Elecrow Meshtastic Device Comparison: Which ThinkNode Is Right for You?
Meshtastic Hardware Comparison
Compare the ThinkNode M1, M2, M3, M4, M5, M6, M7, M8, M9 and Meshstick by the requirements that shape a real Meshtastic project: battery strategy, local interface, positioning, wearable use, outdoor deployment, gateway connectivity and host integration.
10 devices EU868 / US915 versions Meshtastic app compatible Handheld · Wearable · Tracker · Infrastructure
Updated October 26, 2026 · By Elecrow
Scope: This guide compares the Meshtastic versions of the listed Elecrow products. The ThinkNode M2 discussed here is the battery-free version. M8 is included as an upcoming Meshtastic wearable watch, based on pre-release specifications. Prices are not included. Specifications may change — check the linked product pages for the latest details.
Meshtastic hardware is not a single category. A low-power handheld communicator, a GPS tracker, a wearable watch, a solar-powered outdoor node and a PoE gateway may all use the same mesh ecosystem, but they are designed around different constraints. The most useful question is not “Which model is the most advanced?” but “Which role does my network need to fill?”
This comparison starts with that question. It first maps the ten products, then compares the closest alternatives directly, and finally recommends a device for common maker, engineering, outdoor and field-deployment scenarios.
Meet the Ten Devices
Every card links to its official product page. M8 is an upcoming product — official images will be added at launch.
Quick Comparison: All Ten Devices
Device Platform / Radio Interface Positioning Power Strategy Best Matched Role
M1 nRF52840 / SX1262 1.54-inch EPD GPS support 1200mAh portable battery Low-power handheld communication
M2 ESP32-S3 / SX1262 1.3-inch OLED Confirm for project configuration External power; battery not included Embedded maker projects
M3 nRF52840 / LR1110 Tracker-oriented device GPS, Wi-Fi and BLE functions 770mAh portable battery Tracking, safety and telemetry
M4 nRF52840 / LR1110 Portable device interface GPS support Meshtastic node plus power-bank design Emergency and field power
M5 ESP32-S3 / SX1262 1.54-inch EPD GPS support 1200mAh portable battery Feature-rich handheld use
M6 nRF52840 / SX1262 Node-oriented device GPS support 6W solar + MPPT + 7000mAh storage Remote outdoor infrastructure
M7 ESP32-S3 / LR1110 Gateway-oriented device Gateway-focused USB-C or Ethernet PoE Fixed network gateway
M8 nRF52840 / SX1262 1.54-inch 200×200 E-Ink GNSS support 900mAh wearable battery Wearable off-grid communication
M9 ESP32-S3 / LR1110 2.4-inch LCD + full keyboard GPS support 2300mAh portable battery Standalone communication terminal
Meshstick USB-SPI bridge / SX1262 + TCXO No built-in display Host-dependent USB bus power Raspberry Pi, PC and Linux integration
Use the summary table to shortlist products. The comparisons below explain the trade-offs behind each choice.
Compare by Device Role
Handheld & interactive devices
M1, M2, M5, M8 and M9 are the main products for users who interact directly with the node.
M1 emphasizes power efficiency, M2 provides a battery-free ESP32-S3 platform, M5 adds ESP32-S3 flexibility to a handheld form factor, M8 places Meshtastic on the wrist, and M9 provides the most complete local messaging interface.
The decision is mainly about power, integration freedom, wearable convenience, processing headroom or keyboard-first operation.
Tracking & field devices
M3, M4 and M8 are relevant when the device travels with a person or field team.
M3 is tracking-oriented, M4 combines communication with portable power, and M8 adds wearable access, GNSS, motion monitoring and time synchronization to an off-grid communicator.
Choose based on whether location, power support or hands-free access is the primary job.
Outdoor & fixed infrastructure
M6 and M7 extend the network beyond a handheld node.
M6 is designed for solar-powered outdoor deployment. M7 is designed for fixed network access using Ethernet and PoE.
The key trade-off is solar independence versus wired network and power access.
Host-connected LoRa hardware
Meshstick takes a different approach: the host computer supplies processing, storage, networking and automation.
