BGA packages pack more I/O into less space — but every solder joint hides underneath the body.
You can't see them. You can't probe them. And AOI only reaches the outer row.
So how do you actually know a BGA is reliably soldered?
BGA assembly starts with accurate paste deposition.
Stencil thickness and aperture design, aperture area ratio (≥0.66 is a common rule of thumb), paste volume, print alignment, and paste condition — temperature, viscosity, and working life — all decide how much solder ends up on each pad.
For fine pitch, that usually means thinner stencils (75 µm or less), electroformed or nano-coated apertures, and Type 5/6 powder.
SPI closes the loop, measuring volume, height, and area per pad before a single component is placed.
At fine pitch, tolerance shrinks fast.
The placement system has to register each ball to its pad, not just the package outline — ball-based vision recognition generally beats outline recognition below ~0.4 mm pitch.
Placement force matters too: too much and you squeeze paste out, too little and the part floats during reflow.
This is where the joint is actually formed:
Nitrogen helps wetting and reduces voiding at fine pitch. The right profile always depends on the component, board design, alloy, and overall thermal mass.
| Inspection Method | What It Can Detect |
| AOI | Verifies presence, polarity, offset, and the outer ball row only |
| AXI (X-Ray) | Sees voids, bridges, misalignment, and missing or insufficient solder |
| 3D X-Ray / CT | For defects 2D misses, notably head-in-pillow |
| Electrical test | ICT / flying probe / boundary scan — some opens look perfectly fine on X-ray |
| Cross-sectioning | The ground truth for process qualification and failure analysis |
AXI is a commonly used detection method.
Flux outgassing, via-in-pad, reflow profile. Per IPC-7095 / IPC-A-610, void area is commonly held to ≤25% per joint
Excess paste, paste slump, poor stencil wiping, misalignment
Package/board warpage, ball or paste oxidation, weak flux activity. Notoriously hard to catch on 2D X-ray
Oxidation, contamination, or ENIG "black pad"
Board flexure, depaneling stress, drop or mechanical shock
Moisture absorbed before reflow
Print or placement deviation, or failed self-alignment during reflow
Some reliability issues are locked in before the board ever reaches SMT:
Reliable BGA assembly isn't achieved by inspection alone. It's process control from paste printing and placement through reflow — plus design decisions made weeks earlier.
At Elecrow, BGA assembly runs on high-precision SMT placement, controlled reflow profiling, SPI, AOI, and X-Ray inspection, with fine-pitch capability down to 0.2 mm pitch.
