ESP32-P4 vs ESP32-S3
The Ultimate Showdown: ESP32-P4 vs. ESP32-S3
In the world of IoT and embedded systems, Espressif's ESP32 series is a household name. The ESP32-S3, in particular, has won the hearts of countless developers with its potent AIoT capabilities and unbeatable value. However, with the launch of Espressif's latest powerhouse, the ESP32-P4, a critical question has emerged: Compared to the ESP32-S3, which one is truly more powerful?
This question is more nuanced than it seems. These chips aren't simple generational upgrades; they are specialists engineered for different battlefields. This article will provide a definitive deep dive, comparing them across core architecture, performance, connectivity, multimedia capabilities, and target applications to help you make the most informed decision for your next project.
Key Differences
Before we get into the weeds, let's use a quick comparison table to visualize the core distinctions between the ESP32-P4 and ESP32-S3. This is vital for readers seeking fast insights and for search engine summary snippets.
Feature ESP32-P4 (High-Performance MCU) ESP32-S3 (All-in-One AIoT SoC) The Winner?
Core CPU RISC-V Dual-Core 400MHz HP CPU + Single-Core 40MHz LP CPU Xtensa LX7 Dual-Core 240MHz CPU ESP32-P4 (Sheer compute power)
Wireless Connectivity None built-in (Requires external co-processor) Built-in 2.4 GHz Wi-Fi 4 & Bluetooth 5 (LE) ESP32-S3 (Integration & simplicity)
Multimedia Processing Hardware H.264/JPEG encoders, ISP, MIPI CSI/DSI Primarily software-based; has LCD/DVP interfaces ESP32-P4 (Pro-level multimedia core)
AI Acceleration Leverages massive CPU power for complex vision AI Vector instructions for general-purpose AIoT A Tie (Different application focus)
Memory (SRAM) 768 KB on-chip SRAM + 8KB SPM 512 KB on-chip SRAM ESP32-P4
High-Speed Peripherals High-Speed USB OTG (480Mbps), Ethernet MAC, MIPI Full-Speed USB OTG (12Mbps) ESP32-P4
Target Applications HMI, Industrial Automation, Edge Computing Gateways AIoT Devices, Smart Home, Wearables, Consumer Electronics Specialized Roles
Positioning High-Performance Multimedia MCU Highly-Integrated Wireless SoC Specialized Roles
A Head-to-Head Analysis
Now, let's dissect each key differentiator in detail.
1. Core Architecture & Raw Performance: RISC-V Beast vs. Xtensa Powerhouse
This is the most fundamental difference and the key to defining their respective "power."
  • ESP32-P4: Adopts the modern RISC-V architecture, featuring a High-Performance (HP) system with a dual-core processor clocking up to 400MHz, complemented by a separate 40MHz Low-Power (LP) core. This means the P4's raw compute power for intensive tasks vastly outmatches the S3. It's like a machine with a powerful main engine for heavy lifting and an efficient auxiliary engine for idle states.
  • ESP32-S3: Employs the mature and proven Xtensa LX7 architecture with a dual-core processor running at 240MHz. This configuration has been a golden standard for years, balancing performance, power efficiency, and cost for connected AIoT tasks.
Verdict: For pure CPU horsepower, the ESP32-P4 is the undisputed champion. Its higher clock speed and advanced architecture provide a solid foundation for complex algorithms and graphics rendering.
2. Wireless Connectivity: The Integrated SoC vs. The Pure MCU
This is another decisive factor that will guide your choice.
  • ESP32-S3: It's a true AIoT SoC (System on a Chip), integrating a battle-tested 2.4GHz Wi-Fi 4 and Bluetooth 5 (LE) radio. This allows developers to handle computation, control, and wireless connectivity on a single chip, drastically simplifying hardware design and reducing the Bill of Materials (BOM) cost.
  • ESP32-P4: In a strategic move, it has no built-in wireless capabilities. Espressif positions it as a pure High-Performance MCU (Microcontroller). Its purpose is to deliver maximum processing power, offloading connectivity to "companion chips" like the ESP32-C6 or ESP32-H2. This "MCU + Connectivity" approach offers greater flexibility for complex systems.
Verdict: If your project requires a single-chip wireless solution, the ESP32-S3 is your go-to choice. If you are building a more complex system, like an edge gateway that needs to separate high-performance processing from specific wireless protocols (e.g., Wi-Fi 6, Thread), the P4's architecture is more adaptable.
3. Multimedia & Graphics Processing: The Specialist vs. The All-Rounder
This is where the ESP32-P4 is in a league of its own.
  • ESP32-P4: It was born for graphics and video. The P4 integrates an impressive array of hardware accelerators:
    • H.264 Video Encoder: For real-time video stream processing.
    • JPEG Hardware Codec: For highly efficient image handling.
    • MIPI CSI/DSI Interfaces: For connecting modern cameras and high-resolution displays.
    • Image Signal Processor (ISP) & Pixel Processing Accelerator (PPA): Providing hardware-level image optimization and 2D graphics acceleration.