It is a strong fit when the project already uses a Raspberry Pi, Linux computer, router or other compatible USB host.
Choose it when you want to build the system around an existing computer.
Head-to-Head Comparisons
M1 vs. M5 vs. M8 — Which portable interface fits your use?
These three products share a low-power-oriented comparison path, GPS-related use and an E-Ink or EPD display approach, but they are designed for different forms of interaction. M1 is a practical handheld endurance choice, M5 is an ESP32-S3 handheld platform, and M8 moves the device onto the wrist.
Comparison Point ThinkNode M1 ThinkNode M5 ThinkNode M8
Platform nRF52840 ESP32-S3 nRF52840
Display 1.54-inch EPD 1.54-inch EPD 1.54-inch 200×200 E-Ink
Battery 1200mAh 1200mAh 900mAh wearable battery
Interaction model Portable handheld node Portable handheld node with ESP32-S3 flexibility Wearable watch with knob and function keys
Additional functions GPS support GPS support GNSS, RTC, 3-axis acceleration and Bluetooth 5.4
Choose it when Efficient handheld operation is the priority ESP32-S3 processing flexibility matters You want communication and positioning on your wrist
Official figures 1200mAh; 48h+ continuous use; ~85mA max (CPU+LoRa), 5.6µA sleep; GPS/GLONASS/BDS/QZSS 1200mAh; ~340mA max (CPU+LoRa), ~34µA low power; GPS/GLONASS/BDS/QZSS + RTC 900mAh wearable battery; GNSS, RTC, 3-axis accelerometer, Bluetooth 5.4 (pre-release specs)
Bottom line: M1 is the efficiency-focused handheld, M5 is the flexible ESP32-S3 handheld, and M8 is the wearable option.
M2 vs. M5 — Embedded module or complete handheld?
Both use ESP32-S3, but they are not interchangeable products. The battery-free M2 is designed to be integrated into a larger project. The M5 is a portable product with a display, GPS and its own battery system.
Comparison Point ThinkNode M2 ThinkNode M5
Physical concept Battery-free modular board Finished handheld device
Power External power required; battery not included Portable battery-powered operation
Best integration Custom enclosure, vehicle, robot or instrument Field use, portable testing and direct communication
Choose it when You want to define the enclosure and power system You want a ready-to-use ESP32-S3 handheld node
Official figures USB-C 5V/1A or Li-battery connector; ~217mA max working current, ~136mA with screen off; GPIO headers exposed for integration Built-in 1200mAh battery; ~340mA max (CPU+LoRa), ~34µA low power; enclosed shell
Bottom line: M2 is the integration platform; M5 is the complete portable product.
M3 vs. M4 vs. M8 — Tracking, power or wearable access?
These three portable products suit different field workflows. M3 is a compact tracking device, M4 combines a Meshtastic node with portable power, and M8 provides a wearable interface with GNSS and motion-related functions.
Comparison Point ThinkNode M3 ThinkNode M4 ThinkNode M8
Primary use People, vehicles, assets and safety tracking Emergency communication and portable power Wearable off-grid communication and location sharing
Positioning GPS, Wi-Fi and BLE-related functions GPS support GNSS with real-time trajectory and location-sharing support
Interface Compact tracker Power-bank-oriented portable device Watch form factor with E-Ink display, knob and function keys
Choose it when Location updates are central to the project The node must also help power field equipment Hands-free access and wearable status are valuable
Official figures 5–6km LoRa range; GNSS accuracy <1.5m (CEP50); 12–18h per charge at 1 message/min; IP66 Fast charging + reverse charging over USB-C; intelligent power management (over-charge / over-discharge / short-circuit protection); GPS tracking and location sharing 900mAh battery; GNSS with RTC; 3-axis motion sensing; Bluetooth 5.4 (pre-release specs)
Bottom line: M3 is tracking-first, M4 is field-power-first, and M8 is wearable-first.
M6 vs. M7 — Solar outdoor node or PoE gateway?
These products both support infrastructure use, but they are built for different installation conditions. M6 is aimed at remote outdoor deployment with solar charging. M7 is aimed at fixed deployment where Ethernet and PoE are available.
