Every tool is judged by the same three questions — what input does it take, which workflow stage does it own, and where does it hand the design back to you.
Most comparisons of AI tools for PCB design rank features. That is the wrong axis. The tool that will save you a week is the one whose input happens to be the file you already have on disk — and whose stopping point is the work you were going to do by hand anyway.
This guide compares ten AI tools for PCB design on what they actually do, what they require before they can do it, and how far they get before an engineer has to take over. Every entry follows the same four fields, so you can read it like a datasheet instead of a brochure: Input, Output, PCB workflow stage, and Key limitation.
Two things are deliberately not in here: pricing, and a winner. Pricing changes faster than any article can track, and the winner depends entirely on which stage you are stuck at. What follows is the part that stays true for a year.
Requirements tools end at a schematic and BOM. Layout engines begin at a finished schematic. Autorouters begin at a placed board. All-in-one tools span every stage but go shallowest on each. Pick the category first, the brand second.
Every AI tool for PCB design falls into one of six categories, and the category tells you more than the feature list does. The classification below is by starting input, because that is the only thing you cannot change about your current project.
| Tool type | Starting input | What AI helps with | Typical output | Examples |
| AI design assistant | A design question or an existing project | Suggestions and review | Recommendations, edits | Flux, EasyEDA Pro + AI agent |
| AI schematic generator | Requirements or a text prompt | Architecture and schematic | Schematic and BOM | CELUS, Circuit Mind, ProtoFlow |
| AI component tool | Requirements or a schematic | Part selection, alternates | Components and BOM | CELUS, Circuit Mind, Flux |
| AI layout tool | Schematic plus constraints | Placement and routing | PCB layout | Quilter, Cadence Allegro X AI |
| AI autorouter | An existing placed board | Routing the remaining nets | Routed PCB | DeepPCB, Flux AI Auto-Layout |
| AI-native EDA | Product requirements | Several stages in one tool | Native PCB project | Flux, JITX, ProtoFlow |
The second axis is how much control the tool takes. It matters more than people expect, because it decides how much of your design you can still explain in a review.
| Control model | What it means in practice |
| Copilot-style | Suggests changes and waits for you to accept each one. Every decision stays traceable to a human. Slower, but far easier to defend in a design review or an audit. |
| Autonomous layout engine | Generates complete placement-and-routing candidates from your constraints, which you then review and refine. Fast, but the review becomes the real work — and it has to be scheduled, not squeezed in. |
Two tools in the same category can behave very differently on the same board. A category tells you whether the tool will accept your file. Only the limitation note tells you whether it will finish the job. That is why every entry in the next section ends with one.
These ten cover the workflow from requirements to routing. The order is not a ranking — it follows the workflow, starting from the earliest stage a tool can accept.
A browser-based PCB design tool built around an AI agent, aimed at makers, startups and small teams that want one tool from idea to routed board. It plans the design, finds in-stock parts, wires the schematic, places components, routes, and runs ERC and DRC as it works.
A physics-driven AI layout engine that works from an existing schematic, for hardware teams that want several layout candidates from one finished design. It automates placement and routing, then reports the physics and design-rule checks it ran on each candidate — which is its most underrated output.
The generative AI layout application inside the Cadence Allegro X platform, for enterprise teams already working constraint-first in Allegro X. It generates alternative placements, creates power and ground planes, and routes critical nets inside your electrical and manufacturing constraints, with Sigrity X providing SI and PI analysis.
A professional EDA platform whose documented AI lives mostly in the Altium 365 cloud environment — a natural fit for teams that want AI without changing their existing workflow. The Engineering Assistant in the Requirements Portal creates, edits and reviews requirements from natural-language requests.
A free EDA tool in the browser or as a desktop client, with a complete component library and an Extension API that AI connects through. EasyEDA's official API skill lets coding agents such as Claude Code issue commands that edit schematics and PCBs, search the library and run DRC — the most inspectable automation model of the ten, because every action is a readable command.
A browser-based AI platform that converts requirements into a reference schematic and BOM, for engineers who need a sourced BOM early. It captures requirements through guided questions, matches components and reference designs, generates the schematic and runs design checks.
