Luc Paquin
  • 32 Projects
  • 11 Followers
  • May 10,2025
Project #12: Robotics - Vibration - Mk29
  • Crowduino Uno - SD
    Elecrow
    X 1 fenxiang
  • Crowtail - Base Shield
  • Crowtail - I2C LCD
    Elecrow
    X 1 fenxiang
  • Crowtail - Vibration Sensor 2.0
    Elecrow
    X 1 fenxiang
  • Crowtail - Buzzer 2.0
    Elecrow
    X 1 fenxiang
  • Crowtail - LED(Green)
    Elecrow
    X 1 fenxiang
  • USB Battery Pack
    X 1 fenxiang
  • USB Mini-B Cable
    Elecrow
    X 1 fenxiang
https://www.donluc.com/?p=4424
https://youtu.be/TzC-NDANaFU
https://learn.dfrobot.com/makelog-314973.html
#DonLucElectronics #DonLuc #Vibration #Arduino #EEPROM #Display #Elecrow #Project #Patreon #Electronics #Microcontrollers #IoT #Fritzing #Programming #Consultant
The Crowtail- Vibration Sensor is Used to trigger the effect of various vibration with normally closed type vibration sensor SW - 420. It is widely used to reported the theft alarm, intelligent car, earthquake alarm, motorcycle alarm, etc. This module is compared with the normally open type vibration sensor module, vibration trigger for longer periods of time, can drive the relay module.
1. The product is not vibration, vibration switch is closed on state, output output low level, the green light is lit;
2. When product vibration, the vibration switch instantaneous disconnection, output, output level green light is not bright;
3. The output can be attached directly to the single chip microcomputer, through single chip microcomputer to detect the high and low level, thus to detect if there is a vibration environment, report to the police;
DL2505Mk01
1 x Crowduino Uno - SD
1 x Crowtail - Base Shield
1 x Crowtail - I2C LCD
1 x Crowtail - Vibration Sensor 2.0
1 x Crowtail - Buzzer 2.0
1 x Crowtail - LED(Green)
1 x USB Battery Pack
1 x USB Mini-B Cable
Crowduino Uno - SD
SCL - A5
SDA - A4
BUZ - 4
VIB - 5
LED - 6
VIN - +5V
GND - GND
DL2505Mk01p
DL2505Mk01p.ino
getDisplay.ino
getEEPROM.ino
getVibration.ino
setup.ino
Electronics, IoT, Teacher, Instructor, R&D and Consulting
-Programming Language
-IoT
-Robotics
-Automation
-Machine Learning
-Artificial Intelligence (AI)
-RTOS
-Consulting
-Etc...
Follow Us
https://www.donluc.com/luc/
Web: https://www.donluc.com/
Don Luc
175
5
  • Like( 5 )