Comparison Point ThinkNode M6 ThinkNode M7
Installation environment Outdoor and remote locations Indoor, building or fixed network locations
Power model 6W solar panel, MPPT and battery storage Ethernet and PoE, or USB-C
Network role Remote node, relay or monitoring station Network-connected gateway
Choose it when Mains power and frequent maintenance are difficult Wired power and network access simplify the installation
Official figures 6W solar panel with MPPT charging; 7000mAh (2×18650) storage; IP65; -20°C to 60°C operating range 8–10km LoRa range; PoE IEEE 802.3af (37–57V DC) or USB-C 5V/1A; -20°C to 70°C operating range
Bottom line: M6 is the solar outdoor strategy; M7 is the wired fixed-gateway strategy.
M7 vs. Meshstick — Independent gateway or host-based gateway?
Both can be used as part of a broader network, but they distribute system responsibility differently. M7 is a gateway-oriented product with Ethernet and PoE. Meshstick is a USB radio interface that relies on a host computer for software and system services.
Comparison Point ThinkNode M7 Meshstick
System model Independent gateway hardware Radio hardware for a host-based system
Connectivity Ethernet and PoE USB to a compatible host
Best fit Fixed installations with simple deployment and management Raspberry Pi, Linux, PC and custom automation projects
Choose it when You want the gateway hardware to be self-contained You want the host to provide dashboards, databases, scripts or network services
Official figures Pre-installed gateway function, plug-and-play; 100Mbps Ethernet + PoE; RP-SMA external antenna; wall-mount / desktop base included +22dBm max TX with TCXO; supports x86-64 / arm64 / armhf hosts (Raspberry Pi, OpenWrt routers, industrial PCs, Steam Deck); meshtasticd web UI; open-source hardware
Bottom line: M7 simplifies fixed gateway deployment; Meshstick maximizes host-side flexibility.
M5 vs. M9 — Compact handheld or full communication terminal?
Both are ESP32-S3-based portable products, but their interaction models are different. M5 is a compact handheld node with a 1.54-inch display. M9 is built around a larger LCD and a full keyboard for direct message entry.
Bottom line: choose M5 for a compact feature-rich handheld; choose M9 when the device itself must be the primary messaging interface.
Compare by the Requirement That Matters Most
Best for battery-efficient handheld use
Start with M1. Its nRF52840 platform and 1200mAh battery make it the natural comparison point when minimizing power consumption matters more than maximum application processing.
Official figures: 48h+ continuous use on the 1200mAh battery; ~85mA max current (CPU+LoRa); 5.6µA sleep current — the lowest in this lineup.
Best for a wearable Meshtastic device
Start with M8. It puts LoRa communication, GNSS location sharing, Bluetooth 5.4, an E-Ink screen and motion-related functions on the wrist. Its wearable form factor is the main differentiator, not just another display size.
Pre-release specs: 900mAh battery; 1.54-inch 200×200 E-Ink (sunlight-readable); knob + function keys. Field data will be added after launch.
Best for custom maker integration
Start with M2 if you already have an external power plan or want to design the enclosure yourself. Choose M5 when you want a complete portable product instead of a module-like platform.
Official figures: ~217mA max working current, ~136mA with screen off; USB-C 5V/1A input plus Li-battery connector; GPIO headers and mounting holes for enclosure integration.
Best for GPS tracking
Start with M3 when location is the main application requirement. M8 is a strong alternative when the user needs a wearable device with GNSS, status information and motion monitoring.
Official figures (M3): GNSS accuracy <1.5m (CEP50); tracking sensitivity -162dBm; configurable reporting interval with offline data caching; works in a trouser or shirt pocket.
Best for emergency communication and power
Start with M4 when the Meshtastic node also needs to support the rest of a portable field kit. Its power-bank design makes it different from a normal handheld or wearable node.
Official description: high-energy-density lithium-polymer cell; fast charging and reverse charging over USB-C; over-charge, over-discharge and short-circuit protection.
Best for long-term outdoor deployment
Start with M6 when the node must stay outdoors and mains power is not convenient. Evaluate solar conditions, battery storage, antenna placement and maintenance access together.
