avi patel
AI voice assistant
An AI‑powered voice companion that listens to your questions, fetches live answers from the web, and speaks.
AI voice assistant
  • INMP441 MEMS Microphone
    X 1 fenxiang
  • MAX98357 I2S Amplifier
    X 1 fenxiang
  • Micro SD Card Reader
    X 1 fenxiang
  • 16×2 LCD Display Green Backlight
    X 1 fenxiang
  • I2C Module for 16×2 (1602) Character LCD
    X 1 fenxiang
  • ESP32 Development Board | Doit DevKit V1 | powerful Wroom32 modu
    X 1 fenxiang
  • 6 x 6 x 8mm Tactile Pushbutton
    X 1 fenxiang
  • 8Ohm 2W Cavity Speaker | High-quality Sound
    X 1 fenxiang
1. Introduction & Key Features
My project is a real-time AI voice assistant built on an ESP32. It listens to your questions, transcribes them via Deepgram, queries ChatGPT for up-to-date answers, then speaks back through an I²S amp—all while showing each step on a 16×2 LCD display. This makes it a hands-free, web-connected assistant without needing a PC.
  • Live Web Data: Fetch news, weather, stock quotes, or any current event.
  • Local Logging: Records every question (WAV).
  • Clear UI: 16×2 LCD shows “Ready for Ans...”, “record start...”, “Speech to text”, and the actual text.
  • Portable Power: Runs from any USB charger or power bank—no batteries to worry about.
2. Hardware Design & Assembly
All pin-out and wiring details can be found in the Schematic and Layout section. In brief, the core modules are:
  • ESP32-WROOM-32: Main controller with Wi-Fi & I²S
  • INMP441 I²S Mic: Digital microphone
  • MAX98357A Amp: I²S audio output to speaker
  • microSD Module: WAV recording & logs
  • 16×2 I²C LCD: Status display
  • Pushbutton: Record trigger
3. Project Demonstration Video
See it in action:
https://drive.google.com/file/d/1I4ZKJhOAJsSllxNhRCoU3JL7TKS1CD7C/view?usp=drivesdk
4. Software Workflow & Code
st=>start: Button Press
rec=>operation: Record WAV to SD
stt=>operation: Deepgram STT → Text
gpt=>operation: ChatGPT API → Reply Text
tts=>operation: OpenAI TTS → Audio
play=>end: Play via I²S → LCD shows steps
st->rec->stt->gpt->tts->play
  1. Initialize Peripherals (I²S, SD, LCD, Wi-Fi)
  2. Record Audio: Hold button → WAV saved to SD.
  3. Transcribe: Upload WAV to Deepgram → receive plain text.
  4. Chat & TTS: Send text to ChatGPT → get reply → send reply to OpenAI TTS.
  5. Playback: Stream audio through MAX98357A → display messages.
  6. Loop: Ready for next query.
Code Highlights:
  • lib_audio_recording.ino – I²S + SD card WAV writer
  • lib_audio_transcription.ino – HTTPS POST to Deepgram STT
  • lib_OpenAI_Chat.ino – ChatGPT Completions API handler
  • lib_audio_tts.ino – OpenAI TTS playback routine
  • main.ino – Orchestrates button, LCD, and state machine
5. Reference Code
Find the complete source code and documentation on GitHub:
https://github.com/kaloprojects/KALO-ESP32-Voice-ChatGPT
6. Step-by-Step Build Tutorial
  1. Solder headers to each module.
  2. Wire modules per the PDF’s pin diagram.
  3. Flash firmware via Arduino IDE
  4. Insert a FAT32-formatted microSD card.
  5. Power via USB charger—watch the LCD boot.
  6. Hold the button, speak—watch and listen!
7. Lessons Learned & Pitfalls
  • I²S Buffering: Tune buffer sizes to prevent underruns.
  • Network Timeouts: Implement retries for STT and GPT calls.
  • Power Stability: Use a reliable USB supply to avoid drops during Wi-Fi.
Conclusion
This project seamlessly integrates embedded audio I/O, cloud-based AI, and real-time web access into a user-friendly device—ideal for anyone looking to explore AI assistants on the go.
  • AI voice assistant code
    ESP32_Voice_ChatGPT_20250404_14978312686a12f1908f1.zip
    Download(7)
  • pin connection and workflow
    elecrow_project_88776222686a171fdfa7f.pdf
    Download(4)
AI voice assistant
324
8
  • Like( 8 )
