Dharani Creations
Control Your Home with AI and No Code! | NodeMCU + Cadio App
This is a no-code smart home automation system built around the NodeMCU ESP8266 and a 4‑channel 5 V relay module, configured through the Cadio mobile app—no firmware coding required
  • NodeMCU
  • Relay module
  • Jumper Wires
  • Android phone with Bluetooth capabilities
  • CADIO
    CADIO
Project Overview
This is a no-code smart home automation system built around the NodeMCU ESP8266 and a 4‑channel 5 V relay module, configured through the Cadio mobile app—no firmware coding required .
It lets you control up to four appliances via Cadio’s app, voice assistants like Google Assistant and Amazon Alexa, as well as manual push-button switches when offline .
Key Features include:
  • Voice control through Google Assistant and Amazon Alexa
  • Cadio app dashboard control and real-time feedback
  • Local manual control via push buttons if Wi-Fi is unavailable
  • Automatic device scheduling (timers)
  • EEPROM memory of device states after power outages
  • Over-the-air (OTA) Wi‑Fi reconfiguration via physical button
  • Entire setup requires no programming, just GUI configuration
  • NodeMCU ESP8266 board
  • 4‑channel 5 V SPDT relay module
  • Pushbuttons or switches (up to 4) for manual override
  • Power source: typical 5 V USB adapter (e.g. mobile charger)
  • (Optional) Custom PCB with transistors (BC547), optocouplers (PC817), LEDs, resistors, diodes for robust switching and safety \
GPIO pin usage (basic setup):
  • D1 (GPIO5), D2 (GPIO4), D5 (GPIO14), D6 (GPIO12) → relay inputs
  • SD3 (GPIO10), D3 (GPIO0), D7 (GPIO13), RX (GPIO3) → pushbuttons (use INPUT_PULLUP mode)
 Firmware & Configuration
This project uses Cadio's dynamic firmware, not traditional code. Steps:
  1. Flash the firmware to NodeMCU using an ESP flashing tool:
    • Firmware file installed at address 0x0, SPI mode DIO, SPI speed 40 MHz
    • Activate DoNotChgBin option, erase flash before uploading
  2. Reset the ESP8266; wait ~30 seconds until onboard LED blinks—ESP is ready for configuration .
  3. Configure via Cadio app:
    • Connect to the ESP8266's “CADIO” hotspot
    • Set switch & relay modes (e.g. “PRESS” vs “NORMAL”, active‑LOW or HIGH)
    • Assign GPIO pins, export configuration, input Wi‑Fi credentials and unique device name
    • Save and launch dashboard
 Operation Modes
  • App Control: Use Cadio app interface to toggle appliances and schedule operations.
  • Voice Control: Link Cadio account with Google Home and Alexa to control devices using voice commands—no code required
  • Local Switch Control: If Wi‑Fi is down, manual buttons still work to control relays directly
  • State Persistence: Devices remember last on/off state after reboot/power loss, thanks to EEPROM support
  • Wi‑Fi Reconfiguration via OTA: Hold a specific pushbutton for ~4 seconds to reboot into config hotspot for updating Wi‑Fi settings via the Cadio app
 Summary Table
Feature Details
Control Interfaces Cadio app, Google Assistant, Amazon Alexa, manual switches
Appliances Supported Up to 4 relay-controlled devices
Firmware Setup Cadio dynamic firmware (no coding required)
Persistence & Scheduling EEPROM state memory, timer functions
Wi‑Fi Reconfiguration OTA configuration via hotspot and app when button is held
 Why Use This System?
  • You don’t need to program—ideal for beginners and rapid DIY deployment
  • Compatible with voice platforms (Google Assistant, Alexa) with minimal setup
  • Reliable fallback with physical switch control if Wi‑Fi is unavailable
  • State persistence and scheduling make it practical for daily use
  • Over-the-air updates let you change Wi‑Fi settings easily without rewiring
  • Flash Download
    https://github.com/DharaniCreations/Control-Your-Home-with-AI-and-No-Code-NodeMCU-Cadio-App-Home-Automation
  • Diagram
77.2k
18
2
  • Comments( 2 )
  • Like( 18 )