Official figures: 6W solar panel with MPPT smart charging; 7000mAh storage (2×18650); IP65; -20°C to 60°C operating range; four mounting options.
Best for a fixed PoE gateway
Start with M7 when Ethernet and PoE are available. The key performance questions are coverage, network stability, installation height and continuous operation.
Official figures: 8–10km LoRa range with external antennas; PoE IEEE 802.3af (37–57V DC); -20°C to 70°C operating range; 74×74×33mm, 80g.
Best for messaging without a smartphone
Start with M9 when the device itself must support frequent message entry. Its 2.4-inch LCD and full keyboard provide the most complete local communication interface in this comparison.
Official figures: 2.4-inch TFT (240×320) at 200cd/m²; 37-key QWERTY keyboard with chat/map shortcut keys; 2300mAh battery with 2–3 days standby.
Best for Raspberry Pi or Linux projects
Start with Meshstick when the host computer should provide the operating system, storage, networking, dashboards, scripts or databases.
Official figures: x86-64 / arm64 / armhf support — Raspberry Pi, industrial PCs, OpenWrt routers, Steam Deck; USB bus-powered; managed via meshtasticd web UI.
Scenario-Based Recommendations
Project Requirement Recommended Reason
Weekend hiking, camping or event communication M1 Low-power handheld design, display and GPS support.
Embedding a Meshtastic node into custom hardware M2 Battery-free ESP32-S3 platform with external-power flexibility.
People, vehicle or asset tracking M3 Tracking-oriented functions in a compact portable device.
Multi-day field use where other devices need charging M4 Meshtastic communication combined with portable power.
ESP32-S3 handheld development and customization M5 Portable form factor, display, GPS and ESP32-S3 platform.
Wearable off-grid communication and GPS sharing M8 Watch form factor, E-Ink display, GNSS, Bluetooth 5.4 and 900mAh battery.
Permanent outdoor or remote coverage M6 Solar charging, battery storage and outdoor deployment design.
Indoor fixed gateway with wired power and backhaul M7 Ethernet and PoE support for fixed installation.
Standalone communication with physical keys M9 2.4-inch LCD and full keyboard for direct message entry.
Raspberry Pi, Linux, PC or host-based gateway Meshstick USB-connected SX1262 radio for custom host systems.
A Practical Meshtastic Device Decision Tree
  1. Do you need a device that stays with a person?
    • Want a watch form factor and wearable status? Choose M8.
    • Need a physical keyboard and larger local interface? Choose M9.
    • Prioritize low-power handheld operation? Compare M1.
    • Need an ESP32-S3 handheld platform? Compare M5.
    • Need your own external power system and enclosure? Choose M2.
    • Need a tracking-first device with compact placement? Compare M3.
    • Need communication plus portable power? Compare M4.
  2. If you need a deployed network device:
    • Need solar-powered outdoor deployment? Choose M6.
    • Need Ethernet and PoE? Choose M7.
    • Need a Raspberry Pi, PC or Linux host? Choose Meshstick.
Field-Test Reference: What the Official Specs Tell Us
Independent lab testing takes time. Until measured results are available, the official specifications below are the most reliable anchor points for evaluating each device in the field — range, runtime, positioning, endurance and host compatibility, all taken from Elecrow's product pages.
A note on these figures: all data in this section comes from official Elecrow product pages, not from independent lab tests. Real-world range and runtime vary with antenna placement, terrain, radio settings, regional frequency and message interval. Treat the numbers as comparable design targets, and re-test under your own conditions before committing to a large deployment.