    • High-Speed USB OTG (480Mbps): Capable of supporting high-bandwidth devices like USB cameras.
  • ESP32-S3: The S3 has respectable graphics capabilities, including parallel LCD and DVP (Digital Video Port) interfaces for driving mid-resolution screens. However, it lacks hardware-level video encoding and advanced graphics acceleration, making it struggle with complex GUIs or video streams.
Verdict: In the multimedia and HMI arena, the ESP32-P4 is a complete game-changer. Any project requiring a fluid GUI, video playback/encoding, or camera input will find the P4 to be the superior choice by a wide margin.
4. AI Capabilities: High-Performance Vision AI vs. General-Purpose AIoT
  • ESP32-S3: The S3's strength lies in its AI vector instructions, which make it highly efficient for running general-purpose machine learning models like keyword spotting, voice recognition, and sensor data analysis. Espressif’s mature ESP-WHO and ESP-SR libraries provide robust support.
  • ESP32-P4: While the P4 lacks the S3's dedicated AI instructions, it compensates with far greater raw compute power and a professional ISP. This makes it better suited for compute-intensive vision AI tasks like object detection and facial recognition, where it can first optimize camera data with the ISP and then use its powerful CPU for inference.
Verdict: An interesting tie. The ESP32-S3 is ideal for power-efficient, general-purpose AIoT applications. The ESP32-P4 is purpose-built for edge vision AI applications that need to process complex images and video.
Which One Should I Choose?
Let's return to the original question: who is more powerful? The answer is: they are both exceptionally powerful in their designated domains.
Choose the ESP32-S3 if your project is:
  • A smart device requiring native Wi-Fi and/or Bluetooth connectivity.
  • Cost-sensitive and benefits from a single-chip solution.
  • A typical AIoT product: smart home devices, wearables, industrial sensors.
  • Running voice recognition or AI models based on non-image data.
  • Has modest graphical interface requirements or a lower-resolution screen.
Choose the ESP32-P4 if your project is:
  • An HMI (Human-Machine Interface) with a complex, fluid graphical user interface (GUI), like a smart appliance panel or industrial touchscreen.
  • Needs to process real-time video streams from a camera, such as in webcams, video doorbells, or monitoring systems.
  • An edge computing gateway that requires significant processing power to aggregate and analyze data from multiple sources.
  • Has specific wireless needs (like Wi-Fi 6) and will be paired with a dedicated connectivity co-processor.
  • Focused purely on achieving maximum processing and multimedia performance, without the need for integrated wireless.
What's in the future?
The ESP32-S3 is the proven AIoT champion, a masterfully balanced all-rounder of connectivity, computation, and cost. The ESP32-P4 is the new heavyweight contender, trading integrated wireless for a knockout punch in compute and multimedia processing, carving out a new arena for high-performance MCUs.
Therefore, "powerful" is not a one-dimensional metric. The ESP32-S3's power is in its integration and efficiency. The ESP32-P4's power is in its sheer performance and specialization. Understand your application's needs, and you will find your true performance king.
Frequently Asked Questions (FAQ)
Q1: Since the ESP32-P4 has no Wi-Fi, how do I get it online?
A: You need to pair the ESP32-P4 with a wireless co-processor, such as an ESP32-C6 (for Wi-Fi 6, BLE, Zigbee, Thread) or another ESP32 series chip. They communicate via interfaces like SPI or UART, with the co-processor handling all wireless tasks.
Q2: Is the ESP32-P4 a replacement for the ESP32-S3?
A: Absolutely not. They are distinct product lines targeting different markets. The ESP32-S3 will continue to be a top choice for AIoT, while the ESP32-P4 opens up new possibilities in high-performance HMI and edge computing.
Q3: For battery-powered applications, which is better?
A: For applications requiring long periods of wireless connectivity, the ESP32-S3 is generally the better choice due to its mature low-power wireless management. While the ESP32-P4 has an LP core, its overall design is performance-oriented, and adding an external wireless module introduces more complexity to power management.
Q4: I'm building a smart coffee machine with a high-resolution touchscreen. Which should I pick?
A: Without a doubt, choose the ESP32-P4. Its powerful graphics processing, MIPI-DSI interface, and high-performance CPU will deliver the smooth, beautiful user experience that would be very difficult to achieve with an ESP32-S3.
If you're still interested and want to learn more about the ESP32-P4, please check out our another blog post  →  Exploring the Power of ESP32-P4 HMI Displays
❤[New] - Join Our ESP32 Display UI Contest Now
Elecrow and SquareLine are thrilled to announce the Elecrow HMI × SquareLine UI Contest!
※※ Timeline: December 5, 2025 - March 6, 2026
※※ Your Challenge: Design stunning UI for Elecrow ‘CrowPanel ESP32 HMI Displays’ using 'SquareLine Studio/Vision'
This is a great opportunity to win cash prizes, exclusive software license, and have your UI showcased globally, becoming a classic case study and gaining recognition!
Learn More: https://www.elecrow.com/crowpanel-squareline-contest.html
