Marco Serwis
  • 3 Projects
  • 2 Followers
  • Sep 02,2025
H2S-based walkie talkies
This LoRa walkie-talkie works by digitizing and compressing voice, sending it over LoRa in small data packets, and playing it on the receiver.
Using a LoRa module to build a walkie-talkie is an innovative project, but it’s quite different from traditional analog or digital voice walkie-talkies. LoRa (Long Range) is a low-power, long-range wireless communication technology designed for low data rate applications, like sensor data in IoT—not for continuous audio streaming. However, it can still be used for walkie-talkie-style communication with some trade-offs.
This LoRa walkie-talkie works by digitizing and compressing voice, sending it over LoRa in small data packets, and playing it on the receiver. It’s not real-time or full-duplex, but provides very long range, low power, and basic walkie-talkie functionality for voice messages.
1. Hardware Components
  • H2S – Dev board
  • Microphone (electret or MEMS) for audio input
  • Speaker or earphone for audio output
  • Audio codec (e.g., VS1053 or custom ADC/DAC) for compressing/decompressing audio
  • Push-to-Talk (PTT) button
  • Power supply (battery)
2. High-Level Working Process
a. Capture Audio
  • The microphone captures analog audio signals when the user presses the PTT button.
  • Audio is digitized using an ADC (Analog to Digital Converter) on the microcontroller or an external codec.
b. Compress & Packetize Audio
  • Raw audio is compressed (e.g., using ADPCM or other lightweight codecs) because LoRa has limited bandwidth (~300bps to 37.5kbps depending on settings).
  • The digitized audio is broken into small packets suitable for LoRa transmission.
c. Transmit Audio Over LoRa
  • The packets are sent sequentially over the LoRa radio.
  • Due to LoRa’s long range but low data rate, this is typically half-duplex and delayed (latency from buffering and packet transmission).
d. Receive and Reconstruct Audio
  • The receiving device listens for incoming packets.
  • It reassembles and decompresses the audio.
  • Finally, it outputs the audio through a DAC and speaker.
3. Key Considerations & Challenges
Aspect
Details
Latency
LoRa is not real-time; expect a delay of ~100ms to several seconds depending on bitrate and compression.
Audio Quality
Low bitrate audio (e.g., 8 kHz, 4-bit ADPCM) results in lower quality, but intelligible voice.
Duplexing
Only half-duplex possible (talk OR listen, not both at once), similar to traditional walkie-talkies.
Power Consumption
LoRa is very low-power for data transmission, but audio processing (especially codecs) can consume more.
Range
Can reach 1-15+ km depending on environment, antenna, and power settings. Far exceeds typical walkie-talkies.
11.8k
16
  • Like( 16 )