Evaluation Area Products Official Specification Reference
Communication range All products, grouped by handheld, wearable, outdoor and gateway role M3 rated 5–6km; M7 rated 8–10km with external antennas; M1/M5 transmit at up to +22dBm via external antenna; Meshstick up to +22dBm with TCXO stability; M6 uses high-gain external antennas
Battery runtime M1, M3, M4, M5, M8 and M9 M1: 48h+ continuous use, 5.6µA sleep; M3: 12–18h at 1 message/min; M5: ~34µA low-power mode; M9: 2–3 days standby (2300mAh); M8: 900mAh wearable battery (runtime TBD after launch); M4: power-bank-grade cell
GPS acquisition and accuracy M1, M3, M4, M5, M6, M8 and M9 M3: <1.5m CEP50, -162dBm tracking sensitivity, GPS/GLONASS/Galileo/BDS; M1/M5: GPS/GLONASS/BDS/QZSS with RTC-assisted warm start; M6: L76K module; M9: GPS/BDS/Galileo/GLONASS plus magnetic compass; M8: GNSS with RTC (pre-release)
Wearability and readability M8 1.54-inch 200×200 E-Ink readable in sunlight; knob + function keys; watch form factor — final figures after launch
Outdoor endurance M3, M4, M6 and M8 M3: IP66, -20°C to 60°C, magnetic charging with no exposed ports; M6: IP65, -20°C to 60°C, SP11 waterproof aviation connectors for external sensors
Solar operation M6 6W solar panel with MPPT smart charging; 7000mAh storage (2×18650); wall, bracket, pole and U-clamp mounting
PoE and network stability M7 PoE IEEE 802.3af (37–57V DC); 10/100Mbps Ethernet; USB-C 5V/1A fallback; -20°C to 70°C operating range
Host compatibility Meshstick x86-64 / arm64 / armhf; Raspberry Pi, OpenWrt routers, industrial PCs, Steam Deck; meshtasticd daemon with web management; onboard EEPROM for unique node identity
Frequently Asked Questions
What is the best Elecrow Meshtastic device?
There is no single best device for every project. M1 is a strong low-power handheld choice, M3 focuses on tracking, M6 is designed for solar outdoor deployment, M7 is a fixed PoE gateway, M8 is a wearable communication and GPS watch, M9 is a standalone communicator and Meshstick is a host-connected LoRa interface.
What is the difference between ThinkNode M1, M5 and M8?
M1 emphasizes power-efficient handheld use. M5 combines a handheld form factor with an ESP32-S3 platform. M8 is a wearable nRF52840 and SX1262 watch with a 1.54-inch E-Ink display, GNSS support and a 900mAh battery.
Is the ThinkNode M2 in this comparison battery powered?
No. This article covers the battery-free M2 version. It is intended for projects that provide their own external power system, enclosure or embedded integration.
What makes the ThinkNode M8 different from a normal handheld node?
The M8 uses a wearable watch form factor. It combines Meshtastic LoRa communication with a 1.54-inch 200×200 E-Ink display, GNSS, Bluetooth 5.4, a 900mAh battery, an RTC and a 3-axis accelerometer for time synchronization and motion-related applications.
Should I choose the M6 or M7 for a Meshtastic gateway?
Choose M6 when outdoor solar charging and remote deployment are important. Choose M7 when Ethernet and PoE are available and a fixed network-connected gateway is the priority.
What is the Meshstick used for?
The Meshstick adds an SX1262 LoRa interface to a compatible USB host. It is suitable for Raspberry Pi, PC, Linux and custom gateway projects where the host provides processing, storage, networking and automation.
Conclusion
The right Elecrow Meshtastic device is determined by the role your network needs, not by the model number alone. Compare M1 and M5 when choosing between power efficiency and ESP32-S3 flexibility. Compare M1, M5 and M8 when deciding between a low-power handheld, an ESP32-S3 handheld and a wearable communicator.
M2 is the battery-free integration platform. M3, M4 and M8 divide portable use between tracking, field power and wearable access. For infrastructure, M6 and M7 represent two different deployment strategies: solar outdoor operation versus wired Ethernet and PoE. M9 is the strongest choice when users need to type messages directly on the device, while Meshstick is the natural choice when a Raspberry Pi, Linux computer or other host should run the wider system.
These official figures give every reader a solid, comparable starting point — and as Elecrow adds measured range, runtime, GPS, wearability, outdoor, PoE and host-compatibility results over time, this comparison will keep helping makers and engineers move from a list of specifications to a confident hardware decision.
Explore the Elecrow ThinkNode series and Meshstick to start building your Meshtastic network.
Product information and availability may change. Confirm the latest official product specifications before publication.
