Budhi Prayoga
Electro Vibration (EVIB) Meter - Soil Density Detector
This project aims to accelerate the process of identifying soil density values from the subgrade, subbase, and base course layers by integrating vibration, speed, and acceleration sensors connected to an Arduino Mega 2560 microcontroller. The data generated enables real-time monitoring and adjustment during the compaction process in accordance with SNI (Indonesian National Standard) 1738-2011.
  • Robotdyn Arduino Mega 2560 Built-In WiFi
    Robotdyn France
  • Accelero, Gyro and velocity sensor GY-87 10DOF MPU6050 + QMC5883
    Tiongkok, China
  • LCD 3.2 inch touchscreen panel TFT LCD RGB Color Module ILI9341
    Tiongkok, China
  • Active Buzzer
    Tiongkok, China
  • LED 5mm RGB Difused Common Anode & Cathode
    Tingkok, China
    X 3
  • Arduino Mega TFT LCD Shield Adapter v2.2 for LCD 3.2" + Touchscr
    Tingkok, China
  • Data Logger SD Card Reader Writer SPI Interface
    Tingkok, China
  • SD Card Sandisk 4GB + Adapter
  • XL4015 LED Display 5A DC Buck Step Down Voltage Converter Consta
  • Adjustable Stepup LM2577 Step Up Boost Converter Modul + Voltmet
  • Metal Push Button Switch Self Locked 12mm Ring (Power Switch)
  • RTC DS3231 I2C Modul Clock
  • GX12 Jack Aviation Plug Socket Konektor GX-12 12mm Male Female 2
  • DC-022B Female Socket Jack DC 5.5mm Waterproof Tahan Air dan Deb
  • SUNLU 3D Print Filament PETG Hitam 1kg
  • SNDWay Vibration Meter Digital SW-65A
  • SolidWorks
  • Luxion Keyshot Rendering
  • Fritzing
  • Blynk Platform
  • Thingers.io
Soil compaction is a critical process in road construction, significantly affecting the durability and quality of infrastructure. Inadequate or uneven compaction often leads to premature road damage, such as cracking and potholes. Conventional methods for measuring soil density, such as the sand cone or nuclear density tests, are destructive, time-consuming, and unable to provide real-time data. To overcome these limitations, this research focuses on the design and development of a prototype EVIB (Electronic Vibration) Meter Detector based on Arduino Mega 2560 for real-time monitoring of soil compaction using vibration sensors mounted on heavy road roller equipment.
The system integrates a MPU6050 vibration sensor to measure acceleration, velocity, and orientation during compaction, along with a 3.2-inch TFT LCD touchscreen for real-time data visualization and a microSD card module for data logging. The collected vibration data is processed to estimate the California Bearing Ratio (CBR) percentage, which correlates with soil density and compaction quality, in accordance with SNI 1738-2011 standards. The device is designed for outdoor use, ensuring durability against environmental factors such as dust, vibration, and direct sunlight.
The prototype was tested over a 20-day period and validated against a commercial vibration meter (SNDWAY SW-65A) as a reference instrument. The results showed consistent data correlation, with the final CBR percentage reaching 34.23% on day 20. Statistical analysis, including mean, standard deviation, and coefficient of variation, confirmed the validity and reliability of the system. A radar plot comparison further demonstrated high accuracy and precision between the prototype and the reference device.
Blynk IoT 3rd Platform
The findings indicate that the developed EVIB meter prototype is capable of providing real-time, non-destructive, and reliable soil compaction monitoring, making it a practical and cost-effective solution for field applications in road construction and infrastructure projects. This system also has potential for integration with IoT platforms for remote monitoring via smartphones or computers, enhancing project management efficiency.
For more details, please watch the following video :
Animation Contruction Model
  • EVIB Meter Source Code
    EVIB_Code_170045445868ba4cd7d3934.zip
    Download(0)
  • Fritzing Schematic Diagram
    Download(0)
20.0k
25
8
  • Comments( 8 )
  • Like( 25 )
  • Amazing work after i saw full video
    Sep 05,2025 0 comments
    Reply
  • So this project maximizes the potential of the MPU6050 sensor to be placed on a road roller to detect soil density in real time with reference to the SNI17338-2011 standard, which is commonly used by employees during the road construction process, right?
    Sep 06,2025 1 comments
    • Budhi Prayoga 2025-09-08 13:24:53
      exactly 100%. these project convert from conventional method to automatic realtime. Mostly common used at the Ministry of Public Works and Public Housing (PUPR) when working on highway construction projects.
      Reply
    Reply
  • To be honest, I don't know what my brother-in-law does, but what I do know is that he never does anything reckless. And I respect that.
    • Budhi Prayoga 2025-09-08 13:32:51
      thx 4 u'r support. glad to hear that u already accept in college
      Reply
    Reply
  • I like ????????????????
    Sep 08,2025 1 comments
    • Budhi Prayoga 2025-09-08 13:36:05
      its our project too. where have u been, we need to improve performance respon time upload to IoT 3rd platform
      Reply
    Reply
