How Grovety Turned 900 Elevator Cabins into Ad Revenue with Elecrow CrowPanel ESP32-P4
Case Study · Digital Signage
Published June 25, 2026 · Elecrow CrowPanel · ESP32-P4
An elevator-maintenance company wanted the lifts it already services to start paying for themselves. By installing standalone in-cabin media panels built on the Elecrow CrowPanel (ESP32-P4), Grovety turned every cabin into a paid ad slot—complete with offline looped playback, watchdog reliability, and no-laptop content updates over Wi-Fi, USB, or SD. What began as a 100-unit pilot has grown into a 900-unit revenue fleet.
The Challenge: Making Elevators Work Harder
Elevator cabins are high-traffic, captive-audience environments. For a maintenance operator servicing hundreds of buildings, they represent untapped real estate. The problem? Traditional digital signage hardware is expensive, power-hungry, and built for always-on internet. Elevator shafts are not data centers. Any solution needed to run autonomously, survive power glitches, and let field staff update ads without carrying a laptop into a service hatch.
The Solution: CrowPanel ESP32-P4 as an Ad-Ready Appliance
Grovety chose the Elecrow CrowPanel powered by the ESP32-P4 SoC because it offered the right balance of display performance, embedded reliability, and flexible content management at a fleet-friendly price point. Instead of treating each panel as a mini PC, they treated it as an appliance: turn it on, load content, and let it run.
Core Capabilities Delivered
Offline Looped Playback
Content is stored locally and plays continuously without an internet connection, eliminating dependency on elevator-shaft Wi-Fi quality.
Watchdog Protection
A hardware watchdog ensures the panel recovers automatically from freezes or power events, reducing service calls.
Triple-Path Updates
Ad playlists can be refreshed over Wi-Fi, USB, or SD card, giving technicians options in the field.
Camera-Ready Hardware
An onboard camera interface allows future audience-analytics or occupancy-triggered content without a hardware swap.
Content Workflow: Three Steps from Upload to Screen
Grovety kept the operational overhead low. A technician can walk into a building, connect to the panel's access point via a QR code on the bezel, and push new creative in minutes. No software installs, no cloud dashboards, no IT tickets. The workflow is intentionally simple:
  1. Connect. Scan the QR code or join the panel's AP directly from a phone.
  2. Upload. Drop the new image or video loop via the local web portal.
  3. Commit. The panel validates the file, switches playback, and resumes the loop.
This local-first approach means buildings with strict firewall rules or no guest Wi-Fi can still receive fresh campaigns on schedule.
Storage Flexibility for Every Building Profile
Not every elevator has the same connectivity. Grovety's fleet uses a mix of update strategies matched to site conditions:
  • Wi-Fi push: Used in modern commercial towers with stable networks.
  • USB/SD swap: Used in older residential buildings or basements with poor signal.
  • Hybrid mode: Scheduled Wi-Fi updates with SD card as a fallback.
The CrowPanel's embedded storage and ESP32-P4's low-power architecture mean the panel can cache multiple campaigns and rotate them based on time-of-day rules, even when offline for weeks.
Results: From Pilot to Fleet
100 Units in Pilot
900 Units Deployed
3 Update Methods
0 Laptops Required
The 100-unit pilot proved that elevator cabins could generate ad revenue with minimal maintenance overhead. Once the unit economics were validated, Grovety scaled to 900 active panels across its service territory. Each cabin now contributes to a recurring revenue stream that offsets maintenance costs and creates a new profit center for the business.
Why Elecrow CrowPanel Fit the Use Case
Industrial digital signage often defaults to high-cost ARM boards or x86 boxes that require active cooling and complex OS management. The CrowPanel ESP32-P4 offered Grovety a different path:
  • Integrated display + controller: A single SKU reduces BOM complexity and supply-chain risk.
  • Industrial temperature range: Operates reliably in the variable temperatures of elevator machine rooms and cabins.
  • Low power draw: Minimizes electrical load on existing building circuits.
  • Extension-ready I/O: The camera header and GPIO allow future sensors or intercom integration without a board redesign.
What Comes Next
Grovety is already exploring the next phase: using the onboard camera for audience impression counting and demographic-triggered ad rotation. Because the CrowPanel hardware was chosen with headroom, these upgrades are a firmware and peripheral change—not a forklift replacement of 900 units.
Build Your Own Fleet-Ready Signage
Whether you are deploying 10 screens or 1,000, Elecrow CrowPanel gives you an integrated, ESP32-P4-powered display platform designed for commercial environments.
Explore CrowPanel ESP32-P4
