Dharani Creations
IoT-Based Rain-Controlled Clothes Shelter
A weather-responsive clothes shelter that automatically moves your drying laundry under cover when it rains, and returns it back once the skies clear—all managed via IoT.
  • NodeMCU
  • DHT11 Temperature & Humidity Sensor
    X 1 fenxiang
  • IR Flame Detector module
  • Crowtail- Gas Sensor(MQ3) 2.0
  • Ultrasonic Sensor - HC-SR04
  • SG90 Micro-servo motor
  • 5V 2.5A Switching Power Supply
    Digilent
    X 1 fenxiang
  • Fritzing
  • Blynk Platform
Project Overview
Components & Tools
  • Controller: NodeMCU (ESP8266)
  • Sensing: Rain sensor module
  • Actuation: Servo motor (or DC motor / actuator) controlling the shelter mechanism
  • Connectivity: Blynk IoT app for remote monitoring and notification
  • Structure: A mechanical frame (e.g. sliding or folding shelter) attached to the motor and clothesline
Optional additions in similar designs include LDR light sensors, temperature/humidity sensors, and solar power modules
 Working Principle
  1. Rain Detection: A rain sensor continuously monitors for drops.
  2. Signal Processing: When rain is detected, the sensor sends a signal to the NodeMCU.
  3. Motor Activation: The NodeMCU commands the servo/motor to move the clothesline and/or shift a protective roof or cover over the clothes.
  4. Reversal: Once the rain stops, the system reverts to its initial position to resume drying.
  5. Notifications: Alerts and real-time status can be sent to and monitored via the Blynk mobile app
This setup ensures the clothes are protected automatically without manual intervention, reducing the risk of re-washing or clothes getting soaked unexpectedly
 Step-by-Step Construction Guide
1. Setup Hardware
  • Mount NodeMCU on a breadboard or PCB.
  • Wire the rain sensor: VCC to 3.3 V, GND, signal to a GPIO pin (e.g. D2).
  • Wire the servo motor: 5 V (or external supply), GND, signal to a PWM-capable pin (e.g. D9).
  • Secure a mechanical frame that supports covering/uncovering the clothesline via motor motion. Use linkage rods, hinges, or actuators depending on design.
2. Embed Software & IoT
  • Install Arduino IDE with ESP8266 board support.
  • Write code to:
    • Read rain sensor digital input.
    • Drive servo/motor (e.g. 0° = open, 90° = closed).
    • Send real-time status to the Blynk cloud.
  • Upload the script to NodeMCU.
  • Use Blynk to create a mobile interface: buttons, status LEDs, push notifications for weather-triggered actions.
3. Test & Refine
  • Simulate rain by dripping water; observe how quickly and accurately the shelter moves.
  • Tune servo angles and delays for smooth operation.
  • Use Blynk to manually control or override auto behavior if needed.
4. Optional Enhancements
  • Solar power to run autonomously.
  • LDR sensor to factor in sunlight—prevent bringing clothes in just because it’s rainy at night Additional sensors (humidity, temperature) to improve context-aware automation.
  • Weather forecast integration via APIs to preemptively retract clothes ahead of forecasted rain.
 Key Benefits
Benefit Description
Hands-Free Protection No need to monitor weather manually.
Saves Time & Effort No more re-washing or rushing in rain.
Smart Notifications Real-time alerts via smartphone.
Expandable & Affordable Easy to scale or customize with minimal cost.
Similar Arduino-based prototypes using rain sensors and servos achieve this functionality using affordable hobby electronics .
 Inspiration from Related Projects
  • Arduino Uno + Rain sensor + Servo Motor — many hobby builds rely on this basic configuration for rain-activated shelter systems. Arduino Nano version— drops in easily; servo moves clothesline under a protective cover automatically
  • Smart Clothesline with Blynk, LDR & Rain Sensor— controls sun and rain protection with real-time mobile contro.
 Summary
This project integrates IoT (NodeMCU) with rain sensing, motor control, and app connectivity (Blynk) to build a smart cover system for clothes drying. It automatically protects your laundry from rain and restores its drying position when weather improves—all without manual effort.
If you'd like, I can also help you with:
  • Sample Arduino + Blynk code snippets
  • Mechanical design ideas (e.g. hinge layout, pulley arrangement)
  • Selecting appropriate sensors and motor specifications
  • Expanding features like solar power or predictive weather logic
Let me know which direction you'd like to dive deeper into!
  • CODE
    https://github.com/DharaniCreations/IoT-Based-Rain-Controlled-Clothes-Shelter-/blob/main/Smart_Home_Automation.ino
  • GITHUB
297
8
  • Like( 8 )
