Rui Barroso
Garage Gate monitor
This project will control and monitoring your gate, reports if is traveling for closing or opening, if already reach the full close position ( just in case something gets in the away and avoid full close )
Garage Gate monitor
  • EspHome
This project will control and monitoring your gate.
It reports if is traveling for closing or opening.
If already reach the full close position ( just in case something gets in the away and avoid full close )
Possibility to Open or Close from HA
Powered from mains (240Vac)
Inputs :
  • 2 wires from main Motor (+ - )
  • IR sensor placed on the exact end of traveling gate
  • Optional IR sensor on the passing barrier
  • DHT22 or similar to track motor's temperature
Output
  • dry contact to connect parallel with wall swtch (open/close)
  • ESPHome code
    Sliding_gate_-_home_assistant_-_ESPHome_1990837194683590e3c7f91.txt
    Download(1)
  • Schematic
    Schematic_portao_correr-V2_2025-05-27_15113269646835911894414.pdf
    Download(6)
  • 3D view
    Download(3)
  • Board layout
    placa_354102656835915b9bb09.pdf
    Download(0)
  • BOM
    BOM_portao_correr-V2_2025-05-27_425378251683594da2ad1b.zip
    Download(1)
Garage Gate monitor
6.8k
16
  • Like( 16 )
