Manoranjan Das
7805 Voltage Regulator
🚀 Project Overview
This project demonstrates how to build a simple Voltage Regulator using the 7805 integrated circuit (IC). The 7805 provides a stable 5V output from a higher input voltage, making it ideal for powering circuits and components that require a 5V power supply.
⚙️ Project Details
  • Name: 7805 Voltage Regulator
  • Type: Linear Voltage Regulator
  • Input Voltage: 7V to 35V
  • Output Voltage: 5V DC
  • Current Output: 1A (typical)
This is a basic, easy-to-understand circuit designed for beginners. It uses the 7805 voltage regulator IC along with capacitors, diodes, and other passive components to ensure a stable output voltage.
🛠️ How to Build the Project
Schematic:
Below is the schematic diagram for the 7805 Voltage Regulator.
3D PCB Model:
The 3D PCB model gives you a visual representation of how the circuit board looks in 3D before fabrication.
🔧 Bill of Materials (BOM)
The Bill of Materials (BOM) for the project lists all the components used, with their LCSC part numbers. You can download the complete BOM below:
Component Quantity LCSC Part No.
7805 Voltage Regulator IC 1 C36568
Capacitors (470uF) 2 C29919
Capacitors (100nF) 2 C38791
Diodes (1N4007) 4 C32013
Resistor (150 Ohm) 1 C13113
LED (Red) 1 C15972
For more components, refer to the BOM file linked above.
💡 Features of the 7805 Voltage Regulator
  • Compact design for various applications.
  • Efficient voltage regulation with minimal heat dissipation.
  • Perfect for powering Arduino, Raspberry Pi, and other 5V electronics.
  • Easy-to-understand circuit layout and simple components.
💻 Usage Instructions
  1. Connect a power source to the input terminals (7V-35V DC).
  2. The 5V output can be used to power any 5V device (such as Arduino boards).
  3. Make sure to use appropriate heat sinks or ensure proper cooling if higher currents are drawn.
  4. This board is ready to be used for any project that requires a stable 5V power source.
📥 Download Files
📝 License
This project is licensed under the MIT License – free to use and modify. Please credit the original creators if you share or use the design in your own projects.
📢 Follow Us
Stay tuned for more electronics tutorials:
Happy building! ⚡🔧
  • https://github.com/ElectroIoT/EasyEDA-Tutorial-Project/tree/main/7805-Voltage-Regulator
22.1k
16
  • Like( 16 )
