Tomas Rudh
Wall Panel for Home Assistant using Elecrow 10 Inch
Mount an Elecrow 10 inch monitor on the wall, and get a control panel for your entire house, using Home Assistant.
  • Raspberry Pi 4B
    X 1 fenxiang
  • Home Assistant
    Open Source
This is hangers for a monitor to use as wall panel for Home Assistant. The monitor it is designed for is Elecrow 10 Inch 1280 * 800 Touch Screen Monitor, used together with a Raspberry PI.
See the following blog for more detail:
https://hapanel.blog.rudhs.se
I have printed using a Creality Ender 3v2, it works without supports, but will be a bit rough on the, not visible, underside.
Print two, turn one upside down.
750
9
  • Like( 9 )
