deficit ahead of other indicators.
DL2411Mk03
1 x SparkFun RedBoard Qwiic
1 x Gravity: Analog Soil Moisture Sensor
2 x LED
1 x ProtoScrewShield
1 x USB Battery Pack
1 x USB Micro-B Cable
ASM - A0
LEDP- 13
LEDG- 12
VIN - +5V
GND - GND
DL2411Mk03p
DL2411Mk03p.ino
getSoilMoisture.ino
setup.ino
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
Luc Paquin – Curriculum Vitae - 2024
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
484
5
  • Like( 5 )
