SmartHome yourself
  • 10 Projects
  • 10 Followers
  • Jun 13,2025
Neopixel Ring RGB Clock with ESPHome and Home Assistant
Build your own WiFi-enabled RGB clock using a Neopixel ring and ESP32 – no programming needed! Powered by ESPHome and designed for seamless Home Assistant integration, this project displays the current time using colorful LEDs for hours, minutes, and seconds. Whether you want a smart wall clock or a glowing desk centerpiece, this build brings together DIY flair and smart home functionality. Everything runs locally, is OTA updateable, and fully customizable through YAML – the perfect project for makers and smart home fans alike!
  • Home Assistant
    Open Source
  • EspHome
This eye-catching RGB clock uses a 60-LED Neopixel ring to display the current time with color-coded hour, minute, and second indicators. Built with an ESP32 and fully powered by ESPHome, it's ready to integrate into Home Assistant right out of the box!
Whether mounted on the wall or placed on your desk, this project adds both smart functionality and a colorful visual touch to any room. You can customize the LED colors, brightness, or even set automations based on time or occupancy – all from Home Assistant.
📌 Key Features
  • 60 RGB LEDs for accurate time display
  • ESP32-based with ESPHome firmware
  • Seamless Home Assistant integration
  • WiFi-enabled and OTA updatable
  • Customizable LED colors and brightness
  • Wall-mount or desktop-ready design
  • 3D-printable case available
Video
https://youtu.be/4dabOY53DU4
📌 Used components
Full details, configuration and printable files available on my project page:
https://smarthomeyourself.de/rgb-led-uhr-mit-esphome-fuer-home-assistant/
Note: The links above are affiliate links. If you use them, I may earn a small commission – this helps support my projects at no extra cost to you.
  • ESPHome Code
    https://github.com/SmartHome-yourself/neopixel-clock-for-esphome
  • case
    NeoPixelRing_Uhr_PCB_Gehaeuse_331227472684b5f65b6af1.STL
    Download(2)
  • lid
    NeoPixelUhr_mit_PCB_Deckel_1948485804684b5fc8deec6.STL
    Download(2)
122
4
  • Like( 4 )