An AI design platform that converts a hardware architecture into a schematic and BOM, for professional and enterprise teams that need optimised, documented designs. It searches component combinations against cost, size, power and availability targets, then generates the schematic and runs verification checks.
From InstaDeep: a cloud AI routing engine trained with reinforcement learning, for designers who route critical nets by hand and want the routine routing finished quickly. Its Cooper assistant checks stackup, net classes, differential pairs, planes and clearances, then the engine routes the remaining nets.
A code-driven PCB design tool in which requirements and design rules are written in Python, for teams with software skills working on high-frequency or reusable designs. An AI model approved by your organisation edits the design code, while JITX generates schematics, board structures and routing, runs checks, and dispatches HFSS electromagnetic simulations.
A desktop AI-native EDA tool that turns a plain-language description into a schematic, aimed at beginners and makers who want a fast first draft to finish elsewhere. It drafts the schematic, imports real parts from LCSC, DigiKey and Mouser, and runs ERC and DRC on the result.
None of the ten limitations above is a defect. Each one is a scoping decision the vendor made, documented publicly, and it is where your engineering hours come back. A tool whose limitation matches work you enjoy is a better tool for you than one that scores higher on a matrix.
The matrix below reads straight off the vendor documentation. A check mark means the vendor documents AI performing or assisting that stage; a dash means the stage stays with the engineer or another tool.
| Tool | Schematic | Components | Placement | Routing | Verification | Platform | Best for |
| Flux | Yes | Yes | Yes | Yes | Yes | Browser | All-in-one AI workflow |
| Quilter | — | — | Yes | Yes | Yes | Browser | Autonomous layout |
| Cadence Allegro X AI | — | — | Yes | Yes | Yes | Desktop + cloud | Enterprise constraint-driven layout |
| Altium Designer | — | — | — | — | — | Desktop + cloud | Altium teams; AI at requirements |
| EasyEDA Pro + agent | Yes | Yes | Yes | Yes | Yes | Browser + desktop | Agent-driven design via API |
| CELUS | Yes | Yes | — | — | Yes | Browser | Requirements to schematic |
| Circuit Mind | Yes | Yes | — | — | Yes | Browser | Architecture to schematic and BOM |
| DeepPCB | — | — | — | Yes | Yes | Browser | AI routing of a placed board |
| JITX | Yes | Yes | Yes | Yes | Yes | Desktop | Code-driven, high-frequency design |
| ProtoFlow | Yes | Yes | — | — | Yes | Desktop | Prompt to schematic, then handoff |
Read the dashes, not the checks. The dashes tell you which tool you still need to buy, learn, or borrow a colleague for — and that set of dashes is what actually decides your total cost of ownership.
Altium Designer shows a row of dashes, which looks like a poor score until you read the platform column. It is the incumbent: the AI value is in requirements structuring, and everything else continues in a tool your team already runs. If you are already on Altium, the correct move is usually to add a layout engine alongside it, not to replace it.
Choose by starting point and existing EDA software, not by feature count. Find your situation in the table, then read the section below it.
| Your situation | Tool type, and examples |
| I only have an idea | AI schematic or architecture tool — Flux, ProtoFlow |
| I have written requirements | Schematic and BOM generation — CELUS, Circuit Mind |
| I already have a schematic | AI placement and routing — Quilter, Cadence Allegro X AI |
| I need autonomous layout | AI layout engine or autorouter — Quilter, DeepPCB |
| I use KiCad | KiCad-compatible tools — Quilter, DeepPCB, CELUS, ProtoFlow, JITX |
| I use Altium | Altium-compatible tools — Quilter, DeepPCB, CELUS, JITX |
| I want browser-based design | Cloud AI EDA — Flux, EasyEDA Pro |
| I want free options | ProtoFlow free plan, JITX for open-source, Quilter for eligible academic and small-team use |
You need a tool that turns design intent into a schematic, and the decision reduces to one question: do you need a sourced reference design, or a fast first draft?
