SmartHome yourself
  • 12 Projects
  • 29 Followers
  • Jun 13,2025
Smart Garage-Door control with animated RGB-LED
  • Home Assistant
    Open Source
  • EspHome
(with or without Home Assistant)
📌Standalone:
  • automated RGB-LED-Animation when door is opening / closing
📌Additional features when using with Home Assistant:
  • see door-status (open / closed / moving)
  • control door with Home Assistant
  • build automations / notifications based on sensors/switch
  • configure speed, anim-width and delays
Video
https://youtu.be/NvoPeyG30WA
📌Pins:
  • D1: Button
  • D2: RGB-LED Stripe
  • D5: Sensor (open)
  • D6: Sensor (closed)
  • D7: Relay
📌Used products:
📌Additional Links/Codes/Files
ESPHome Code: https://smarthomeyourself.de/hc_downloads/esphome_garagentor.txt
ESPHome Binary (Standalone): https://smarthomeyourself.de/hc_downloads/esphome_garagentor_10ms_150leds_15sec.bin
3D-Print Case (STL): https://www.thingiverse.com/thing:4963861
⚠️ Note on RGB LED Compatibility (WS2812 or similar)
This PCB includes a BOB-12009 level shifter based on a bidirectional MOSFET. While suitable for I²C, it is not ideal for WS2812-type LEDs, especially when using fast or complex effects. You may experience flickering or signal issues due to slow signal rise/fall times.
✅ Workaround – Skip the level shifter:
If the distance to the first LED is very short (a few centimeters), you can bridge LV2 and HV2 directly and leave the level shifter unpopulated.
👉 Do not install the level shifter in this case – it will interfere with the signal.
✅ Workaround 2 – Use a proper level shifter:
👉 For longer distances or improved reliability, use a proper unidirectional level shifter like the 74AHCT125 or 74HCT14.
* Note: The links above are affiliate links. If you use them, I may earn a small commission – this helps support my projects at no extra cost to you.
  • mount top
    Halter_Oben_PCBWay_Community_392861456684b581de6885.STL
    Download(24)
  • case lid
    garagentorbeleuchtung_Deckel_PCBWay_Community_183288772684b583718b6f.STL
    Download(16)
  • case
    garagentorbeleuchtung_PCB_Case_PCBWay_Community_487211187684b5845244bd.STL
    Download(18)
  • mount door 1
    Halter_Tor_-_Halter_Tor-1_PCBWay_Community_2079436099684b58542c9d2.STL
    Download(12)
  • mount bottom
    Halter_Unten_PCBWay_Community_1387980952684b586ec4abe.STL
    Download(15)
  • mount plate
    Halter_Tor_-_Halter_Tor_Platte-1_PCBWay_Community_1148126364684b587e41ead.STL
    Download(20)
6.3k
16
  • Like( 16 )
