Building your own computer is a rewarding experience, and with the rise of powerful single-board computers (SBCs) like the Raspberry Pi 5 and Jetson Orin Nano, you no longer need a giant tower to have a capable machine. A compact, stylish, and functional case can turn your SBC project into a sleek mini PC.
One such option is the Elecrow Mini PC Case, a DIY-friendly enclosure designed specifically for the Raspberry Pi 5 and Jetson Orin Nano. It’s more than just a box; it's a complete solution with integrated cooling, a status display screen, and expansion capabilities. Since this case is shipped unassembled, this guide will walk you through the general steps to put it all together.
Before you start, lay out all the components to ensure you have everything. Your package should include:
You will also need your single-board computer: either a Raspberry Pi 5 or a Jetson Orin Nano.
The case is designed with three RGB fans for excellent cooling.
The PCBA is the brain of the case's features. It manages the power button, OLED screen, and fans.
One of the coolest features is the built-in 1.3-inch OLED screen, which can display system status in real-time.
If you are using a Raspberry Pi 5 and want to add high-speed storage, this case has you covered. The PCBA includes a PCIe M.2 socket. You can install an NVMe SSD (sizes 2230, 2242, 2260, and 2280 are supported). Simply insert the SSD into the slot and secure it with the mounting screw.
With all the internal components installed and connected, it's time to close up the case. Carefully assemble the remaining acrylic and aluminum alloy panels. Ensure all ports (USB, HDMI, Power) are properly aligned with the cutouts, and use the final set of screws to secure the entire chassis.
Once assembled, connect your monitor, keyboard, mouse, and power supply. Press the power button, and your mini PC should come to life! You'll see the RGB fans light up and the OLED screen display key system information, like temperature or CPU usage.
You've successfully built a compact, powerful, and cool-looking mini PC that’s perfect for everything from a home media center to a development environment for your next great project.
Ready to build your own? You can find this versatile Mini PC Case at Elecrow:
View Product at Elecrow