For a sourced reference design, CELUS and Circuit Mind capture functional blocks and constraints, then return a schematic and BOM your EDA tool can open. For early exploration, Flux and ProtoFlow draft a schematic from a plain description. Once any AI-generated BOM exists, verify availability and package information before the design hardens — that step is cheaper at hour one than at week six.
Use a layout tool that accepts your native files. Quilter generates placement and routing candidates from Altium, Cadence, OrCAD, Siemens Xpedition or KiCad files; Allegro X AI works inside an existing Allegro X project.
Prepare the inputs first. Board outline, fixed connector and mounting-hole positions, stackup, net classes and design rules. Missing rules produce layouts that look complete while quietly missing the design intent — and a layout engine will not tell you which constraint you forgot, because it has no idea you meant to specify one.
Use an autorouter when placement is already fixed. DeepPCB routes a placed board from Altium, KiCad or EasyEDA files; Flux AI Auto-Layout routes once placement is finalised in Flux.
The selection rule both DeepPCB and Quilter describe: route critical nets by hand first — clocks, high-speed pairs, RF paths — then let the engine do the rest. Routers optimise geometry; they cannot recover a topology decision that was wrong before routing started.
KiCad 10 still ships without a built-in AI assistant, so AI enters through tools that read and write KiCad files: Quilter, DeepPCB (via plugin), CELUS, ProtoFlow and JITX all support KiCad import or export.
General-purpose AI agents can also operate the KiCad interface directly as computer-use agents — a real workflow, not a demo, but one where verification is entirely your responsibility. Whichever route you take, keep the native KiCad project as the source of truth and re-run DRC inside KiCad after any agent edit.
Choose the stage you want to automate. For schematic and PCB edits, connect an AI coding agent through EasyEDA's official API skill. For AI routing, send the placed board to DeepPCB, which accepts EasyEDA Pro files. Either way, keep the native project authoritative and re-run DRC in EasyEDA Pro after each agent change — the agent has no memory of what the board is supposed to do.
Use constraint-driven EDA with AI, and keep the constraint set as the source of truth. Allegro X AI routes critical nets within the Allegro X constraint system with SI and PI analysis through Sigrity X; JITX encodes SI targets and stackups in code with HFSS simulation in the loop.
Before trusting any AI layout on a high-speed board, confirm how the tool handles these five things. Ask for a demonstration on your stackup, not on theirs.
| What to confirm | Why it decides whether the output is usable |
| Impedance | Controlled-impedance traces must be calculated from the actual stackup, not from a default template. If the tool cannot import your fabricator's build, its impedance numbers are fiction. |
| Differential pairs and length matching | Pair routing with length and skew tuning, and evidence that it tunes between pairs in the same interface, not only within each pair. |
| SI and PI | Crosstalk, return paths and power delivery. A routed board with a split reference plane under a high-speed net is a DRC pass and a compliance failure. |
| HDI and thermal | Microvia structures, copper balance and heat paths — the three things that separate a prototype from a producible board. |
| Manufacturing constraints | Your fabricator's trace, space, drill and stackup limits, loaded as rules rather than assumed. This is where AI drafts most often fail at CAM review. |
AI speeds up drafting, placement and routing, but its output can still contain errors in connectivity, footprint, signal integrity and manufacturability. An engineer has to check and sign off on each of these before an order is placed. The five below are ordered by how often they reach a fabricator.
AI tools can connect the wrong pins, leave nets unconnected, or select parts with the wrong rating or package. Altium's own AI notice is explicit that AI-generated content may be incomplete or incorrect and that qualified engineers must review every output — treat that as the industry baseline, not a vendor quirk.
A footprint can look correct in the PCB editor and still fail at assembly. In the GPT-6 Astra EasyEDA Pro project, the first native check reported 50 association mismatches caused by different physical footprints sharing the same library name — a class of error that is invisible until every reference silently resolves to the wrong land pattern.
A fully routed, DRC-clean board confirms geometry, not electrical performance. DeepPCB is unusually honest about this: DDR nets, length matching, advanced impedance control and RF constraints stay with engineers. For high-speed nets, check impedance against the real stackup, reference-plane continuity under each pair, length matching, skew and crosstalk — and run SI and PI simulation wherever the design requires it.
