Grovety
  • 23 Projects
  • 25 Followers
  • Jun 17,2025
Weather & Air Quality Station (EnSens Add-on & CrowPanel)
Displays real-time indoor data (temperature, humidity, pressure, IAQ, CO₂, VOC) and live weather forecasts. Easy setup with prebuilt firmware. Fully open-source and customizable.
Goods
This advanced environmental monitoring station is built on the CrowPanel Advance platform (5-inch or 7-inch version) and uses the EnSens Add-on with a Bosch BME688 sensor to provide a comprehensive view of both indoor air quality and outdoor weather conditions.
Requirements
1. CrowPanel Advance 5” or 7”
2. EnSens Add-on for local sensing of temperature, humidity, pressure, VOC, CO₂, and IAQ
Main Features
The user interface features two main tabs (Indoor and Forecast) and an additional Settings tab.
1. Indoor Tab – Real-Time Local Monitoring
Displays detailed sensor data from the EnSens Add-on:
  • Time and Date: Full clock, calendar, and day of the week
  • Temperature: Current value with dynamic trend arrow
  • Humidity: Live reading, trend, and dew point calculation
  • Pressure: Measured value, trend indication, and 24-hour graph
  • Air Quality Parameters:
    • IAQ (Indoor Air Quality Index): Visual scale from 0 (clean) to 500 (hazardous)
    • CO₂ Levels: Monitors indoor carbon dioxide with warning levels
    • VOC Levels: Indicates presence of airborne organic compounds (e.g., from paint, furniture, or people) with a colored status bar
All indicators are presented with intuitive visual aids for quick assessment of trends and health-related concerns.
2. Forecast Tab – Online Weather
Fetches weather data from OpenWeatherMap, including:
  • External temperature, humidity, and pressure
  • Weather condition icons and daily forecast summaries
  • Location-based automatic updates
Settings Menu
The system provides a full configuration interface:
  • Wi-Fi setup
  • Location settings (for weather forecast)
  • Manual or automatic screen brightness
  • Manual time and date adjustment
  • Measurement unit selection: °C / °F, hPa / mmHg
Customizable and Expandable
The firmware for both CrowPanel and EnSens Add-on is open-source and can be modified for advanced use cases. Easily expand the station’s capabilities or integrate it into broader environmental monitoring systems.
Installation & Firmware Guide
Step 1: Installing the EnSens Add-on Module
Simply plug the EnSens Add-on into the dedicated expansion port on the back of the CrowPanel Advance.
Refer to the product photos — no tools or configuration needed. The module will be automatically recognized after firmware upload.
⚠️ Don't forget to move the jumper on the back of the panel to the WM (wireless module) position.
Step 2: Flashing the Firmware
Option A: Use Prebuilt Firmware (Recommended for Beginners)
1.     Download the precompiled firmware archive:
https://github.com/Grovety/ensens_addon_crowpanel_meteo/blob/main/grc_ensens_release_1.5.7z
2.     Unpack the archive.
3.     Connect your CrowPanel to your PC via USB-C cable.
4.     Launch FlashTool.exe from the unpacked folder — it will auto-detect the COM port and flash the firmware automatically.
5.     Wait for flashing to complete — the system will reboot and start showing data immediately.
Option B: Build from Source (For Developers)
1.     Install Development Tools:
o   Install Visual Studio Code
o   Install ESP-IDF Extension for VSCode
o   Install ESP-IDF v5.4.1 through the extension
2.     Open the Project:
o   Open a terminal and navigate to the root of the project folder
o   Run code . or open the folder in VSCode manually
3.     Connect the Panel via USB-C
Ensure your CrowPanel is connected and powered.
4.     Flash the Project:
In VSCode:
o   Select ESP-IDF version v5.4.1
o   Set Flash Method: UART
o   Choose the correct COM port
o   Target Device: esp32s3
o   Click "Build, Flash and Monitor"
You now have a fully functional smart station with both Indoor and Forecast tabs enabled.
  • https://github.com/Grovety/ensens_addon_crowpanel_meteo/tree/main
15.8k
19
  • Comments( 1 )
  • Like( 19 )
