Aleksei Tertychnyi
pollutagNode2 - LoRaWAN Node for Air Quality Monitoring
Autonomous LoRaWAN node easily connectible via TTN/Helium networks, supporting downlinks. LaRaWAN node based on Seeed Studio' Wia-E5 module (based STM32WLE), so no additional transceiver needed - the main MCU and LoRa PHY already inside - suitable air quality monitoring, garden, intelligent home, automatization... You may connect load remotely by downlinks - via AO3400A transistor (on board). Optimized for Sensirion SEN54 sensor. MPPT and Li-Ion battery charger for power from 5V++ cheap solar panels. 10+ years of autonomic work with cheap 2W solar panel and standard 1850 Li-Ion battery expected. Sleeping current below 1 mA.
  • Cube IDE
    ST
pollutagNode2
Overview
The LoraWAN node for air quatity monitoring based on STM32WLE and SEN54 Sensirion sensor. This LoRaWAN node is designed for continuous air quality monitoring. The node operates autonomously and support remote commands via downlinks.
  1. LaraWAN node based on STM32WLE MCU (LORA-E5, Wio-E5), easy to integrate monitoring and control node (air quality monitoring, garden, intelligent home. etc.)
  2. You may connect load remotely by downlinks - via AO3400A transistor (on board)
  3. New Sensirion SEN54 sensor optimized
  4. MPPT and Li-Ion battery charger for power from 5V++ cheap solar panels.
  5. Sleep current as low as 0.9 mA
  6. 10+ years of autonomity with cheap 2W solar panel and standard 1850 Li-Ion battery
  7. More than 2 weeks work autonomity from fully charged 3500mA Li-Ion battery
  8. Ideal for sensor.community integration over LoRaWAN IoT, like TTN and Helium, no internet connection from your side needed!
  9. Full fledged with routed I/O ports - easy to solder - easy to add functionality (inputs, outputs, interfaces etc.)
Downlink commands supported
Reset the device via sending downlink to Port2 via LoRaWAN console:
FF FF FF FF FF FF
Set transmit period (in milliseconds) via downlink on Port2:
01 00 XX XX XX XX
(XX XX XX XX - milliseconds coded in hex (big endian), ex. for 5 minutes = 300,000 ms = 00 04 93 E0)
Set measuring period (in minutes) via downlink as for now provided together with LED_ON command in one 2-bytes downlink message on Port2: 01 XX - LED ON and measuring period = XX minutes, 00 XX - LED is OFF and measuring period = XX minutes. This LED enhanced with FET transistor, so you may connect some load (LOAD output) to be switched ON/OFF (see the schematic).
Uplink decoding / downlink encoding
The node uplink data packet containing 13 payload bytes with following data - PM1 concentration, PM2.5 concentration, PM10 concentration, temperature, humidity, volatile organic compound index (VOC), battery level related to volts, status of LED output. Decoder for payload on server side (uplink):
 function Decoder(bytes, port, uplink_info) {
    var decoded = {};
    decoded.PM1 = ((bytes[0]*256 +  bytes[1])/10.0).toFixed(2);
    decoded.PM2_5 = ((bytes[2]*256 +  bytes[3])/10.0).toFixed(2);
    decoded.PM10 = ((bytes[4]*256 +  bytes[5])/10.0).toFixed(2);
    decoded.T = (-100.0 + bytes[6] +  bytes[7]/100.0).toFixed(2);
    decoded.RH = (bytes[8] +  bytes[9]/100).toFixed(2);
    decoded.VOC = ((bytes[10]*256 + bytes[11])/10.0).toFixed(2);
    decoded.Battery = (bytes[12]*0.0238).toFixed(2);//battery , volts
    decoded.LEDON = bytes[13];
    decoded.RSSI = normalizedPayload.gateways[0].rssi.toFixed(0);
    decoded.SNR = normalizedPayload.gateways[0].snr.toFixed(0);
    decoded.FREQUENCY = normalizedPayload.frequency;
    return decoded;
Downlink payload encoder example:
function Encoder(measurements, port) {
    if(measurements.LED_ON.value) return [1];
    else return [0];
More information
Follow the project and find more information on Hackaday pollutagNode2.
Integration with Sensor.Community (will appear also on aqicn.org / waqi.info) via easy-to-use pollutants.eu API (Webhook URL) via TTN network find here.
For Helium it is an integration guide here.
BOM List
Name Designator Quantity Manufacturer Part Manufacturer Supplier Supplier Part
Resistor 30k R11,R8,R2,R6 4 CR0603-FX-3002ELF Bourns Mouser 652-CR0603FX-3002ELF
AO3400A Q2 1 AO3400A Alpha & Omega Semiconductors Digi-Key 785-1000-1-ND
PMV41XPAR Q1 1 PMV41XPAR Nexperia Mouser 771-PMV41XPAR
Capacitor 10uF C11,C3,C2,C1,C7,C8 6 GRM188R61C106KALD Murata Electronics Mouser 81-GRM188R61C106KALD
Resistor 82k R9,R4 2 RT0603FRE0782KL KEMET Mouser 603-RT0603FRE0782KL
SM06B-GHS-TB_LF__SN_ J3 1 SM06B-GHS-TB(LF)(SN) JST  Mouser 306-SM06BGHSTBLFSN
142-0701-801 J2 1 142-0701-801 Cinch Connectivity Solutions Mouser 530-142-0701-801
Capacitor 0.1uF C10,C4,C5,C6 4 06035C104KAT2A AVX Mouser 581-06035C104KAT2A
LTST-C171YKT LED1,LED2 2 LTST-C171YKT Lite-On Mouser 859-LTST-C171YKT
Resistor 2k R1,R7,R10 3 RC0603FR-072KL Yageo Mouser 603-RC0603FR-072KL
MPQ3413GJ-5-AEC1-P IC2 1 MPQ3413GJ-5-AEC1-P Monolithic Power Systems (MPS) Mouser 946-MPQ3413GJ5AEC1P
Capacitor 0.22uF C9 1 AC0603X7R9BB224 KEMET Mouser 603-AC0603X7R9BB224
Resistor 120 Ohm R5 1 ERJ-U03J121V Panasonic Mouser 667-ERJ-U03J121V
Resistor 0.1 Ohm R3 1 CRL1206FWR100ELF Bourns Mouser 652-CRL1206FWR100ELF
Inductance 10uH L2 1 SRN3015BTA-100M Bourns Mouser 652-SRN3015BTA-100M
Inductance 2.2uH L1 1 SRN3015-2R2M Bourns Mouser 652-SRN3015-2R2M
LDCL015M33R IC3 1 LDCL015M33R STMicroelectronics Mouser 511-LDCL015M33R
PMEG2010AEH D2,D1 2 PMEG2010AEH-QX Nexperia Mouser 771-PMEG2010AEH-QX
LoRa-E5 IC1 1 317990687 SEEED STUDIO Mouser 713-317990687
CN3791 IC4 1 CN3791 Consonance LCSC C154992
61300511121 J1 1 61300511121 Wurth LCSC C6461551
  • FW on GitHub
    https://github.com/WeSpeakEnglish/pollutag_node2
  • Schematic
    Download(26)
2.1k
17
2
31
  • Comments( 2 )
  • Like( 17 )