A clean DRC confirms the design meets the rules you entered, and those rules may not reflect your fabricator's capability. A board can therefore pass DRC and still present manufacturing problems: an annular ring below the drill tolerance window, a solder-mask sliver between fine-pitch pads, or a stackup needing sequential lamination when ordinary multilayer was ordered.
An engineer still owns the decisions that need accountable sign-off: architecture, trade-offs, compliance and final release. Review AI output with exactly the same schematic review, layout review and prototype testing you would apply to any new design — the tool being new is not a reason to relax the process, and it is not a reason to tighten it either.
The practical version of limitation five, as a release gate. Each item is yes or no, and any "no" blocks the order rather than being noted for later.
Pick your native EDA project and treat every AI output as a proposal until it is merged there. Boards living in two tools at once are the ones that ship with stale copper.
Checks run inside the AI tool are convenience output, not evidence. Run them again with your rule deck, in your environment, before exporting anything.
The step the Astra project proved is not optional. Verify pin 1, pad numbering, pitch and courtyard, then grep the library for duplicate names before the BOM hardens.
Every line, at order time: MPN, package, and whether alternates are acceptable in production. AI-generated BOMs inherit whatever snapshot the model or tool held.
Name what you are unsure about — "please review the 0.15 mm trace regions and the 0.5 mm pitch connector footprint." A specific question gets a specific answer; a silent upload gets a generic pass.
A first article with functional test tells you in a week what a hundred-unit run tells you in a month. AI-generated files should never go straight to volume.
At Elecrow that sequence is the default rather than an add-on: Gerber and stackup checked against published process capability, BOM and CPL cross-checked by a dedicated project manager, fabrication and SMT with SPI and AOI, X-ray where the package demands it, and functional test before shipment.
Not on its own. A general-purpose model can draft a circuit or operate EDA software through an agent, but the board still needs EDA tools, datasheet checks and engineering review. The useful role for a general model today is as an operator of tools that do understand geometry — not as a replacement for them.
Yes, with limits. ProtoFlow has a free plan with a daily AI allowance, JITX is free for open-source designs, and Quilter is free for eligible academic, personal and small-team use. EasyEDA Pro is free as an EDA tool and exposes the API that AI agents drive. The constraint is usually message allowance, layer count or export format rather than raw capability.
Usually a tool with a guided, prompt-based workflow, such as Flux or ProtoFlow. The AI drafts the schematic and runs error checks while you learn to verify the result. The important part is not the drafting speed — it is that you learn to catch the errors, because every tool in this guide assumes someone will.
No. KiCad 10 does not include a built-in AI assistant. AI interacts with KiCad through tools that import or export KiCad files, such as Quilter and DeepPCB, or through external agents that operate the interface. Keep the native project authoritative and re-run DRC inside KiCad after any agent edit.
Not at present. Current tools automate drafting, placement and routing, but engineers still define constraints, review footprints and signal integrity, and sign off on the design for manufacturing. What shrinks is typing and searching. What grows is constraint definition, review discipline and accountability.
Not reliably. The vendors are direct about it: DeepPCB keeps DDR nets, length matching, advanced impedance control and RF constraints with engineers, and Quilter lists length matching, RF routing and blind or buried vias as maturing features. Route these by hand, then let AI handle the routine nets around them.
You do not have to — but do tell them what you are uncertain about. Naming the specific regions and footprints you want reviewed gets a far more useful CAM response than a silent upload, and it costs nothing.
AI tools for PCB design now cover different parts of the same workflow. Some turn requirements into schematics and BOMs, some focus on placement and routing, and some combine several stages in a single environment. The right choice depends largely on where you are starting: an idea, a set of requirements, a schematic, or a partially placed board.
The most useful tool is not the one that does the most. It is the one that fits your workflow and provides the right level of automation without taking control away from the engineer — and the only way to know which one that is, is to start from the file you already have.
Upload Gerber and BOM, get a quotation within one business day, and have a project manager check the files before anything reaches the line.
